LCD Large Font Help
Hello All!
I'm working on a project inspired by the following instructable: http://www.instructables.com/id/Custom-Large-Font-For-16x2-LCDs/. I've got a 16x2 LCD with a keypad on it attached to a crane scale. Unfortunately, the numbers are too small on a single line, so I'm trying to use a large font over two lines. To test the programming, I've got an LCD Keypad shield attached to an Uno and am reading values from the keypads on A0. If the analog value is under 1000, it displays beautifully on the screen. If it's over 1000, however, the hundreds digit is cut off. If you have a similar setup, could you load my program and give any insight as to what I might be doing wrong? I suspect the problem lies in the section of code where I'm breaking down the analog value from thousands to hundreds, to tens, to ones, but I can't quite figure it out. I'm so close! Any help is greatly appreciated.
Here's the code:
#include <LiquidCrystal.h>
//Initial program Made by Michael Pilcher
//2/9/2010
//Modified and customized by Nick Pulver
//8/28/2013
// These constants won't change. They're used to give names
// to the pins used:
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
//char outputValueChar[5];
int thousands;
int hundreds;
int tens;
int ones;
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// the 8 arrays that form each segment of the custom numbers
byte A[8] =
B00111,
B01111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
byte B[8] =
B11111,
B11111,
B11111,
B00000,
B00000,
B00000,
B00000,
B00000
byte C[8] =
B11100,
B11110,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
byte D[8] =
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B01111,
B00111
byte E[8] =
B00000,
B00000,
B00000,
B00000,
B00000,
B11111,
B11111,
B11111
byte F[8] =
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11110,
B11100
byte G[8] =
B11111,
B11111,
B11111,
B00000,
B00000,
B00000,
B11111,
B11111
byte H[8] =
B11111,
B00000,
B00000,
B00000,
B00000,
B11111,
B11111,
B11111
// loop counter
int x = 0;
// assignes each segment a write number
lcd.createChar(0,A);
lcd.createChar(1,B);
lcd.createChar(2,C);
lcd.createChar(3,D);
lcd.createChar(4,E);
lcd.createChar(5,F);
lcd.createChar(6,G);
lcd.createChar(7,H);
// sets the LCD's rows and colums:
lcd.begin(16, 2);
void custom0()
{ // uses segments to build the number 0
lcd.setCursor(x, 0); // set cursor to column 0, line 0 (first row)
lcd.write((byte)0); // call each segment to create
lcd.write(1); // top half of the number
lcd.write(2);
lcd.setCursor(x, 1); // set cursor to colum 0, line 1 (second row)
lcd.write(3); // call each segment to create
lcd.write(4); // bottom half of the number
lcd.write(5);
void custom1()
lcd.setCursor(x,0);
lcd.write(1);
lcd.write(2);
lcd.write(32);
lcd.setCursor(x,1);
lcd.write(32);
lcd.write(255);
lcd.write(32);
void custom2()
lcd.setCursor(x,0);
lcd.write(6);
lcd.write(6);
lcd.write(2);
lcd.write(3);
lcd.write(7);
lcd.write(7);
void custom3()
lcd.setCursor(x,0);
lcd.write(6);
lcd.write(6);
lcd.write(2);
lcd.write(7);
lcd.write(7);
lcd.write(5);
void custom4()
lcd.setCursor(x,0);
lcd.write(3);
lcd.write(4);
lcd.write(2);
lcd.write(32);
lcd.write(32);
lcd.write(255);
void custom5()
lcd.setCursor(x,0);
lcd.write((byte)0);
lcd.write(6);
lcd.write(6);
lcd.write(7);
lcd.write(7);
lcd.write(5);
void custom6()
lcd.setCursor(x,0);
lcd.write((byte)0);
lcd.write(6);
lcd.write(6);
lcd.write(3);
lcd.write(7);
lcd.write(5);
void custom7()
lcd.setCursor(x,0);
lcd.write(1);
lcd.write(1);
lcd.write(2);
lcd.write(32);
lcd.write((byte)0);
lcd.write(32);
void custom8()
lcd.setCursor(x,0);
lcd.write((byte)0);
lcd.write(6);
lcd.write(2);
lcd.write(3);
lcd.write(7);
lcd.write(5);
void custom9()
lcd.setCursor(x,0);
lcd.write((byte)0);
lcd.write(6);
lcd.write(2);
lcd.write(32);
lcd.write(32);
lcd.write(255 );
// read the analog in value:
outputValue = analogRead(analogInPin);
// map it to the range of the analog out:
// print the results to the serial monitor:
Serial.print("output = ");
Serial.println(outputValue);
String stringOne = String(outputValue);
x=0;
//THIS IS WHERE I THINK THE PROBLEM LIES
/*The following section breaks down the analog value
into thousands, hundreds, tens, ones, and attaches them to
a custom large-font number*/
thousands = outputValue /1000;
switch(thousands)
case 5:
custom5();
case 4:
custom4();
case 3:
custom3();
case 2:
custom2();
case 1:
custom1();
case 0:
custom0();
hundreds = outputValue /100;
switch (hundreds) {
  case 9:
custom9();
case 8:
custom8();
case 7:
custom7();
case 6:
custom6();
case 5:
custom5();
case 4:
custom4();
case 3:
custom3();
case 2:
custom2();
case 1:
custom1();
case 0:
custom0();
tens=outputValue /10;
tens=tens%10;
switch (tens) {
case 9:
x=x+4;
custom9();
case 8:
x=x+4;
custom8();
case 7:
x=x+3;
custom7();
case 6:
x=x+4;
custom6();
case 5:
x=x+4;
custom5();
case 4:
x=x+4;
custom4();
case 3:
x=x+4;
custom3();
case 2:
x=x+4;
custom2();
case 1:
x=x+4;
custom1();
if (outputValue<10)
//case 0:
x=x+4;
custom0();
case 0:
x=x+4;
custom0();
ones=outputValue%10;
//ones=ones%100;
// Serial.println(ones);
switch (ones) {
case 9:
x=x+4;
custom9();
case 8:
x=x+4;
custom8();
case 7:
x=x+4;
custom7();
case 6:
x=x+4;
custom6();
case 5:
x=x+4;
custom5();
case 4:
x=x+4;
custom4();
case 3:
x=x+4;
custom3();
case 2:
x=x+4;
custom2();
case 1:
x=x+4;
custom1();
case 0:
x=x+4;
custom0();
first I would replace all those little customX() functions with a parameterized call to custom(byte X)
that will make the code more compact -> less typos, less to debug etc.
fontHelper(byte a, byte b, byte c, byte d, byte e, byte f)
    lcd.setCursor(x,0);
    lcd.write(a);
    lcd.write(b);
    lcd.write(c);
    lcd.setCursor(x,1);
    lcd.write(d);
    lcd.write(e);
    lcd.write(f);
void custom(byte digit)
  switch (digit)
    case 0: fontHelper(1,2,32,32,255,32); break;
    case 1: fontHelper(1,2,32,32,255,32); break;
    case 2: fontHelper(6,6,2,3,7,7); break;
    case 3: fontHelper(6,6,2,7,7,5); break;
    case 4: fontHelper(3,4,2,32,32,255); break;
    // TODO the next 5
    case 5: fontHelper(1,2,32,32,255,32); break;
    case 6: fontHelper(1,2,32,32,255,32); break;
    case 7: fontHelper(1,2,32,32,255,32); break;
    case 8: fontHelper(1,2,32,32,255,32); break;
    case 9: fontHelper(1,2,32,32,255,32); break;
Then your loop can become smaller too,
less typing, more overview, less errors, more fun!
  outputvalue %= 1000;
  outputvalue %= 100;
  tens = outputValue /10;
  ones = outputvalue % 10;
  x = 0;
  custom(thousands);
  x = 1;
  custom(hundreds);
  x = 2;
  custom(tens);
  x = 3;
  custom(ones);
  delay(1000);  // just made this one up
Wow! Thanks for the quick, helpful response. I'm working on it right now. First off, I get an error:
ISO C++ forbids declaration of 'fontHelper' with no type
Any ideas?
Had not tested it, should compile now, (I have another liquidCrystal lib that gives me some low level errors)
// Initial program Made by Michael Pilcher
// 2/9/2010
// Modified and customized by Nick Pulver
// 8/28/2013
byte A[8] = {
B00111,
B01111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
byte B[8] = {
B11111,
B11111,
B11111,
B00000,
B00000,
B00000,
B00000,
B00000
byte C[8] = {
B11100,
B11110,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
byte D[8] = {
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B01111,
B00111
byte E[8] = {
B00000,
B00000,
B00000,
B00000,
B00000,
B11111,
B11111,
B11111
byte F[8] = {
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11110,
B11100
byte G[8] = {
B11111,
B11111,
B11111,
B00000,
B00000,
B00000,
B11111,
B11111
byte H[8] = {
B11111,
B00000,
B00000,
B00000,
B00000,
B11111,
B11111,
B11111
int x;
void fontHelper(byte a, byte b, byte c, byte d, byte e, byte f)
    lcd.setCursor(x,0);
    lcd.write(a);
    lcd.write(b);
    lcd.write(c);
    lcd.setCursor(x,1);
    lcd.write(d);
    lcd.write(e);
    lcd.write(f);
  switch (digit)
    // TODO
  lcd.begin(16, 2);
  int outputValue = analogRead(analogInPin);
  byte thousands = outputValue /1000;
  outputValue %= 1000;
  byte hundreds = outputValue /100;
  outputValue %= 100;
  byte tens = outputValue /10;
  byte ones = outputValue % 10;
  x = 0;
  custom(thousands);
  x = 1;
  custom(hundreds);
  x = 2;
  custom(tens);
  x = 3;
  custom(ones);
I think you had some problems with dissecting the outputValue into individual digits..
That's exactly what the problem was. Everything works beautifully well. Here's the final code. Made some cursor adjustments. Thanks for the help!
// 2/9/2010
// 8/28/2013
byte A[8] = {
B00111,
B01111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
byte B[8] = {
B11111,
B11111,
B11111,
B00000,
B00000,
B00000,
B00000,
B00000
byte C[8] = {
B11100,
B11110,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
byte D[8] = {
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B01111,
B00111
byte E[8] = {
B00000,
B00000,
B00000,
B00000,
B00000,
B11111,
B11111,
B11111
byte F[8] = {
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11110,
B11100
byte G[8] = {
B11111,
B11111,
B11111,
B00000,
B00000,
B00000,
B11111,
B11111
byte H[8] = {
B11111,
B00000,
B00000,
B00000,
B00000,
B11111,
B11111,
B11111
int x;
    lcd.setCursor(x,0);
    lcd.write(a);
    lcd.write(b);
    lcd.write(c);
    lcd.setCursor(x,1);
    lcd.write(d);
    lcd.write(e);
    lcd.write(f);
  switch (digit)
    case 0: fontHelper(0,1,2,3,4,5); break;
    case 5: fontHelper(255,6,6,7,7,5); break;
    case 6: fontHelper(0,6,6,3,7,5); break;
    case 7: fontHelper(1,1,2,32,0,32); break;
    case 8: fontHelper(0,6,2,3,7,5); break;
    case 9: fontHelper(0,6,2,32,32,255); break;
  lcd.begin(16, 2);
  outputValue %= 100;
  x = 0;
  custom(thousands);
  x = x+4;
  custom(hundreds);
  x = x+4;
  custom(tens);
  x = x+4;
  custom(ones);
last note: x = x + 4; can be written as x += 4;
You can make a parameter of the position, pos is 0,1,2,3,...
void fontHelper(byte pos, byte a, byte b, byte c, byte d, byte e, byte f)
    lcd.setCursor(pos*4, 0);  //
    lcd.write(a);
    lcd.write(b);
    lcd.write(c);
    lcd.setCursor(pos*4, 1);
    lcd.write(d);
    lcd.write(e);
    lcd.write(f);
void custom(byte pos, byte digit)
  switch (digit)
    case 0: fontHelper(pos, 0,1,2,3,4,5); break;
    case 1: fontHelper(pos, 1,2,32,32,255,32); break;
    case 2: fontHelper(pos, 6,6,2,3,7,7); break;
    case 3: fontHelper(pos, 6,6,2,7,7,5); break;
    case 4: fontHelper(pos, 3,4,2,32,32,255); break;
    case 5: fontHelper(pos, 255,6,6,7,7,5); break;
    case 6: fontHelper(pos, 0,6,6,3,7,5); break;
    case 7: fontHelper(pos, 1,1,2,32,0,32); break;
    case 8: fontHelper(pos, 0,6,2,3,7,5); break;
    case 9: fontHelper(pos, 0,6,2,32,32,255); break;
  custom(0, thousands);
  custom(1, hundreds);
  custom(2, tens);
etc.
now you should add code so that you only update a bigNumber when it has changed,
if (prevThousands != thousands)
  prevThousands  = thousands;
Awesome. This works great!
can you post an image?
Photo attached.
Cool!
