setCursor 0, 0 print at beginning of line hello
setCursor 0, 1 print at beginning of line hello
setCursor 0, 2 print 4 positions down the line hello
setCursor 0 ,3 print 4 positions down the line hello
16x4 display. Why the spaces on line 3 and 4 ?
DaveX
October 9, 2024, 7:22pm
3
LCD.clear();
LCD.setCursor(0, 0);
LCD.print("Chiller ");
LCD.setCursor(9, 0);
LCD.print(temp1, 1);
LCD.setCursor(0, 1);
LCD.print("Freezer 1 " );
//LCD.setCursor (10, 1);
//LCD.print (temp1, 1);
LCD.setCursor(0, 2);
LCD.print("Freezer 2 " );
LCD.setCursor(10, 2);
LCD.println(temp3, 1);
LCD.setCursor(0, 3);
LCD.print("Freezer 3 " );
//LCD.setCursor (10, 30);
//LCD.println (temp4, 1);
sensor 2, 3 and 4 not connected and using LiquidCrystal_I2C
line 1 and 2 is fine but 3 and 4 start leading 4 spaces but cursor set to start at 0
could the lcd display be faulty? Even just a simple code to print hello world on line 3 from position 0 starts 4 spaces down the line. Could it be the library? Corrupt?
ec2021
October 9, 2024, 7:45pm
7
Read post #3 ...
(and probably also this link: https://forum.arduino.cc/t/problems-with-16x4-lcd-i2c-interface/480283/2 )
It looks as if the library you are using doesn't fit to the hardware ...
ec2021
October 9, 2024, 7:56pm
9
There is a "quick but dirty" solution in the link
lcd.setCursor(0, 0);
lcd.print("row one");
lcd.setCursor(0, 1);
lcd.print("row two");
lcd.setCursor(-4, 2);
lcd.print("row three");
lcd.setCursor(-4, 3);
lcd.print("row four");
Just to check if it's the different memory organisation of your lcd.
However, I highly recommend to check @DaveX 's post!
thanks..the -4 helps me out for now.
ec2021
October 9, 2024, 8:04pm
11
Oh my dear, I was afraid you'll say that ...
However. if you are interested in some background on LCD addressing issues:
https://web.alfredstate.edu/faculty/weimandn/lcd/lcd_addressing/lcd_addressing_index.html
Good luck (and better use the appropriate lib!)
ec2021
i will try hd44780. Great and fast support! THANK YOU
system
Closed
April 7, 2025, 8:06pm
13
