so I'm working on a project for my school making a radar and thermometer with Arduino. and the code is like this.
#include <Servo.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN 8
#define DHTTYPE DHT22
DHT_Unified dht(DHTPIN, DHTTYPE);
Servo servo_1;
int trig = 4;
int echo = 5;
int buzzpin = 13;
int buzzstate = LOW;
int ledr = 12;
int ledg = 11;
int ledstatus = 13;
unsigned long previousMillis = 0;
const long intervalFar = 250;
const long intervalClose = 50;
const long intervalIdle = 1250;
int servo_pin = 3;
int pos = 0;
int distance,duration;
Serial.println("Radar Start");
pinMode(ledr, OUTPUT);
pinMode(ledg, OUTPUT);
pinMode(buzzpin, OUTPUT);
servo_1.attach(servo_pin);
pinMode(trig, OUTPUT);
pinMode(echo, INPUT);
dht.begin();
// moving servo
for (pos = 0; pos <= 180; pos+= 1){ // arah kiri ke kanan
servo_1.write(pos);
delay(60);
dist_calc(pos);
for (pos = 180; pos >= 0; pos -= 1){ // arah kanan ke kiri
servo_1.write(pos);
delay(60);
dist_calc(pos);
float dist_calc(int pos){
//trigger HC-SR04 sensor
digitalWrite(trig, LOW);
delayMicroseconds(2);
digitalWrite(trig, HIGH);
delayMicroseconds(10);
duration = pulseIn(echo, HIGH);
distance = 100.0*(343.0*(duration/2.0))/1000000.0;
//led and buzzer
if (distance <= 200 && distance > 100){
if (currentMillis - previousMillis >= intervalFar){
if (buzzstate == LOW) {
buzzstate = HIGH;
buzzstate= LOW;
digitalWrite(buzzpin, buzzstate);
digitalWrite(ledr, buzzstate);
digitalWrite(ledg, LOW);
} else if (distance <= 100 && distance > 0) {
if (currentMillis - previousMillis >= intervalClose) {
if (buzzstate = LOW) {
buzzstate = HIGH;
buzzstate = LOW;
} else if (distance > 200){
digitalWrite(buzzpin, LOW);
digitalWrite(ledr, LOW);
digitalWrite(ledg, HIGH);
//DHT22 sensor
sensors_event_t event;
dht.temperature().getEvent(&event);
float temperature = event.temperature;
Serial.print(pos);
Serial.print(" , ");
Serial.println(distance);
if (isnan(event.temperature)) {
Serial.println ("Error");
}else {
Serial.print("Suhu: ");
Serial.println(temperature);
when I tested the DHT22 and HC-SR04 sensors there were no problems. but the problem appears with the LED and buzzer so when the object approaches a distance between 0 - 100 cm there is no reaction whatsoever. even though I set it to flash and make a sound quickly
