Led- 2 pin -brightness of an LED- help
hello, I have no pwm pin, use it all.
I can also connect using two digital pins to control the brightness of an LED?
for a 5mm LED, one I put a 10k resitencia,
for another pin, falling to half brightness I put a 20K resistor,
this is good, as this resistance calculation?
int ledA = 7;
int ledB = 4;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(ledA, OUTPUT);
  pinMode(ledB, OUTPUT);
  digitalWrite(ledA, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(ledB, LOW);    // turn the LED off by making the voltage LOW
// the loop routine runs over and over again forever:
  for(int i=0;i<2;i++){
    if(i==0){
        digitalWrite(ledA, HIGH);   // turn the LED on (HIGH is the voltage level)
    }else{
      digitalWrite(ledB, HIGH);   // turn the LED on (HIGH is the voltage level)
    delay(1000);               // wait for a second
What you have done is make a very simple 2 bit digital to analog convertor. It should work, but instead of using digitalWrite (?, LOW); try pinMode(?, INPUT); and put pinmode(?, OUTPUT); before digitalWrite(?, HIGH);.
If you set one pin HIGH and the other LOW, some current will flow from one pin to the other instead of through the LED.
Paul
PaulRB:
Paul
I do not understand how to do what you mention
and using diodes?
Yes, those diodes should work.
However, you can do it without diodes like this:
int ledA = 7;
int ledB = 4;
  for(int i=0;i<4;i++){
    if(bitRead(i, 0) == 1){
    }else{
        pinMode(ledB, INPUT);
    if(bitRead(i, 1) == 1){
    }else{
        pinMode(ledA, INPUT);
This should give you three levels of brightness (plus off).
However, with 10K and 20K they will be very dim. Try 100R and 220R.
