We are stuck in our science project and we are in desperate need of your help! We need to be able to sequentially control eight LEDs using an Arduino Uno. The problem is we have no idea of how to write a suitable code. The LEDs are to be activated in intervals with specific time for on/off for each one. In the first sequence the LEDs must have a special timing unlike the following which will have the same. We have read about delay, loop and interrupt but are unsure of how to use them to fit our purpose.
I prefer not using delay() because that will interfere with other parts of your code that you may be waiting on. So with that in mind, I use millis(0 to determine whether something needs to happen or not. The following code will turn everything on in sequence, then turn everything off in sequence. You can adjust it to your specific application.
DISCLAIMER: this is untested code, which could contain errors. use at your own discretion.
int resetDone = 0; // Used to reset the full array of LEDs
int pauseInterval = 50; // how long to pause between each LED
long lastUpdate; // lastUpdate will get big rather fast
// Assume you're using 5 sequential pins (starting at 2) for your LEDs, let's set their output mode
for (int p = 2; p <= 7; p++) {
pinMode(p, OUTPUT);
void resetAll() {
digitalWrite(p, LOW);
resetDone = 1;
// I like to reset everything before starting up again
if (!resetDone) {
resetAll();
// p is also used as a counter down below
p = 2;
if (millis() - lastUpdate > pauseInterval) {
// anything in here will happen only if time elapsed is bigger than pauseInterval
digitalWrite(p, (digitalRead(p) == LOW ? HIGH : LOW));
lastUpdate = millis();
p++;
if (p > 7) {
p = 2; // Start over
If you need them to turn on, then off before moving on to the next LED, then change the time code if routine to turn on and off before incrementing the value of p.
