"Does anyone have an example of the LD2410S sensor with the Arduino R4 WiFi?"
It should be the same is a standard Arduino Uno, so this should work.
(I'm not sure of the language)
This might also help
An Arduino library for the Hi-Link LD2410 24Ghz FMCW radar sensor.
and
Discover comprehensive tutorials on how to use Cirkit Designer, detailed documentation for electronic components, and step-by-step guides for project design. Ideal for students, hobbyists, and developers looking to create and innovate in circuit...
Hope this helps!
Thank you for the help. My sensor is the LD2410S. The code in the video is for the LD2410B. I used the same sketch, it didn’t show any errors but returned the message “sensor not found.”
Hmmmmm. . . . .
I'll look into that
