LDR always gives same value ? #PROBLEM
Hey guys. First of all, my english is not good, forgive me if I type something wrong :roll_eyes:
Let me introduce my program as quickly as possible: There's a LDR and PIR sensor for automatic mode. I've a IR remote control and it will be the main control unit. I'm controlling the system with this remote control. There's 3 mode: ON - OFF - AUTOMATIC(SENSOR) MODE.
My problem is : last week I finished my automatic/remote controlled room lamp circuit/program. I decided to put all circuit in a deodorant bottle but it was too small and I gave up this idea and I decided to put this things in a bigger box.
After this process, a problem happened. When I re-check the program LDR gives me always the same value in serial monitor. This value is 14. I changed my arduino-cables-breadboard and even resistors.
By the way, when I unplug LDR, (I don't know "unplug" is the correct word?) program still gives this 14 value at serial monitor. Can you help me ? Thank you.
I'm using Arduino Pro Mini 5V 16MHz.
Here's my program
#include "IRremote.h"
#define segA 2//connecting segment A to PIN2
#define segB 3// connecting segment B to PIN3
#define segC 4// connecting segment C to PIN4
#define segD 5// connecting segment D to PIN5
#define segE 6// connecting segment E to PIN6
#define segF 7// connecting segment F to PIN7
#define segG 8// connecting segment G to PIN8
int LDR = A0;
byte sensor = 11;
byte bulb = 12;
int val = 0;
int val2 = 0;
int RCV_PIN = 10;
int buzzer = 13;
int COUNT=0;//count integer for 0-9 increment
IRrecv irrecv(RCV_PIN);
decode_results results;
  pinMode(sensor,INPUT);
  pinMode(bulb,OUTPUT);
  digitalWrite(bulb, HIGH); //rölenin baÅŸlangıç durumu
  irrecv.enableIRIn();
 for (int i=2;i<9;i++)
pinMode(i, OUTPUT);// taking all pins from 2-8 as output
void loop()  {
  val=analogRead(LDR);
  val = map(val,0,1024,0,100);
  Serial.println(LDR);
  delay(200);
  if (irrecv.decode(&results)) { // have we received an IR signal?
    irrecv.resume(); // receive the next value
    delay (500);
  if (results.value == 0xFFE21D) {
    digitalWrite(bulb,LOW);
    Serial.println("ANA KUMANDA: sistem acik");
  digitalWrite(segA, HIGH);
  digitalWrite(segB, HIGH);
  digitalWrite(segC, HIGH);
  digitalWrite(segD, HIGH);
  digitalWrite(segE, LOW);
  digitalWrite(segF, LOW);
  digitalWrite(segG, HIGH);
  if (results.value == 0xFFA25D){
    digitalWrite(bulb,HIGH);
    Serial.println("ANA KUMANDA: sistem kapali");
    digitalWrite(segA, LOW);
    digitalWrite(segD, LOW);
    digitalWrite(segG, LOW);
  if (results.value == 0xFF629D) {
    Serial.println("ANA KUMANDA: sistem otomatik modda");
     digitalWrite(segC, LOW);
     digitalWrite(segE, HIGH);
  if (results.value !=0xFF629D){
  if (digitalRead(sensor) == HIGH && val<=50 ) {
    Serial.println("Hareket belirlendi !");
  else if (digitalRead(sensor) == LOW || val>50 ){
Instead of this:-
perhaps you really meant this:-
  Serial.println(val);
Edit: Also, 'analogRead()' can only return values between 0 and 1023, so instead of this:-val = map(val,0,1024,0,100);you probably should really have this:-val = map(val,0,1023,0,100);
OldSteve:
Instead of this:-
Edit: Also, 'analogRead()' can only return values between 0 and 1023, so instead of this:-`val = map(val,0,1024,0,100);`you probably should really have this:-`val = map(val,0,1023,0,100);`
You are the best. It works again. Thank you so much !
ugurkirelli:
Glad I could help. :slight_smile:
Code: [Select]
With that mapping, you would only ever see 100% for an input of 1023.
map (i, 0, 1024, 0, 101) would give a better distribution.
AWOL:
Yeah, right. I can't argue. I remember seeing that once before, (and making a bit of a study of it), for mapping analogue read values to an 8-bit variable.:-
map (i, 0, 1024, 0, 256)
sp. i >>= 2;
AWOL:
sp. i >>= 2;
Yeah, that was the end result, or i/4 actually.
Is i>>=2 more code efficient than i/=4, or does it generate the same code?
My brain is going to declare its independence. What is the final situation ? lol
ugurkirelli:
Sorry for getting off-track. This is best:-map (i, 0, 1024, 0, 101)
OldSteve:
The compiler would hopefully use ">> 2" whichever you wrote.
AWOL:
Good. And thanks.
