LED blinking at same time instead of reciprocally
So I was starting with LED blink with arduino uno ,
First I blink using the pin 13 which worked fine then I decided to use PIN 12 as well, but when LED on 13 is lit, LED on 12 is off and vice versa , so I set the code like this below
int LED_YELLO_PIN = 13;
int LED_GREEN_PIN = 12;
  pinMode(LED_YELLO_PIN, OUTPUT);
  pinMode(LED_GREEN_PIN, OUTPUT);
  digitalWrite(LED_GREEN_PIN, HIGH);
  digitalWrite(LED_YELLO_PIN, LOW);
  digitalWrite(LED_YELLO_PIN, HIGH);
  digitalWrite(LED_GREEN_PIN, LOW);
and here are unexpected the result : - YouTube
How can I male these two LED blink reciprocally ?
got it working the wiring circuit was wrong earlier
