Led Blinks for 10 seconds than stays ON
Hi there,
I would like to make a LED blinking for 10 seconds, then, after the blinking cycle, it should stay ON.
The sketch below works but I'm sure there is a more elegant way, probably using constexpr uint8_t NumberOfBlinks {*}.
Could you please guys give me a hint?
Thanks a lot
const int ledPin = 14;
 pinMode(ledPin, OUTPUT);
   digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level)
   delay(1000); // wait for a second
   digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW
  void loop() {}
Look into the concept of a "for" loop.
Is this functionality of blink LED 10 seconds then LEd shall stay on (forever)
all that you want to do in this project?
or
Do you plan to make theLED do more than just this?
const byte ledPin = LED_BUILTIN;        // 13
byte On = LOW;
void setup ()
    pinMode (ledPin, OUTPUT);
    for (int n = 20; n > 0; n--)  {
        digitalWrite (ledPin, ! digitalRead (ledPin));
        delay (250);
    digitalWrite(ledPin, On);
void loop ()
It's just for that. I'll might use it for a project in the future.
Thanks a lot for the sketch.
It worked fine, I just replaced:
byte On = LOW;
with
byte On = HIGH;
so the LED stays on after the blinking cycle.
Much obliged!
hopefully you see that by defining what "On" is, instead of using LOW/HIGH makes things clear
