Hi, I am using a 2IC LCD 2*16 and I have the following issue:
While playing the « Hello World » prgm only white squares are displayed on the first line.
I use a Mega so SDA and SLC are on pin 20 and 21.
I played the « scanner » prgm to check the I2C address to use which also helped me to confirm that my connection to pins are good (whenever I unplug one pin or if I exchange the 2 pins 20 and 21 then I2C device is not recognised anymore)
But still I have those white squares…
If anyone has an idea I would be very greatfull.
However I have no potentiometer on my LCD… but I don’t think this is the reason neither regarding the I2C adress (027 is good)
Indeed reading from another similar subject I’ve installed hd44780 library and I’ve run the I2CexpDiag squetch.
Strangely while doing this I got my LCD to display runtime properly.
I say strangely because then I tried to run the « hello world » squetch which comes with the library and then got the same pb again: white square on the first line.
So I know my LCD can work, but I don’t know how to do it
Each i/o class in the hd44780 library has its own examples and its own HelloWorld sketch. Likely the OP was running a HelloWorld from the wrong i/o class for his LCD.
