Als erstes musst Du mal im setup() festlegen, das Du einen lcd verwendest.
Dazu gehört entweder eine Zeile
lcd.begin();
oder einer Zeile
lcd.init();
Eine von beiden ist richtig - die andere lässt Dich den Sketch nicht kompilieren.
Wenn es dann noch nicht geht:
Lade den folgenden Code auf Deinen Controller und kontrolliere, ob dei Adresse 0x27 stimmt.
// i2c_scanner
// Version 1
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
// Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26 2013
// V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
// by Arduino.cc user Krodal.
// Changes by louarnold removed.
// Scanning addresses changed from 0...127 to 1...119,
// according to the i2c scanner by Nick Gammon
// http://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
// As version 4, but address scans now to 127.
// A sensor seems to use address 120.
// Version 6, November 27, 2015.
// Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
Wire.begin();
while (!Serial); // Leonardo: wait for serial monitor
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for (address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
Serial.print(error);
Serial.println(address);
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address < 16)
{ Serial.print("0"); }
Serial.print(address, HEX);
Serial.println(" !");
nDevices++;
else if (error == 4)
Serial.print("Unknown error at address 0x");
if (address < 16)
Serial.println(address, HEX);
if (nDevices == 0)
{ Serial.println("No I2C devices found\n"); }
{ Serial.println("done\n"); }
delay(5000); // wait 5 seconds for next scan
Wenn die Adresse stimmt, dann nimm Deinen Code in dieser veränderten Form:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
// lcd.begin(); // eines von beiden stimmt
lcd.init();
lcd.setCursor(0, 0);
lcd.print(" STEPS - 0");
lcd.setCursor(0, 1);
lcd.print(" RPS - 0.00");
und spiel den auf.
Wenn Du nix zu sehen bekommst, drehe an dem kleinen Drehwiderstand - der ist für den Kontrast zuständig. Es könnte sein, das er einfach zuweit zugedreht ist.
Berichte.
