Lcd.print() won't work
Hi, I am having the problem that I can't print out a string variable using the lcd.
I never had a problem with this and the solution seems to be so simple, but I can't find it. I hope somebody has an idea.
Error Message in German: "Keine Instanz von Überladene Funktion "LiquidCrystal_I2C::print" stimmt mit der Argumentliste überein. -- Argumenttypen sind: (std::__cxx11::string) -- Der Objekttyp ist: LiquidCrystal_I2C",
->translated via google translate into English: No instance of Overloaded Function \ "LiquidCrystal_I2C :: print " matches the argument list. - Argument types are: (std :: __ cxx11 :: string) - The object type is: LiquidCrystal_I2C
Here is my Code:
#include string // isn't shown on this forum, so I wrote it without the two symbols
class Window
public:
string Line1;
string Line2;
void setLines(string line1, string line2) {
    Line1 = line1;
    Line2 = line2;
string getLines()
    return Line1 + Line2;
void printOnLcd()
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print(Line1); // HERE IS THE ERROR
  lcd.setCursor(0,1);
  lcd.print(Line2); //HERE IS THE ERROR
Try String (capital S).
This solved my issue! Many thanks. However, it also created another error: In the method getLines() the two Strings can't be added together anymore. Do you know how to do that? Thanks again for your very helpful answer!
SOLUTION: I wrote string again in front of the method, it should instead have been String
:joy:
