Need review of electrical schematic
Is there any reason this would not work?
I"m trying to run high power leds, and control their brightness through three pins off an esp32. I'm not an electrical engineer or a coder. Have no idea what i'm doing, just using my research and common sense to put this together. Thanks for any help.
After reading one of the comments, I made some changes to the schematic. This is just my way of visualizing what i want to get done.
Ultimately, I want all the drivers and the controls on one PCB and i'm trying to keep it small.
cb8f7c83-71ea-46d5-90e0-5b9e5decf134.pdf (59.3 KB)
Sorry to say, but your schematic is full of flaws.
You cannot make a stable voltage with a resistor divider.
Your led driver connection is unclear and probably wrong.
How will you derive 3 different voltages from 48V to your led drivers?
What is this schematic supposed to accomplish?
Could you redraw your schematic with gnd at the bottom? And without ambiguous connections to your driver ic's?
Your 20 ohm resistor will dissippate more than 20W. It will let out the magic smoke soon. And it is pretty wastefull...
What purpose does the 20V line serve?
For one, the max input voltage of the NLDD-1400 is 46V, not 52V. See the datasheet.
So you need a different driver.
No voltage dividers to power stuff! Get a buck converter, and only one. It can power both your MCU and RTC.
How come it's 48 V btw?
I doubt that the NLDD-1400 will be happy with driving two or three 1.4A LEDs from a 48volt supply. Efficiency goes down with supply/LED voltage difference. Your driver will likely become very hot with only two LEDs in series.
Leo..
Yeah, I noticed that this morning and made a change on the driver.
Yeah, didn't notice that before, I changed the driver to one that's outputs a min of 2v to hopefully help.
aren't buck converters large? almost the same size as a Driver?
I actually changed it to 54V, becuase I'm powering 48V's worth of LED's potentially plus powering an MCU and a Display.
Can't read any of the small text in your schematic.
Make the text bigger and export to a pdf.
Looks like you are still trying to get lower voltages by using resistors.
This makes no sense, your longest string of LEDs is about 18V
Your comments around the circuit make no sense, especially the one about 'voltage draw'. Voltage is the difference in potential between 2 points, current is drawn.
I suspect you need to understand Kirchoff's circuit laws.
You're probably right about that.
In my head, I'm using constant current drivers where the current stays the same and they get brighter by adding voltage. I assumed I needed enough voltage to supply all three strings of LED's at their brightest which would be 48v's. plus add in voltage from the MCU and the Display.
I'll take a look at what you posted. Thank you!
No. Voltage (and current) to the LEDs stays constant, and about 3.3volt (1Amp) per LED. PWM turns the LEDs fully ON/OFF at a high rate, and the PWM ratio changes perceived brightness.
Can't you use more LEDs and drivers with a lower current.
That would improve efficiency and heat dissipation, while the light output stays the same.
You should be using strings of 12 LEDs with an 48volt supply.
Leo..
I don't know what size your driver is, but I'd say they are small:
Buck converter 9-72 V in 5 V out
Length: 11.68 mm (0.46 in)
Width: 7.5 mm (0.295 in)
Height: 10.16 mm (0.4 in)
It's through hole so solder to a PCB is preferred, or second choice, wires.
I'm 100% sure you can get it cheaper elsewhere, Mouser isn't about low prices.
What happened to that RTC? Why's the battery still there?
Edit: Added a quote from you at top
You get what you pay for. Mouser doesn't sell fakes or knockoffs. They are an authorized parts distributor for thousands od manufacturers. The Forum is full of people with problems with junk from Amazon, alibaba, aliexpress and the like.
What are U4, U5 and U7?
What are the two rectangles at the top?
What are the part numbers of the drivers?
What is the part number for the LEDs?
EasyEDA does not export very good images.
In principle, it looks like you are attempting to drive 3 groups of high power Leds using an ESP32-C6 (XIAO) and some ancilliary components. At least from the mixture of voltages you have indicated you are doing this in a very unconventional way.
Why not start by showing a link to the data sheet for the leds and say what the application is so the readers here can understand why you have chosen to group 6 and 3 and 2 leds. If you do that, you will almost certainly start a discussion about how best to structure the circuit and dimension the power supply (-ies) to achieve your goal in a way which is more likely to end in a successful result.
Makes you wonder how much time is spent by the users themselves and others trying to help with something faulty.
-- But it was cheap?
-- Yeah, and it came with a big package of frustration too
:raising_hand_man: Here's one right here. Digikey for me
Each string of LEDs needs enough voltage for that particular string. As the strings are not in series with each other the voltage for one does not add to the voltage for another. For voltage to add things have to be in series with each other. Kirchoff's voltage law makes this clear. In my opinion if you understand Ohm's and Kirchoff's laws then you will find that much of electronics makes sense.
