LED fade arduino code not working with state change detection
my arduino code for a state change detection with a led fade code at end isn't working. I inserted a LED fade code at end of state change and changed the led pin input but the code comes up with a error message and i don't know what is wrong with the code.
here is the code:
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 11; // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button went from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
// if the current state is LOW then the button went from on to off:
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state, for next time through the loop
lastButtonState = buttonState;
// turns on the LED every four button pushes by checking the modulo of the
// button push counter. the modulo function gives you the remainder of the
// division of two numbers:
if (buttonPushCounter % 3 == 0) {
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
if (buttonPushCounter % 6 == 0) {
int led = 11; // the PWM pin the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
// the setup routine runs once when you press reset:
// declare pin 11 to be an output:
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
// set the brightness of pin 11:
analogWrite(led, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness <= 0 || brightness >= 255) {
fadeAmount = -fadeAmount;
// wait for 30 milliseconds to see the dimming effect
delay(30);
Please read the sticky post at the top of the forum to learn how to properly post your code using code tags. Then, go back and edit your post and insert the code tags. It is also helpful to post your error message, not an image of it.
With that being set, you can not have two setup() functions and two loop() functions. Combining two sketches together requires combining everything in both the setup() functions an the same for loop()
    delay(50);
  delay(30);
blh64:
how would I combine the LED void setup with the state change detection?
An Arduino Sketch MUST have only one setup() function and only one loop() function. Please read Arduino Sketch Structure
