LED Light control PIR Motion sensor
Hi guys,
Currently, I am doing a mini project whereby I am using a PIR Motion control to control the state of my LED.
this is the PIR Motion sensor I am using : PIR motion sensor
How the program supposed to work is as follows: when a person passes by the motion sensor, the LED would turn on at 50% brightness the first two times. On the third pass by, the LED would turn on to max brightness. However, if during the first two times when the LED in on, after about 10seconds if there is no third output by the PIR Sensor, the LED would turn off.
int pir1 = 12;
int led3 = 5;
unsigned long ToppreviousMillis = 0;
unsigned long TopcurrentMillis;
  pinMode(pir1, INPUT);
  pinMode(led3, OUTPUT);
  ToppreviousMillis = millis();
  if (motiondetected()) { //if the PIR is detecting motion
    analogWrite (led3, 50);  //turn the light on
    Serial.println("motion detected 1");
    if (ToppreviousMillis > TopcurrentMillis + 10000) // if variable time is greater than variable time + 20 seconds
      analogWrite (led3, 0);  //turn the light back off
      analogWrite(led3, 50);
      Serial.println("motion detected 2");
      analogWrite(led3, 255);
        Serial.println("motion detected last");
bool motiondetected() {
  if (digitalRead(pir1) == HIGH) {
    TopcurrentMillis = millis();
    return true;
    return false;
However, my PIR Sensor would output HIGH several times for about 2seconds causing my if loops to activate over and over again. Could someone advice me on what's wrong with my code and point me in the right direction?
Thank you!
there are many ways to do a thing.
this is the first that comes to mind.
if motion, turn on 50%
count times of more motion
run time out to 10 seconds
if more motion = 0 turn off
if more motion = 1 reset to count for another 10 second
if more motion = 2 go high
time out to 10 seconds would be using blink without delay
