Is there a problem with this code? The LCD seems to turn on but nothing is displayed.
#include <Wire.h>
// I2C address for the LCD
#define LCD_ADDRESS 0x27 // Change this to your LCD's I2C address
// Constants
const int redLEDs[6] = {8, 9, 10, 11, 12, 13};
const int buttonPins[6] = {2, 3, 4, 5, 6, 7};
const int timeButton30 = A1; // Button to set game time to 30 seconds (using pin A6, not available on Uno, choose another)
const int timeButton60 = A2; // Button to set game time to 60 seconds (using pin A7, not available on Uno, choose another)
// Initialize the LCD with I2C address
LiquidCrystal_I2C lcd(LCD_ADDRESS, 16, 2); // Change 16x2 if your LCD is a different size
// Initialize Wire library for I2C
Wire.begin();
// Initialize LED pins
for (int i = 0; i < 6; i++) {
pinMode(redLEDs[i], OUTPUT);
digitalWrite(redLEDs[i], LOW);
// Initialize button pins
pinMode(buttonPins[i], INPUT_PULLUP);
// Initialize time control button pins
pinMode(timeButton30, INPUT_PULLUP);
pinMode(timeButton60, INPUT_PULLUP);
lcd.init();
lcd.backlight(); // Turn on the backlight
lcd.setCursor(0, 0);
lcd.print("Select Time:");
lcd.setCursor(0, 1);
lcd.print("30s or 60s");
// Wait for time selection
unsigned long gameTime = 30000; // Default 30 seconds
while (true) {
if (digitalRead(timeButton30) == LOW) {
gameTime = 30000;
if (digitalRead(timeButton60) == LOW) {
gameTime = 60000;
// Clear the LCD
lcd.clear();
// Display game time selection
lcd.print("Time Selected:");
lcd.print(gameTime / 1000);
lcd.print(" seconds");
// Wait for 2 seconds before starting
delay(2000);
// Initialize score
int score = 0;
// Initialize start time
unsigned long startTime = millis();
// Start game loop
while (millis() - startTime < gameTime) {
// Choose random LED
int ledIndex = random(6);
int ledPin = redLEDs[ledIndex];
// Light up red LED
digitalWrite(ledPin, HIGH);
// Wait for button press
int buttonPressed = -1;
unsigned long buttonStartTime = millis();
while (buttonPressed == -1 && millis() - buttonStartTime < 2000) {
if (digitalRead(buttonPins[i]) == LOW) {
buttonPressed = i;
// Check if button was pressed
if (buttonPressed == ledIndex) {
// Add point to score
score++;
} else if (buttonPressed != -1) {
// Deduct point for wrong button press
score--;
// Turn off red LED
digitalWrite(ledPin, LOW);
// Update score on LCD
lcd.clear();
lcd.print("Score:");
lcd.print(score);
lcd.print("Time:");
lcd.print((gameTime - (millis() - startTime)) / 1000);
lcd.print("s");
// Display final score
lcd.clear();
lcd.print("Final Score:");
lcd.print(score);
// Wait for 10 seconds before resetting
delay(10000);
// Reset LED states
// No need for any code here as the game logic is handled in setup()
