LED coding
This may be in the wrong area but can somebody tell me whats wrong with the code? I have it all set up right, however, when I upload it it tells me to add extra characters. When I add them it tells me there are more wrong ones. Can some one fix the line that is giving my trouble? Im still new to this.)
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);   // set the LED on
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // set the LED off
  pinMode(12, OUTPUT);
  digitalWrite(12, HIGH);   // set the LED on
  digitalWrite(12, LOW);    // set the LED off
  pinMode(11, OUTPUT);
  digitalWrite(11, HIGH);   // set the LED on
  digitalWrite(11, LOW);    // set the LED off
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);   // set the LED on
  digitalWrite(10, LOW);    // set the LED off
// LED leads connected to PWM pins
const int RED_LED_PIN = 9;
const int GREEN_LED_PIN = 8;
const int BLUE_LED_PIN = 7;
// Used to store the current intensity level of the individual LEDs
int redIntensity = 0;
int greenIntensity = 0;
int blueIntensity = 0;
// Length of time we spend showing each color
const int DISPLAY_TIME = 100; // In milliseconds
  // Cycle color from red through to green
  // (In this loop we move from 100% red, 0% green to 0% red, 100% green)
  for (greenIntensity = 0; greenIntensity <= 255; greenIntensity+=5) {
        redIntensity = 255-greenIntensity;
        analogWrite(GREEN_LED_PIN, greenIntensity);
        analogWrite(RED_LED_PIN, redIntensity);
        delay(DISPLAY_TIME);5
  // Cycle color from green through to blue
  // (In this loop we move from 100% green, 0% blue to 0% green, 100% blue)
;for blueIntensity = 0; blueIntensity <= 255; blueIntensity+=5)
        greenIntensity = 255-blueIntensity;
        analogWrite(BLUE_LED_PIN, blueIntensity);
  // Cycle cycle from blue through to red
  // (In this loop we move from 100% blue, 0% red to 0% blue, 100% red)
  for (redIntensity = 0; redIntensity <= 255; redIntensity+=5)
        blueIntensity = 255-redIntensity;
The line
should be
for (blueIntensity = 0; blueIntensity <= 255; blueIntensity +=5){
You added number 5s after some semi-colons for some reason, which will stop it working. Deleting the 5s and sorting out the for loop, we have:
Which compiles fine.
Onions.
Thanks you!
You haven't posted it in a code box. Modify the original post:-
Select the code and hit the # icon, then click save.
Also noticed, you might want to put
from loop into setup. If you want to flash each LED colour on before you start mixing colours, I'd put this into setup:
and this into the start of loop:
Or you could turn it into a flash function:
void flash(int pin){
  digitalWrite(pin, HIGH);
  digitalWrite(pin, LOW);
Then call the function at the start of loop
flash(12);
flash(11);
flash(10);
Just some ideas.
Onions.
