Hello
I have a problem with my Arduino Uno connected to LCD by I2C converter. When I am connecting my Arduino with 16x2 LCD normally (by RS R/W EN etc) its work fine but when im trying connect it by I2C converter my LCD is light on but it doesnt shown any letters. I can change contrast so i dont think that converter is broken. Even the I2C scanner is detecting nothing (No I2C devices found). I have Arduino Uno R3 so i tried connecting SDA ->A4, SCL -> A5 and SDA->SDA, SCL->SCL (Uno R3 have output SCL and SDA pins).My libraries are imported properly (my code is compile without errors) I would be gratefull for any help. I am adding code which i used to.
#include <Wire.h>
Wire.begin();
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
//kod ze strony botlandu
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
lcd.begin(16,2);
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Hello, world!");
lcd.setCursor(0,1);
lcd.print("BOTLAND.com.pl");
lcd.backlight();
delay(5000);
lcd.noBacklight();
delay(5000);
