Led cube 8x8x8
Hello to you all.
I could use some help.
I Just started a 8x8x8 led cube with arduino.
I searched the internet for a schematic.
I found one as shown in the attachments but i am not sure if i, am going the right way.
So i draw a schematic and i hope it is ok.
OR i hope someone can direct me the right way.
The part i draw is what i, am not sure of.
Best regards.
My worries are with the capacitators.
There are multiple component in need of capacitators.
At this point in my drawing the are all connect inline.
Is that ok or is that trouble.
And what about the voltage of the capacitators.
Do they all need to have the same voltage because the 0.1uf i only can find max 50v.
0.1uF caps rated for 25V, 50V, 100V will all be fine.
Locate one near the 5V pin of each logic chip, adjacent to it when possible, and connect the other end to the nearest Gnd.
Thank for your replay.
I can place them close to the chips no probleem.
I know that they need to be bridged between 5v and grond.
Also there are 3 caps in parallel.
1x1000 1x100 1x10 uf.
Are they for the hole circuit So i can put the where the 5v enters my circuit.
So finaly the 0.1uf caps are also connected to them.
OR do they only need to be connected for de led's.
In short terms is my drawing result in fire or is it ok.
