LCD keypad Shield With UV UVM-30A
I'm trying to get an LCD reader to show my data from my UV sensor, I don't understand this appears in the code---->
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,4,5,6,7);
#define pinSensorUV    A5
#define divisor        20
 int indiceUV;
 lcd.begin(16,2);
 pinMode(pinSensorUV, INPUT);
 lcd.setCursor(0,0);
 lcd.print("INDICE ");
 lcd.setCursor(0,1);
 lcd.print("UV :");
lcd.setCursor(8,1);
  lcd.print (indiceUV);
  delay(500); // DELAY PARA APROXIMAR AS MEDIDAS DO TEMPO DE RESPOSTA DO SENSOR DE 500 mS
    leituraUV = analogRead(pinSensorUV); // REALIZA A LEITURA DA PORTA ANALÓGICA
    indiceUV = map(leituraUV, 0,203,0,10) ; // CONVERTE A FAIXA DE SINAL DO SENSOR DE 0V A 1V PARA O INDICE UV DE 0 A 10.
  #ifdef DEBUG
    Serial.print("Indice UV: ");
    Serial.println(indiceUV);
  #endif
leituraUV wasn't defined, so code wouldn't compile
try this
LiquidCrystal lcd (8,9,4,5,6,7);
char s [80];
void setup () {
    Serial.begin (9600);
    lcd.begin (16,2);
    lcd.setCursor (0,0);
    lcd.print ("INDICE ");
    lcd.setCursor (0,1);
    lcd.print ("UV :");
void loop ()
    int leituraUV = analogRead (pinSensorUV);     // read sensor
    int indiceUV  = map (leituraUV, 0,203,0,10);  // map from 0-10
    lcd.setCursor (8,1);
    sprintf (s, "leitura %4d, indice %3d", leituraUV, indiceUV);
    Serial.println (s);
    delay (500); // slow output
