hello,i am a newcomer to the world of arduino,i have been through the beginners guide and done the blink,chasers,matrix etc and decided to try a 3x3x3 led cube which is working fine with some code i found on the net.
the building and wiring seems simple enough,when i looked through the code i thought i would be able to change a few things to change the patterns but its a lot more complicated than i thought so i would like to know if there are any good easy tutorials you could recommend
#include <LedCube.h>
byte levelPins[] = {11,12,13};
byte colPins[] = {2,3,4,5,6,7,8,9,10};
LedCube cube(3, levelPins, colPins);
void setup ()
void loop ()
delay(100);
cube.enableBuffer(false);
// light one level at a time, increasing speed each time
for(byte t=25; t>2; t-=2)
for(byte l=0; l<cube.getNumLevels(); l++){
cube.lightLevel(l,t);
cube.lightLevel(1, t);
// single random light at a time
cube.randomLight(random(25,100),100);
// random column drop
for(byte x=0; x<=15; x++) {
cube.lightDrop(random(0,cube.getNumCols()), random(50,200));
// circle around cube at a random level
for(byte x=0; x<=5; x++) {
cube.lightPerimeter(random(0,cube.getNumLevels()), random(1,5), random(25,100));
// random columns
cube.randomColumn(25);
// turn off a single column randomly
cube.enableBuffer();
for(byte c=0; c<20; c++)
cube.fillBuffer();
cube.invertBuffer();
cube.randomColumn();
cube.drawBuffer(12);
cube.invertBuffer(false);
// cols in and out
for(byte c=1, d=0; c<=36; c++)
if(c%2 == 0){
for(d=0; d<20; d++) {
cube.lightColumn(2,1);
cube.lightColumn(4,1);
cube.lightColumn(6,1);
cube.lightColumn(8,1);
} else if(c%4 == 1) {
for(d=0; d<30; d++) {
cube.lightColumn(1,1);
cube.lightColumn(3,1);
cube.lightColumn(7,1);
cube.lightColumn(9,1);
for(d=0; d<70; d++) {
cube.lightColumn(5,1);
// diamond and box
byte diamond[] = {0,4, 1,1, 1,3, 1,4, 1,5, 1,7, 2,4};
byte box[] = {0,0, 0,1, 0,2, 0,3, 0,5, 0,6, 0,7, 0,8, 1,0, 1,2, 1,6, 1,8, 2,0, 2,1, 2,2, 2,3, 2,5, 2,6, 2,7, 2,8};
cube.lightSequence(box, sizeof(box), 200);
cube.lightSequence(diamond, sizeof(diamond), 400);
// remaining effects use the buffer
// pyramids
cube.fillBuffer();
cube.lightPerimeter(0);
byte corners[] = {1,0, 1,2, 1,6, 1,8};
cube.lightSequence(corners, sizeof(corners));
cube.drawBuffer(100);
cube.lightPerimeter(2);
// helicopter effect
byte topSeq[8] = {0,3,6,7,8,5,2,1};
byte midSeq[8] = {5,8,7,6,3,0,1,2};
byte botSeq[8] = {8,5,2,1,0,3,6,7};
for(byte q = 0; q<3; q++){
for(byte r = 0; r<7; r++){
for(byte s= 0; s<8; s++){
cube.clearBuffer();
cube.lightOn(0,botSeq~~);~~
cube.lightOn(1,midSeq~~);
cube.lightOn(2,topSeq);
cube.drawBuffer(100/(r+1));
~~ // turn off one light at a time~~
~~ cube.fillBuffer();
cube.drawBuffer(25);
for(byte w=0, l, c; w<27; ){
l = random(0,cube.getNumLevels());
c = random(0,cube.getNumCols());
if(cube.getBufferAt(l,c)){
cube.lightOff(l,c);
cube.drawBuffer(15+w*2);
w++;
is there anything i could change in this code to change patterns
TONY
