LCD Menu Help
I know menus have been done to death, but help a confused hobbyist?
I'm trying to make a 5-button (right, up, down, left, select) menu that looks something like this:
Main Menu >
Air Quality
Settings (target values to set temp/humidty)
AQ Monitor (temp, humidity, CO2 ppm)
Water Quality
Settings (target values to set pH, drain/fill interval)
WQ Monitor (temp, pH, dissolved O2 ppm, conductivity, time since drain)
Power
Generator
Generator Monitor (volts, amps)
Load
Load Monitor (volts, amps)
After hours upon hours of scouring online, I haven't been able to find a menu sketch that actually works. I did find a tutorial with a menu structure that I liked, as my menu needs to have a main menu with 3 submenus, submenus 1 & 2 containing two more submenus for setting variables and reading sensors, while submenu 3 has 2 for simply reading back sensor values.
This is the tutorial I've chosen to follow. A sample sketch is included with the tutorial and I tried loading it straight into my sketch, modifying the button values to match what analogRead(A0) was giving me for each button.
The buttons are in a resistor ladder with resistors and an LED connected for test purposes:
        Analog pin 5
Ground--1K--|--------|--------|-------|-------|
          LED      LED      LED     LED     LED
          btn1     btn2     btn3    btn4    btn5
        220 Ohm  470 Ohm     1K     2.2K    4.7K
           |--------|--------|-------|-------|-- +5V
In this configuration I get values of 394, 329, 264, 194, and 114 when I use Serial.print((analogRead(A0)). I took these values and substituted them into the code where appropriate. I changed the display from LiquidCrystal.h to LiquidCrystal_I2C.h, changing the appropriate initializations in void setup() to display an I2C LCD with address 0x27, a width of 20 and height of 4.
When I power on my Arduino Uno and upload the sketch, it boots up fine but the menu goes straight to
"sub menu 1", and only responds to button 3. Button three brings up a screen showing "item 1" and "item 2" but only as long as the button is pressed. The menu returns to "sub menu 1" after releasing the button.
I tried a few other menu sketch examples that I found on my Google quest and none seem to work. Does anyone know why this tutorial might not be working? If not, does anyone know of some menu sketches that work? I didn't think a menu would be this hard.
chuckt95:
So, the tutorial you've linked to does not represent the code in the Arduino. A good starting point is to post the code *as it exists *inside code tags.
It's a rather lengthy code, it has to be broken into two replies.
PART A:
    Name    : LCD Button Shield Menu
    Author  : Paul Siewert
    Created : June 14, 2016
    Last Modified: June 14, 2016
    Version : 1.0
    Notes   : This code is for use with an Arduino Uno and LCD/button shield. The
              intent is for anyone to use this program to give them a starting
              program with a fully functional menu with minimal modifications
              required by the user.
    License : This program is free software. You can redistribute it and/or modify
              it under the terms of the GNU General Public License as published by
              the Free Software Foundation, either version 3 of the License, or
              (at your option) any later version.
              This program is distributed in the hope that it will be useful,
              but WITHOUT ANY WARRANTY; without even the implied warranty of
              MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
              GNU General Public License for more details.
   This program is designed to get you as close as possible to a finished menu for the standard Arduino Uno LCD/button shield. The only required modifications
   are to add as menu items to the master menu (menuItems array) and then modify/adjust the void functions below for each of those selections.
// You can have up to 10 menu items in the menuItems[] array below without having to change the base programming at all. Name them however you'd like. Beyond 10 items, you will have to add additional "cases" in the switch/case
// section of the operateMainMenu() function below. You will also have to add additional void functions (i.e. menuItem11, menuItem12, etc.) to the program.
String menuItems[] = {"ITEM 1", "ITEM 2", "ITEM 3", "ITEM 4", "ITEM 5", "ITEM 6"};
// Navigation button variables
int readKey;
// Menu control variables
int menuPage = 0;
int maxMenuPages = round(((sizeof(menuItems) / sizeof(String)) / 2) + .5);
int cursorPosition = 0;
// Creates 3 custom characters for the menu display
byte downArrow[8] = {
  0b00100, //   *
  0b00100, //   *
  0b00100, //   *
  0b00100, //   *
  0b00100, //   *
  0b10101, // * * *
  0b01110, //  ***
  0b00100  //   *
byte upArrow[8] = {
  0b00100, //   *
  0b01110, //  ***
  0b10101, // * * *
  0b00100, //   *
  0b00100, //   *
  0b00100, //   *
  0b00100, //   *
  0b00100  //   *
byte menuCursor[8] = {
  B01000, //  *
  B00100, //   *
  B00010, //    *
  B00001, //     *
  B00010, //    *
  B00100, //   *
  B01000, //  *
  B00000  //
// Setting the LCD shields pins
LiquidCrystal_I2C lcd(0x27, 20, 4);
  // Initializes serial communication
  lcd.init(); //initialize the lcd
  lcd.backlight(); //open the backlight
  lcd.setCursor(5, 0);
  lcd.print("System");
  lcd.setCursor(0, 1);
  lcd.print("intitializing...");
  // Creates the byte for the 3 custom characters
  lcd.createChar(0, menuCursor);
  lcd.createChar(1, upArrow);
  lcd.createChar(2, downArrow);
  mainMenuDraw();
  drawCursor();
  operateMainMenu();
  Serial.println(analogRead(A0));
// This function will generate the 2 menu items that can fit on the screen. They will change as you scroll through your menu. Up and down arrows will indicate your current menu position.
void mainMenuDraw() {
  Serial.print(menuPage);
  lcd.clear();
  lcd.setCursor(1, 0);
  lcd.print(menuItems[menuPage]);
  lcd.setCursor(1, 1);
  lcd.print(menuItems[menuPage + 1]);
  if (menuPage == 0) {
    lcd.setCursor(15, 1);
    lcd.write(byte(2));
  } else if (menuPage > 0 and menuPage < maxMenuPages) {
    lcd.write(byte(2));
    lcd.setCursor(15, 0);
    lcd.write(byte(1));
  } else if (menuPage == maxMenuPages) {
    lcd.write(byte(1));
// When called, this function will erase the current cursor and redraw it based on the cursorPosition and menuPage variables.
void drawCursor() {
  for (int x = 0; x < 2; x++) {     // Erases current cursor
    lcd.setCursor(0, x);
    lcd.print(" ");
  // The menu is set up to be progressive (menuPage 0 = Item 1 & Item 2, menuPage 1 = Item 2 & Item 3, menuPage 2 = Item 3 & Item 4), so
  // in order to determine where the cursor should be you need to see if you are at an odd or even menu page and an odd or even cursor position.
  if (menuPage % 2 == 0) {
    if (cursorPosition % 2 == 0) {  // If the menu page is even and the cursor position is even that means the cursor should be on line 1
      lcd.setCursor(0, 0);
      lcd.write(byte(0));
    if (cursorPosition % 2 != 0) {  // If the menu page is even and the cursor position is odd that means the cursor should be on line 2
      lcd.write(byte(0));
  if (menuPage % 2 != 0) {
    if (cursorPosition % 2 == 0) {  // If the menu page is odd and the cursor position is even that means the cursor should be on line 2
      lcd.write(byte(0));
    if (cursorPosition % 2 != 0) {  // If the menu page is odd and the cursor position is odd that means the cursor should be on line 1
      lcd.write(byte(0));
void operateMainMenu() {
  int activeButton = 0;
  while (activeButton == 0) {
    int button;
    readKey = analogRead(0);
    if (readKey < 790) {
      delay(100);
    button = evaluateButton(readKey);
    switch (button) {
      case 0: // When button returns as 0 there is no action taken
      case 1:  // This case will execute if the "forward" button is pressed
        button = 0;
        switch (cursorPosition) { // The case that is selected here is dependent on which menu page you are on and where the cursor is.
          case 0:
            menuItem1();
          case 1:
            menuItem2();
          case 2:
            menuItem3();
          case 3:
            menuItem4();
          case 4:
            menuItem5();
          case 5:
            menuItem6();
          case 6:
            menuItem7();
          case 7:
            menuItem8();
          case 8:
            menuItem9();
          case 9:
            menuItem10();
        activeButton = 1;
        mainMenuDraw();
        drawCursor();
      case 2:
        button = 0;
          cursorPosition = cursorPosition - 1;
          cursorPosition = constrain(cursorPosition, 0, ((sizeof(menuItems) / sizeof(String)) - 1));
        if (menuPage % 2 == 0 and cursorPosition % 2 == 0) {
          menuPage = menuPage - 1;
          menuPage = constrain(menuPage, 0, maxMenuPages);
        if (menuPage % 2 != 0 and cursorPosition % 2 != 0) {
        mainMenuDraw();
        drawCursor();
        activeButton = 1;
      case 3:
        button = 0;
        if (menuPage % 2 == 0 and cursorPosition % 2 != 0) {
          menuPage = menuPage + 1;
        if (menuPage % 2 != 0 and cursorPosition % 2 == 0) {
        cursorPosition = cursorPosition + 1;
        mainMenuDraw();
        drawCursor();
        activeButton = 1;
PART B (this goes driectly under the last line of PART A):
// This function is called whenever a button press is evaluated. The LCD shield works by observing a voltage drop across the buttons all hooked up to A0.
int evaluateButton(int x) {
  int result = 0;
  if (x < 100) {
    result = 1; // right
  } else if (x < 180) {
    result = 2; // up
  } else if (x < 250) {
    result = 3; // down
  } else if (x < 320) {
    result = 4; // left
  Serial.println(x);
  return result;
// If there are common usage instructions on more than 1 of your menu items you can call this function from the sub
// menus to make things a little more simplified. If you don't have common instructions or verbage on multiple menus
// I would just delete this void. You must also delete the drawInstructions()function calls from your sub menu functions.
void drawInstructions() {
  lcd.setCursor(0, 1); // Set cursor to the bottom line
  lcd.print("Use ");
  lcd.print(byte(1)); // Up arrow
  lcd.print("/");
  lcd.print(byte(2)); // Down arrow
  lcd.print(" buttons");
void menuItem1() { // Function executes when you select the 1st item from main menu
  lcd.clear();
  lcd.setCursor(3, 0);
  lcd.print("Sub Menu 1");
    int button;
      delay(100);
    switch (button) {
      case 4:  // This case will execute if the "back" button is pressed
        button = 0;
        activeButton = 1;
void menuItem2() { // Function executes when you select the 2nd item from main menu
  lcd.clear();
  lcd.print("Sub Menu 2");
    int button;
      delay(100);
    switch (button) {
        button = 0;
        activeButton = 1;
void menuItem3() { // Function executes when you select the 3rd item from main menu
  lcd.clear();
  lcd.print("Sub Menu 3");
    int button;
      delay(100);
    switch (button) {
        button = 0;
        activeButton = 1;
void menuItem4() { // Function executes when you select the 4th item from main menu
  lcd.clear();
  lcd.print("Sub Menu 4");
    int button;
      delay(100);
    switch (button) {
        button = 0;
        activeButton = 1;
void menuItem5() { // Function executes when you select the 5th item from main menu
  lcd.clear();
  lcd.print("Sub Menu 5");
    int button;
      delay(100);
    switch (button) {
        button = 0;
        activeButton = 1;
void menuItem6() { // Function executes when you select the 6th item from main menu
  lcd.clear();
  lcd.print("Sub Menu 6");
    int button;
      delay(100);
    switch (button) {
        button = 0;
        activeButton = 1;
void menuItem7() { // Function executes when you select the 7th item from main menu
  lcd.clear();
  lcd.print("Sub Menu 7");
    int button;
      delay(100);
    switch (button) {
        button = 0;
        activeButton = 1;
void menuItem8() { // Function executes when you select the 8th item from main menu
  lcd.clear();
  lcd.print("Sub Menu 8");
    int button;
      delay(100);
    switch (button) {
        button = 0;
        activeButton = 1;
void menuItem9() { // Function executes when you select the 9th item from main menu
  lcd.clear();
  lcd.print("Sub Menu 9");
    int button;
      delay(100);
    switch (button) {
        button = 0;
        activeButton = 1;
void menuItem10() { // Function executes when you select the 10th item from main menu
  lcd.clear();
  lcd.print("Sub Menu 10");
    int button;
      delay(100);
    switch (button) {
        button = 0;
        activeButton = 1;
Depending on your display, this library may be useful GitHub - MajicDesigns/MD_Menu: Menu system for displays with up to 2 lines. Available from the library manage in the IDE as well.
You only need to change the data feeding the menu and it will run it for you. Make sure you read the documentation that is in the docs folder.
