LDR Problem (Do I need to Add Something Here)
Hello everyone,
I am working on a project where I am using four LDRs (Light Dependent Resistors) with an Arduino Uno and two servos. The goal is to move the servos based on the intensity of the light detected by each LDR.
However, I am having some trouble with the LDR function in my code. I have attached the code below for reference.
#include <Servo.h>
Servo servo1;
Servo servo2;
int ldr1 = A0;
int ldr2 = A1;
int ldr3 = A2;
int ldr4 = A3;
  servo1.attach(9);
  servo2.attach(10);
  int val1 = analogRead(ldr1);
  int val2 = analogRead(ldr2);
  int val3 = analogRead(ldr3);
  int val4 = analogRead(ldr4);
I would greatly appreciate it if someone could help me understand how can I modify the LDRs it to achieve my desired outcome.
Thank you in advance for your help!
Edit: the code is currently not doing anything with the LDR values.
Edit 2: I am using a phone to paste this code above.
Here is the wiring.
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the </> icon from the ‘posting menu’ to attach the copied sketch.
Always show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
Why have you have not attempted to move the servo ?
It would help us to help you if you would describe the trouble in more detail.
e.g. is it a white line follower, or a black line follower ? Or an ashes follower ?
What’s the orientation of the servos to the direction of travel ?
With these questions, you may be able to start on the code yourself.
Don’t try to get everything workng at once… get one sensor displaying the value in serial monitor, then maybe work on moving one servo with one sensor value.
What’s the relationship between the servos and the sensors?
Obviously. :wink:
Four LDRs, two servos...
Like this, without further details, excess LDRs, missing servos or missing data.
Be more explicit.
Hi, @accessduino
Are you making a solar tracker for a PV array?
The instructions above will show you how to post your code.
What problem are you having?
Does your code compile?
What Arduino controller are you using?
Can we please have a circuit diagram?
An image of a hand drawn schematic will be fine, include ALL power supplies, component names and pin labels.
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
I miss in setup
And in loop
Serial.println(val1);
Do you have pull-up or pulldown resistors on your LDR's?
What would that be exactly?
How are you connecting to the LDRs ? They don't generate electricity (the clue is in the name... the R stands for resistor) so usually they are used in a voltage divider circuit. Bit hard to say if they are connected correctly in your circuit, because you haven't showed us what that looks like.
I mean theres this thing I researched in the internet called value? It may have something to do with the LDR readings.
Lets say ldr1 and ldr3 are across from each other and ldr2 and ldr 4 are across from each other.
You'd read the value from ldr1 and ladr3, determine which ldr has more light, by its higher value, and torque the servo to a point where the light from ldr1 and ldr3 matches.
some base code I used to track the sun with solar cells.
   Project, use solar cells to generate power
   2/2/2020
// https://docs.espressif.com/projects/esp-idf/en/latest/api-reference/system/esp_timer.html
///esp_timer_get_time(void) //gets time in uSeconds like Arduino Micros. see above link
//////// http://www.iotsharing.com/2017/09/how-to-use-arduino-esp32-can-interface.html
#include "sdkconfig.h"
#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
// #include "esp32/ulp.h"
// #include "driver/rtc_io.h"
#include <SimpleKalmanFilter.h>
#include <driver/adc.h>
#include "esp_sleep.h"
#include "driver/mcpwm.h"
const int TaskCore1 = 1;
const int TaskCore0 = 0;
const int TaskStack20K = 20000;
const int Priority3 = 3;
const int Priority4 = 4;
const int SerialDataBits = 115200;
volatile bool EnableTracking = true;
  Serial.begin( 115200 );
  // https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
  // set up A:D channels
  log_i( "Setup A:D" );
  adc_power_on( );
  vTaskDelay( 1 );
  adc1_config_width(ADC_WIDTH_12Bit);
  // ADC1 channel 0 is GPIO36 (ESP32), GPIO1 (ESP32-S2)
  adc1_config_channel_atten(ADC1_CHANNEL_0 , ADC_ATTEN_DB_11); // azimuth 0
  //  // ADC1_CHANNEL_3  ADC1 channel 3 is GPIO39 (ESP32)
  adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11); // azimuth 1
  //  // ADC1 channel 5 is GPIO33
  adc1_config_channel_atten(ADC1_CHANNEL_5, ADC_ATTEN_DB_11); // altitude 1
  //  // ADC1 channel 6 is GPIO34
  adc1_config_channel_atten(ADC1_CHANNEL_6, ADC_ATTEN_DB_11); // altitude 0
  //  // adc for light dark detection, ADC1 channel 7 is GPIO35 (ESP32)
  adc1_config_channel_atten(ADC1_CHANNEL_7, ADC_ATTEN_DB_11);
  // adc for solar cell voltage detection, ADC1 channel 4 is GPIO33 (ESP32)
  adc1_config_channel_atten(ADC1_CHANNEL_4, ADC_ATTEN_DB_11);
  log_i( "A:D setup complete" );
  // control for relay to supply power to the servos
  pinMode( 5, OUTPUT );
  vTaskDelay(1);
  log_i( "setup MCPWM" );
  mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM1A, GPIO_NUM_4 ); // Azimuth
  mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, GPIO_NUM_12 ); // Altitude servo
  mcpwm_config_t pwm_config = {};
  pwm_config.frequency = 50;    //frequency = 50Hz, i.e. for every servo motor time period should be 20ms
  pwm_config.cmpr_a = 0;    //duty cycle of PWMxA = 0
  pwm_config.cmpr_b = 0;    //duty cycle of PWMxb = 0
  pwm_config.counter_mode = MCPWM_UP_COUNTER;
  pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
  log_i( "MCPWM complete" );
  mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config);    //Configure PWM0A timer 0 with above settings
  mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_1, &pwm_config);    //Configure PWM0A timer 1 with above settings
  fMoveAltitude( 1525 );
  fMoveAzimuth( 1500 );
 xTaskCreatePinnedToCore( TrackSun, "TrackSun", TaskStack20K, NULL, Priority3, NULL, TaskCore1 ); // assigned to core
xTaskCreatePinnedToCore( fDaylight, "fDaylight", TaskStack20K, NULL, Priority3, NULL, TaskCore0 ); // assigned to core
  ////  // esp_sleep_enable_timer_wakeup( (60000000 * 2) ); // set timer to wake up once a minute 60000000uS * 2
void fDaylight( void * pvParameters )
  int lightLevel = 0;
  log_i( "Start up fDaylight" );
  while (1)
    // sufficent voltage at the solar cells to do the thing?
    log_i( "Solar Cell: %d", adc1_get_raw(ADC1_CHANNEL_4) );
    if (adc1_get_raw(ADC1_CHANNEL_4) > 1600 )
      lightLevel = adc1_get_raw(ADC1_CHANNEL_7);
      if ( adc1_get_raw(ADC1_CHANNEL_7) >= 300 )
        log_i( "Light Level: %d", lightLevel );
        digitalWrite( 5, LOW ); // power to relay module/servos
        vTaskDelay( 1 );
        // if light level to low park boom
        fMoveAltitude( 1475 );
        fMoveAzimuth( 1900 );
        //     put esp32 into deep sleep
        digitalWrite( 5, HIGH ); // deenergize servo motors
        EnableTracking = false;
        esp_sleep_enable_timer_wakeup( (60000000 * 5) ); // set timer to wake up once a minute 60000000uS
        esp_deep_sleep_start();
    vTaskDelay( 1000 );
  } // while(1)
} // void fDaylight( void * pvParameters )
   @brief Use this function to calcute pulse width for per degree rotation
   @param  degree_of_rotation the angle in degree to which servo has to rotate
   @return
       - calculated pulse width
//static uint32_t servo_per_degree_init(uint32_t degree_of_rotation)
//  const int SERVO_MIN_PULSEWIDTH = 500; //Minimum pulse width in microsecond
//const int SERVO_MAX_PULSEWIDTH 2500 //Maximum pulse width in microsecond
//const int SERVO_MAX_DEGREE 180 //Maximum angle in degree upto which servo can rotate
//  uint32_t cal_pulsewidth = 0;
//  cal_pulsewidth = (SERVO_MIN_PULSEWIDTH + (((SERVO_MAX_PULSEWIDTH - SERVO_MIN_PULSEWIDTH) * (degree_of_rotation)) / (SERVO_MAX_DEGREE)));
//  return cal_pulsewidth;
void mcpwm_gpio_initialize(void)
// void TrackSun( int Altitude, int Azimuth )
void TrackSun( void * pvParameters )
  log_i( "Startup TrackSun" );
  int64_t EndTime = esp_timer_get_time();
  int64_t StartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros
  int Altitude = 1500;
  int Azimuth = 900;
  int maxAltitudeRange = 2144;
  int minAltitudeRange = 900;
  int maxAzimuthRange = 2144;
  int minAzimuthRange = 900;
  float AltitudeThreashold = 10.0f;
  float AzimuthThreashold = 10.0f;
  float kalmanThreshold = 80.0f;
  SimpleKalmanFilter kfAltitude0( AltitudeThreshold, kalmanThreshold, .01 ); // kalman filter Altitude 0
  SimpleKalmanFilter kfAltitude1( AltitudeThreshold, kalmanThreshold, .01 ); // kalman filter Altitude 1
  SimpleKalmanFilter kfAzimuth0( AzimuthThreshold, kalmanThreshold, .01 ); // kalman filter Azimuth 0
  SimpleKalmanFilter kfAzimuth1( AzimuthThreshold, kalmanThreshold, .01 ); // kalman filter Azimuth 1
  float filteredAltitude_0 = 0.0f;
  float filteredAltitude_1 = 0.0f;
  float filteredAzimuth_0 = 0.0f;
  float filteredAzimuth_1 = 0.0f;
  uint64_t AzimuthEndTime = esp_timer_get_time();
  uint64_t AzimuthStartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros,but rolls over after 207 years
  uint64_t AltitudeEndTime = esp_timer_get_time();
  uint64_t AltitudeStartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros,
  int StartupCount = 0;
  int TorqueAmmount = 5;
  while (1)
    if ( EnableTracking )
      //Altitude
      AltitudeEndTime = esp_timer_get_time() - AltitudeStartTime; // produce elapsed time for the simpleKalmanFilter
      kfAltitude0.setProcessNoise( float(AltitudeEndTime) / 1000000.0f );
      kfAltitude1.setProcessNoise( float(AltitudeEndTime) / 1000000.0f );
      // Serial.println( AltitudeEndTime,6 );
      filteredAltitude_0 = kfAltitude0.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_6) );
      filteredAltitude_1 = kfAltitude1.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_5) );
      //      Serial.print( filteredAltitude_0 );
      //      Serial.print( ", " );
      //      Serial.print( filteredAltitude_1 );
      //      Serial.println();
      if ( (filteredAltitude_0 > filteredAltitude_1) && (abs(filteredAltitude_0 - filteredAltitude_1) > AltitudeThreshold))
        Altitude -= TorqueAmmount;
        // log_i( "> Alt %d", Altitude );
        if ( Altitude < minAltitudeRange )
          Altitude = 900;
        fMoveAltitude( Altitude );
      if ( (filteredAltitude_0 < filteredAltitude_1) && (abs(filteredAltitude_0 - filteredAltitude_1) > AltitudeThreshold) )
        Altitude += TorqueAmmount;
        if ( Altitude >= maxAltitudeRange )
          Altitude = 900;
        // log_i( "< Alt %d", Altitude );
      //// AZIMUTH
      AzimuthEndTime = esp_timer_get_time() - AzimuthStartTime; // produce elasped time for the simpleKalmanFilter
      //      Serial.print( (float)adc1_get_raw(ADC1_CHANNEL_3) );
      //      Serial.print( "," );
      //      Serial.print( (float)adc1_get_raw(ADC1_CHANNEL_0) );
      kfAzimuth0.setProcessNoise( float(AzimuthEndTime) / 1000000.0f ); //convert time of process to uS, update SimpleKalmanFilter q
      kfAzimuth1.setProcessNoise( float(AzimuthEndTime) / 1000000.0f ); //convert time of process to uS, update SimpleKalmanFilter q
      filteredAzimuth_0 = kfAzimuth0.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_3) );
      filteredAzimuth_1 = kfAzimuth1.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_0) );
      //      Serial.print( filteredAzimuth_0 );
      //      Serial.print( filteredAzimuth_1 );
      if ( (filteredAzimuth_0 > filteredAzimuth_1) && (abs(filteredAzimuth_0 - filteredAzimuth_1)) > AzimuthThreashold )
        Azimuth += TorqueAmmount;
        if ( Azimuth >= maxAzimuthRange )
          Azimuth = 900;
        // log_i( "> Az %d", Azimuth );
        fMoveAzimuth( Azimuth );
      if ( (filteredAzimuth_0 < filteredAzimuth_1) && (abs(filteredAzimuth_1 - filteredAzimuth_0)) > AzimuthThreashold )
        // log_i( "< Az %d", Azimuth );
        Azimuth -= TorqueAmmount; // make new position to torque to
        if ( (Azimuth >= maxAzimuthRange) || (Azimuth <= minAzimuthRange) )
          Azimuth = 900;
      } //azmiuth end
      if ( StartupCount < 500 )
        ++StartupCount;
        TorqueAmmount = 1;
        // esp_sleep_enable_timer_wakeup( (60000000 / 30) ); // set timer to wake up
        // esp_sleep_enable_timer_wakeup( (60000000 / 20) ); // set timer to wake up
        // esp_light_sleep_start();
     vTaskDelay( 65 );
  } // while(1)
} //void TrackSun()
void fMoveAltitude( int MoveTo )
  mcpwm_set_duty_in_us(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_A, MoveTo);
  vTaskDelay( 12 );
void fMoveAzimuth( int MoveTo )
  mcpwm_set_duty_in_us(MCPWM_UNIT_0, MCPWM_TIMER_1, MCPWM_OPR_A, MoveTo);
  vTaskDelay( 12 );
void loop() {}
perhaps it will give a clue or not.
Hi, @accessduino
Please do not go back and edit old posts, if you have requested or new info, please post it in a new post.
Do you have code that JUST reads your LDRs?
Can ypu post a diagram of how you have your LDRs mounted so that they can detect the difference in sunlight?
So you are making a PV panel tracker?
Have you written your code in stages?
Thanks.. Tom..
Thanks for informing me, but i have found this information somewhere in the internet:
If the value of val1 (is less than the value of val2 (the reading from LDR2), then the position of servo1 is increased by 5 degrees. If val1 is greater than val2, then the position of servo1 is decreased by 5 degrees.
This is where I based my project in.
