LED Control System Using Arduino: Potentiometer and Push Buttons
Hi everyone,
I’ve been trying to complete an Arduino project in Tinkercad where I need to do this Arduino activity, it requires building a circuit with the following components:
  • 5 or 6 red LEDs
  • 5 or 6 resistors (150Ω or similar)
  • 1 potentiometer
  • 3 push buttons
  • 3 resistors (10kΩ)
  • 1 protoboard
  • 1 Arduino UNO
Main Tasks:
  1. Potentiometer Control:
  • When the potentiometer is at the initial position (far left), all LEDs must be off.
  • At the final position (far right), all LEDs must be on.
  • At intermediate positions, only some LEDs should light up (e.g., halfway lights up LEDs 1, 2, and 3).
  1. LED Blinking Sequence:
  • The LEDs must turn on and off in sequence every 500 ms. For example:
    • LED 1 turns on, then after 500 ms LED 2 turns on, then after 500 ms LED 3 turns on.
    • After all are on, they turn off after 500 ms, and the cycle repeats indefinitely.
  1. Brightness Adjustment
  • Add 3 push buttons to control LED brightness:
    • Button 1 (KEY1): Minimum brightness.
    • Button 2 (KEY2): Half brightness.
    • Button 3 (KEY3): Maximum brightness (default if no button is pressed).
  • Use Arduino’s PWM functions (analogWrite and map) for brightness control.
I managed to get the potentiometer part working, but the brightness control isn’t responding .
int LED1 = 3;
int LED2 = 5;
int LED3 = 6;
int LED4 = 9;
int LED5 = 10;
int LED6 = 11;
int Botao1 = 2;
int Botao2 = 7;
int Botao3 = 8;
int pwm = 255;
  pinMode(A0, INPUT);
  pinMode(Botao1, INPUT_PULLUP);
  pinMode(Botao2, INPUT_PULLUP);
  pinMode(Botao3, INPUT_PULLUP);
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(LED4, OUTPUT);
  pinMode(LED5, OUTPUT);
  pinMode(LED6, OUTPUT);
  if (digitalRead(Botao1) == LOW) {
    pwm = 50;
  if (digitalRead(Botao2) == LOW) {
    pwm = 150;
  if (digitalRead(Botao3) == LOW) {
    pwm = 255;
  pot = analogRead(A0);
  if (pot >= 900) {
    piscaLEDs(6);
  } else if (pot >= 760) {
    piscaLEDs(5);
  } else if (pot >= 590) {
    piscaLEDs(4);
  } else if (pot >= 420) {
    piscaLEDs(3);
  } else if (pot >= 240) {
    piscaLEDs(2);
  } else if (pot >= 70) {
    piscaLEDs(1);
    apagaTodosLEDs();
void piscaLEDs(int quantidade) {
  int leds[] = {LED1, LED2, LED3, LED4, LED5, LED6};
  for (int i = 0; i < quantidade; i++) {
    analogWrite(leds[i], pwm);
  for (int i = quantidade - 1; i >= 0; i--) {
    digitalWrite(leds[i], LOW);
void apagaTodosLEDs() {
  for (int i = 0; i < 6; i++) {
This is the circuit I put together in tinkercad, I'm not sure if all the connections are correct. I need help, I'm really new to this and I don't really know what I'm doing, so if someone could help me and explain what's going wrong, it would help me a lot.
What is it doing instead?
absolutely nothing
I'm sorry, but I don't understand. You'll have to be more precise.
Are the LEDs coming on? Are they not coming on? Are they the wrong brightness? What?
where did you place the 10K resistors? Change your code to print which button is pressed. For debugging also place a delay(2000) in the loop so you do not flood the serial channel. When the buttons are working let us know. Also if you do not have a multimeter you need to get one, even a $5 one would work.
Listening to your teacher while in school saves you a lot of time, difficulty, and money.
Your project has:
The LEDs work, counting from zero to their maximum. The potentiometer changes the maximum. The buttons should be changing the brightness of the LEDs.
When do you have to present the programme at school?
The wiring is wrong. The push button switches should be placed across the central barrier on the bread board.
Then they should be wired across one diagonal. That is with ground where it is, and the input pin to the Arduino diagonally across from this.
The black wire carrying the ground to the Arduino on pin 24 of the Arduino is obscured by the blue wires so it is hard to see where it goes. Move it away from the blue wires so that you don't hide it.
The smart thing to do would be to define this as a global variable, just before the setup function, so you would not have to build this array every time you ran the piscaLEDs function.
where is the ground connection to your breadboard?
pot is undefined, needs to be
    int pot = analogRead(A0);
would be cleaner to define your LEDs as
const byte PinLeds [] = { 4, 5, 6, 9, 10, 11 }
const int Nleds       = sizeof(PinLeds);
and elsewhere do
    for (int i = 0; i < Nleds; i++)
        pinMode (PinLeds [i], OUTPUT);
        analogWrite (PinLeds [i], pwm);
        delay (500);
        digitalWrite (PinLeds [i], LOW);
What's happening is that the buttons, when pressed, don't change the LED brightness, I've fixed what you said about the programming
The process of the LEDs turning on and flashing, and the potentiometer, is working, I'm having trouble with the buttons, which when pressed don't change the brightness of the LEDs, and I can't check if these buttons are working even in the simulator
Print the PWM values to the Serial Monitor.
In two weeks
when I copied the code it didn't take the int pot, so it looks like I didn't declare it but it was the first thing I did in the code
int pot = 0;
int LED1 = 3;
int LED2 = 5;
int LED3 = 6;
int LED4 = 9;
int LED5 = 10;
int LED6 = 11;
int Botao1 = 2;
int Botao2 = 7;
int Botao3 = 8;
int pwm = 255;
  pinMode(A0, INPUT);
    pwm = 50;
    pwm = 150;
    pwm = 255;
  if (pot >= 900) {
    piscaLEDs(6);
    piscaLEDs(5);
    piscaLEDs(4);
    piscaLEDs(3);
    piscaLEDs(2);
    piscaLEDs(1);
    apagaTodosLEDs();
This is a newer version of the code, same problem, buttons are not changing the brightness of the leds
int pot = 0;
int LED1 = 3;
int LED2 = 5;
int LED3 = 6;
int LED4 = 9;
int LED5 = 10;
int LED6 = 11;
int Botao1 = 2;
int Botao2 = 7;
int Botao3 = 8;
int pwm = 255;
int ledcount = 6;
  pinMode(A0, INPUT);
  for(int led = 0; led < ledcount; led++){
    pinMode(leds[led], OUTPUT);
  if (pot >= 900) {
    piscaLEDs(6);
    piscaLEDs(5);
    piscaLEDs(4);
    piscaLEDs(3);
    piscaLEDs(2);
    piscaLEDs(1);
    apagaTodosLEDs();
    verificaButoes;
void verificaButoes(){
    pwm = 50;
    pwm = 150;
    pwm = 255;
    verificaButoes;
  • OP, as is, tell us what you think this line does ?
    verificaButoes; // <——<<<
when I set it to check the buttons, they all appear as pressed, without me having pressed any of them
  • Do you see the difference ?
verificaButoes;
versus
verificaButoes();
Yes, I'm sorry, I just fixed that, but still not working
int pot = 0;
int LED1 = 3;
int LED2 = 5;
int LED3 = 6;
int LED4 = 9;
int LED5 = 10;
int LED6 = 11;
int Botao1 = 2;
int Botao2 = 7;
int Botao3 = 8;
int pwm = 255;
int ledcount = 6;
  pinMode(A0, INPUT);
  if (pot >= 900) {
    piscaLEDs(6);
    piscaLEDs(5);
    piscaLEDs(4);
    piscaLEDs(3);
    piscaLEDs(2);
    piscaLEDs(1);
    apagaTodosLEDs();
    verificaButoes();
    pwm = 50;
    pwm = 150;
    pwm = 255;
