Hi, I have this code that takes the input from the serial monitor and turns on the led corresponding to the number entered. I have a few questions/improvements that I would like to make but I don't know how. Heres the code:
int pin;
for(pin = 2; pin <=10; pin++)
pinMode(pin, OUTPUT);
pinMode(13, OUTPUT);
if (Serial.available() > 0)
int LED = Serial.read() - 48;
digitalWrite(LED, HIGH);
delay(200);
if(digitalRead(2) && digitalRead(3) &&digitalRead(4) &&digitalRead(5) &&digitalRead(6) &&digitalRead(7) &&digitalRead(8) &&digitalRead(9) == HIGH)
int count;
for(count = 1; count <= 10; count++) //Blinks All LEDS 10 Times to alert
int LEDNumber;
for(LEDNumber = 1; LEDNumber <= 13; LEDNumber++)
digitalWrite(LEDNumber, HIGH);
delay(100);
digitalWrite(LEDNumber, LOW);
delay(100);
int Reds; //Turns all LEDS back on
for(Reds = 2; Reds <= 10; Reds++)
digitalWrite(Reds, HIGH);
Serial.print("All LEDs on. Turning off.");
Serial.println("");
int LEDoff;
for(LEDoff = 2; LEDoff <= 10; LEDoff++) //Turns all LEDS off
digitalWrite(LEDoff, LOW);
delay(100);
Serial.print("All LEDs are now off. Enter New Number to Continue.");
Serial.println("");
It currently works exactly how I want it to: When a number is entered in the serial monitor, it turns on the led connected to the corresponding pin. When all the pins 2-9 are on, it blinks all of them, turns them off and returns a message to the serial monitor. First, I would like to know how to receive multiple digit numbers from the serial monitor so I can use pins 10-13. When I currently type in a number such as 13, it attempts to turn on pin 1 then pin 13. Question 2 is why is it necessary for the -48 on the digital read line in the first part of void loop()? There is no logic behind it, it is just a pattern i noticed. When i type a number like 3 into the serial monitor, the arduino sees it as a value of 48 higher. Finally, how could i code it if I entered a number that was already on, the arduino would turn it off? For example if i entered 2 and 2 again, it would turn on then off.
Thanks for reading and hopefully you can shed some light on this ![]()
