Hello. I am using an Arduino Nano (Old Bootloader) along with a MAX7219 led array. For the matrix I use a library called MaxMatrix, this one in particular. I also want to use an LCD display via I2C, using LiquidCrystal_I2C.
The problem is that for some reason these two libraries conflict (by including them together in the code, the array of leds is not initialized correctly). I have found that what produces it is Wire (Wire.h) implicit in LiquidCrystal_I2C.
I don't understand why this happens. Somebody could help me? Thank you!
Please show your complete code and a schematic of your circuitry, including precise model numbers for both the LED array (i suppose you already provided that) and the LCD display.
It should not happen, unless you use too much SRAM (dynamic memory).
There are many ways in which two libraries could conflict, e. g. through I2C address conflicts, or through hard waits (delay()) in one library messing up the timing of the other one. It is also possible OP just made a mistake in their own code. Telling someone who is experiencing a bug that "it should not happen" is entirely useless.
Very improbable, but without any circuit (or code) details, we will never know, will we? ![]()
I would disagree with that. It tells the beginner that what he is trying to do is a valid thing, therefore he has to look for problems with his code. In order to understand code on an embedded system you also need to know the schematic.
Perhaps I should have written it as: "Hmmmm, sniff, sniff, I smell a memory problem" ![]()
My matrix of leds is this. The screen, this (along with an I2C control).
My complete code (although quite long) is this:
#include <Arduino.h>
#include <MaxMatrix.h>
#include <avdweb_VirtualDelay.h>
#include <avr/pgmspace.h>
#include <OneButton.h>
#include <EasyBuzzer.h>
#include <rtttl.h>
// PINs definitions
#define CYLINDER_1_DIN 4
#define CYLINDER_1_CS 5
#define CYLINDER_1_CLK 6
#define CYLINDER_2_DIN 7
#define CYLINDER_2_CS 8
#define CYLINDER_2_CLK 9
#define CYLINDER_3_DIN 15
#define CYLINDER_3_CS 14
#define CYLINDER_3_CLK 16
// set LCD to I2C pins. Arduino Leonardo Mini (Pro Micro) is 2: SDA, 3: SCL
#define SPEAKER 10
#define BUTTON_START A1
#define BUTTON_BET 0
#define LED_START A0
#define LED_BET A2
#define COIN_INSERTER 1
#define SERVO_DOOR A3
#define ADC_SEED_PIN A4 // this pin is on Pro Micro not listed on pins, but it is on the chip itself
// Symbol definitions
PROGMEM const unsigned char CH[] = {
8, 8, B00000110, B01101111, B11110110, B01100100, B00100100, B00101000, B00110000, B00100000, // 0: cherry
8, 8, B00000000, B00111100, B01111110, B11111101, B01100010, B00111100, B00000000, B00000000, // 1: lemon
8, 8, B00111100, B01111110, B11111111, B11111111, B11111101, B11111101, B01100010, B00111100, // 2: orange
8, 8, B00000000, B00011110, B01111111, B11111101, B11111010, B11100100, B01111000, B00000000, // 3: plum
8, 8, B00011000, B11111111, B01111010, B01111010, B01111010, B01111010, B00110100, B00011000, // 4: bell
8, 8, B00011000, B00111100, B00111100, B01111110, B01111110, B00011000, B00010000, B00100000, // 5: grape
8, 8, B00011100, B00111110, B01111101, B11111010, B11110100, B11101000, B01010000, B00100000, // 6: melon
8, 8, B00011000, B00011000, B00011000, B00011000, B00110000, B01100000, B01111110, B01111110, // 7: seven
8, 8, B01000010, B00100100, B00011000, B00111100, B11111111, B00011000, B00010000, B00010000, // 8: star
8, 8, B00111100, B01000010, B10011001, B10100101, B10000001, B10100101, B01000010, B00111100, // 9: joker
// Symbols pay value (0 to 9), for bets x1
int symbolValue[10] = {3, 3, 5, 5, 10, 20, 30, 40, 75, 75};
// Cylinder definitions
int cylinderSymbols1[24] = {8, 5, 5, 9, 1, 0, 1, 7, 3, 3, 3, 2, 2, 2, 0, 0, 0, 4, 4, 4, 6, 1, 1, 1};
int cylinderSymbols2[24] = {8, 4, 4, 0, 0, 0, 9, 1, 6, 6, 1, 1, 1, 7, 1, 1, 2, 2, 2, 3, 5, 3, 3, 3};
int cylinderSymbols3[24] = {8, 2, 2, 2, 4, 4, 0, 0, 1, 9, 1, 1, 1, 6, 7, 3, 3, 3, 5, 5, 0, 0, 0, 2};
// Count of symbol on each reel
int totalSymbols = 24;
// reel speed. In milliseconds. Lower is faster.
int reelSpeed = 12;
// starting picture of cylinder
byte startingPicture[] = {8, 8, B10000001, B01000010, B00100100, B00011000, B00011000, B00100100, B01000010, B10000001};
class SlotCylinder {
byte buffer[10];
int *p_cylinderArr; // cylinder array (numbers 0 to 9)
int arrSize; // size of cylinderArr
int shiftSpeed; // speed of scrolling. Best is 25
int shiftCount; // how many times will the cylinder turn. More like symbol shift.
int startingIndex; // the index in cylinderArr where the cylinder will start
int realIndex = 0; // real index of position in cylinder
int realShiftSpeed; // shift speed already with slow start
//int shiftStart[18] = {75,74,73,70,66,62,56,50,44,38,31,25,19,13,9,5,2,1}; // slow start array. Like fade in
int shiftStart[18] = {50,50,48,47,44,41,38,34,29,25,21,16,13,9,6,3,2,1};
int shiftStartLength = 18; // length of shiftStart array. the slowing array.
int shiftStartPosition = 0; // position for slow start
int *rollingArray = {nullptr};
int rollingArrayIndex = 0;
int rollingArrayLength = 0;
bool isRolling = false;
int updDelay;
VirtualDelay rollDelay; // initialize virtual delay
MaxMatrix *p_dotMatrix;
//constructor
public:
* Constructor of SlotCylinder
* @param {int} *_p_cylinderArr pointer to array
* @param {int} _arrSize size of the cylinderArr array
* @param {int} _shiftSpeed speed of shift. Best is 25
SlotCylinder(int *_p_cylinderArr, int _arrSize, int _shiftSpeed) {
p_cylinderArr = _p_cylinderArr;
arrSize = _arrSize;
shiftSpeed = _shiftSpeed;
realShiftSpeed = _shiftSpeed;
// set right speed based on actual shiftspeed
for (int sb = 0; sb < shiftStartLength; sb++) {
shiftStart[sb] = shiftStart[sb] + shiftSpeed;
// Initialize MaxMatrix
void initMatrix(byte din, byte cs, byte clk) {
p_dotMatrix = new MaxMatrix(din, cs, clk, 1);
p_dotMatrix->init(); // module initialize
p_dotMatrix->setIntensity(1); // dot matix intensity 0-15
p_dotMatrix->clear();
p_dotMatrix->writeSprite(0, 0, startingPicture);
* Returns if cylinder is rolling
bool isCylinderRolling() {
return isRolling;
* Generates shifting array for the roll
void generateShiftArray(int _count) {
// Serial.println("generating shift array...");
int count = _count * 9;
rollingArrayLength = count;
int *myArray;
myArray = new int[count];
for (int i = 0; i < count; i++) {
// makes the starting speed slower
if (shiftStartPosition < shiftStartLength) {
myArray[i] = shiftStart[shiftStartPosition];
myArray[i] = shiftSpeed;
shiftStartPosition++;
shiftStartPosition = 0; // reset position
// Serial.println("almost there...");
rollingArray = myArray;
delete [] myArray;
// Serial.println("done.");
* Updating function which rolls the symbol
void update() {
if (isRolling == true) { // only if its rolling
updDelay = *(rollingArray + rollingArrayIndex);
if (updDelay < 0 || (updDelay > *(rollingArray + 1))) {
updDelay = *(rollingArray + (rollingArrayIndex - 1));
// Serial.println("ROLLING");
rollDelay.start(updDelay); // starts the roll
if (rollDelay.elapsed()) {
// Serial.print("TICK ");
// Serial.print(*(rollingArray + rollingArrayIndex));
// Serial.print(" -- ");
// Serial.print(rollingArrayIndex);
// Serial.print(" of ");
// Serial.print(rollingArrayLength);
// Serial.print(" | delay: ");
// Serial.println(updDelay);
// rolling has finished
if ((rollingArrayLength-1) < rollingArrayIndex) {
isRolling = false;
EasyBuzzer.stopBeep();
EasyBuzzer.singleBeep(131, 30);
// Serial.println("!!!! Finished rolling...");
if (rollingArrayIndex % 9 == 0) { // time to print symbol
//// Serial.println("### SYMBOL ###");
if (realIndex >= arrSize) { // endless shift thru the cylinder array
realIndex = realIndex - arrSize;
// display symbol to hidden place
memcpy_P(buffer, CH + 10 * p_cylinderArr[realIndex], 10);
p_dotMatrix->writeSprite(9, 0, buffer); // writes to 9th position because of 1px space
p_dotMatrix->setColumn(9 + buffer[0], 0);
realIndex++;
p_dotMatrix->shiftLeft(false, false); // shift one line
rollingArrayIndex++;
* Start rolling the cylinder
void roll() {
isRolling = true;
* Returns the symbol value in cylinder
int getPosition() {
return p_cylinderArr[realIndex - 1];
* Flashes or permanent turns on/off the LED connected to a pin
class Flasher {
int ledPin; // the number of the LED pin
unsigned long OnTime; // milliseconds of on-time
unsigned long OffTime; // milliseconds of off-time
int ledState; // ledState used to set the LED
unsigned long previousMillis; // will store last time LED was updated
bool updateFlshr = false; // flashing on/off
bool isOn = false; // global on/off
public:
Flasher(int pin, long on, long off) {
ledPin = pin;
pinMode(ledPin, OUTPUT);
OnTime = on;
OffTime = off;
ledState = LOW;
previousMillis = 0;
void update() {
if (updateFlshr == true) {
// check to see if it's time to change the state of the LED
if ((ledState == HIGH) && (currentMillis - previousMillis >= OnTime)) {
ledState = LOW; // Turn it off
previousMillis = currentMillis; // Remember the time
digitalWrite(ledPin, ledState); // Update the actual LED
else if ((ledState == LOW) && (currentMillis - previousMillis >= OffTime)) {
ledState = HIGH; // turn it on
void setInterval(long on, long off) {
OnTime = on;
OffTime = off;
void blinkOn() {
updateFlshr = true;
void permanentOn() {
isOn = true;
digitalWrite(ledPin, HIGH);
void off() {
isOn = false;
ledState = LOW;
digitalWrite(ledPin, LOW);
bool isBlinking() {
return updateFlshr;
bool isPermanentOn() {
return isOn;
// initialize LCD on I2C pins
LiquidCrystal_I2C lcd(0x27,16,4);
// initialize all cylinders
SlotCylinder cylinder1(cylinderSymbols1, totalSymbols, reelSpeed);
SlotCylinder cylinder2(cylinderSymbols2, totalSymbols, reelSpeed);
SlotCylinder cylinder3(cylinderSymbols3, totalSymbols, reelSpeed);
// initialize buttons
OneButton startButton(BUTTON_START, true); // Buttons can be on analog pins
Flasher startLed(LED_START, 300, 300); // set light to current button
OneButton betButton(BUTTON_BET, true);
Flasher betLed(LED_BET, 300, 300);
OneButton coinInserter(COIN_INSERTER, true);
// initialize main variables
bool slotRunning = false;
bool winner = false;
VirtualDelay lcdDelay;
// songs definitons
const char songWinner[] PROGMEM = "winner:d=32:b=130:f5,c6,f5,c6,f5,c6,f5,c6,16f6";
const char songGameOver[] PROGMEM = "gamovr:d=8:b=200:e5,b4,g4,8p,2e4";
const char songInsertCoin[] PROGMEM = "coin:d=16:b=140:e5,8e6";
ProgmemPlayer player(SPEAKER);
// credit and bets related stuff
int credit = 0;
int bet = 2; // value of bet
int betsArr[15] = {2, 5, 10, 20, 30, 40, 50, 60, 70, 80, 90, 100, 200, 500, 1000}; // possible bets
int betPos = 0; // position of bet in bet array
int betLen = 15; // length of bet array
* Prints label and value to LCD. Lines are defined from 0 to 1
void printNumberWithLabelToLCD(const char *label, int value, int valueStartingPosition, int line = 0) {
char buffer[50];
// i know this is messy piece of s**ty code, deal with it B-). I don't wanna talk about it!!!
if (value >= 0 && value < 10) {
snprintf(buffer, 50, "%s%u ", label, value);
} else if (value >= 10 && value < 100) {
} else if (value >= 100 && value < 1000) {
} else if (value >= 1000 && value < 10000) {
} else if (value >= 10000 && value < 100000) {
} else if (value >= 100000 && value < 1000000) {
snprintf(buffer, 50, "%s%u", label, value);
lcd.setCursor(0, line);
lcd.print(buffer);
// plays song for winning
void playWinSong() {
EasyBuzzer.stopBeep(); // stops any beeps
player.setSong(songWinner);
player.finishSong(); // plays song
// plays song for game over
void playGameOverSong() {
player.setSong(songGameOver);
// plays song for inserting coin
void playInsertCoinSong() {
player.setSong(songInsertCoin);
// update bet info in first line on LCD
void updateBetInfo() {
lcd.setCursor(11, 0);
lcd.print(" ");
printNumberWithLabelToLCD("Bet: ", bet, 5, 0); // update bet info
// seed generator from ADC pin (pins A6 and A7 on NANO)
uint32_t get_seed(int pin) {
uint16_t aread;
union {
uint32_t as_uint32_t;
uint8_t as_uint8_t[4];
} seed;
uint8_t i, t;
/* "aread" shifts 3 bits each time and the shuffle
* moves bytes around in chunks of 8. To ensure
* every bit is combined with every other bit,
* loop 3 x 8 = 24 times.
for (i = 0; i < 24; i++) {
/* Shift three bits of A2D "noise" into aread. */
aread <<= 3;
aread |= analogRead(pin) & 0x7;
/* Now shuffle the bytes of the seed
* and xor our new set of bits onto the
* the seed.
t = seed.as_uint8_t[0];
seed.as_uint8_t[0] = seed.as_uint8_t[3];
seed.as_uint8_t[3] = seed.as_uint8_t[1];
seed.as_uint8_t[1] = seed.as_uint8_t[2];
seed.as_uint8_t[2] = t;
seed.as_uint32_t ^= aread;
return(seed.as_uint32_t);
int randomGenerator(int min, int max) // range : [min, max)
static bool rndGenFirst = true;
if (rndGenFirst) {
// Serial.print("Using seed: ");
// Serial.println(get_seed(ADC_SEED_PIN));
srandom(get_seed(ADC_SEED_PIN)); // seeding for the first time only!
rndGenFirst = false;
return min + random() % (( max + 1 ) - min);
* Push the start button
void startButtonFn() {
if (credit >= bet && slotRunning == false) { // start only if player have credit and reels dont rotate
credit -= bet; // bets the money
startLed.off(); // turns off the light on button
betLed.off();
updateBetInfo();
printNumberWithLabelToLCD("Credit: ", credit, 8, 1); // update credit info
int firstNumber = randomGenerator(10, 25);
int secondNumber = randomGenerator(1,15);
int thirdNumber = randomGenerator(1,10);
secondNumber = firstNumber + secondNumber;
thirdNumber = secondNumber + thirdNumber;
if (firstNumber == secondNumber) {
secondNumber++;
if (secondNumber == thirdNumber) {
thirdNumber++;
// Serial.println("RND: ");
// Serial.println(firstNumber);
// Serial.println(secondNumber);
// Serial.println(thirdNumber);
cylinder1.generateShiftArray(firstNumber);
cylinder2.generateShiftArray(secondNumber);
cylinder3.generateShiftArray(thirdNumber);
cylinder1.roll();
cylinder2.roll();
cylinder3.roll();
slotRunning = true;
// make deep beep sound or something error-like
// walk thru the bet array to get the highest possible bet. if bet <= credit
void setCorrectBet() {
if (bet > credit) { // only if bet is greater than credit
for (int i = betLen-1; i --> 0;) {
if (betsArr[i] <= credit) {
betPos = i;
bet = betsArr[i];
updateBetInfo();
void betButtonFn() {
if (slotRunning == false) { // only allowed to push when cylinders are not turning
betPos++;
if (betPos == betLen) { // scroll thru bet array
betPos = 0;
if (betsArr[betPos] > credit) { // scroll is shortened due to the lack of credits
betPos = 0;
bet = betsArr[betPos];
updateBetInfo();
EasyBuzzer.singleBeep(262, 40);
void coinInserterFn() {
// Serial.println(coinInserter.getPressedTicks());
credit = credit + 20;
updateBetInfo();
playInsertCoinSong();
if (startLed.isBlinking() == false) {
startLed.blinkOn();
if (betLed.isBlinking() == false) {
betLed.blinkOn();
* Watcher for the slot machine. Resolves, if you win or lose.
void slotWatch() {
if (slotRunning == true) {
// cylinders are rolling
if (cylinder1.isCylinderRolling() == false && cylinder2.isCylinderRolling() == false && cylinder3.isCylinderRolling() == false) {
// all cylinders stopped
// Serial.println("###############");
// Serial.print("CYL 1: ");
// Serial.println(cylinder1.getPosition());
// Serial.print("CYL 2: ");
// Serial.println(cylinder2.getPosition());
// Serial.print("CYL 3: ");
// Serial.println(cylinder3.getPosition());
// Serial.println("---------------");
/* TODO
- first two symbols pays as 0.5 bet MAYBE
// all symbols are the same
if (winner == false &&
(cylinder1.getPosition() == cylinder2.getPosition() &&
cylinder2.getPosition() == cylinder3.getPosition())
// WIN
playWinSong();
credit += (symbolValue[cylinder1.getPosition()] * bet);
winner = true;
// Serial.println("*** WINNER ***");
/* JOKERS: If bet > 10, joker symbol (9) act as any symbol.
x | J | x
x | x | J
x | J | J
if (winner == false && (bet >= 10 &&
((cylinder2.getPosition() == 9 && cylinder1.getPosition() == cylinder3.getPosition()) ||
(cylinder3.getPosition() == 9 && cylinder1.getPosition() == cylinder2.getPosition()) ||
(cylinder2.getPosition() == 9 && cylinder3.getPosition() == 9)
// WIN
playWinSong();
winner = true;
// Serial.println("*** WINNER with JOKERS ***");
// J | x | J
((cylinder1.getPosition() == 9 && cylinder3.getPosition() == 9)
// WIN
playWinSong();
credit += (symbolValue[cylinder2.getPosition()] * bet);
winner = true;
J | J | x
J | x | x
((cylinder1.getPosition() == 9 && cylinder2.getPosition() == cylinder3.getPosition()) ||
(cylinder1.getPosition() == 9 && cylinder2.getPosition() == 9)
// WIN
playWinSong();
credit += (symbolValue[cylinder3.getPosition()] * bet);
winner = true;
// JOKERS end
if (winner == false) {
// LOSE
if (credit <= 0) {
playGameOverSong();
credit = 0;
lcd.setCursor(0, 1);
lcd.print(" iNSERT C0iN ");
startLed.off();
betLed.off();
// Serial.println("!!! GAME OVER !!!");
// Serial.println("-_- LOSER -_-");
// check if credit is enough to match the bet
setCorrectBet();
// Serial.print("credit: ");
// Serial.println(credit);
if (credit > 0) {
startLed.blinkOn();
betLed.blinkOn();
winner = false;
// Serial.begin(9600); // 115200
// Serial.println("STARTING SLOT MACHINE");
// init LCD. Shows bet and credits.
lcd.init();
lcd.backlight();
updateBetInfo();
// init display 8x8 matrix with DIN, CS, CLK
cylinder1.initMatrix(CYLINDER_1_DIN, CYLINDER_1_CS, CYLINDER_1_CLK);
cylinder2.initMatrix(CYLINDER_2_DIN, CYLINDER_2_CS, CYLINDER_2_CLK);
cylinder3.initMatrix(CYLINDER_3_DIN, CYLINDER_3_CS, CYLINDER_3_CLK);
// attach button to function
startButton.attachClick(startButtonFn);
betButton.attachClick(betButtonFn);
// attach coin inserter
coinInserter.setDebounceTicks(2);
coinInserter.attachClick(coinInserterFn);
// initialize easybuzzer
EasyBuzzer.setPin(SPEAKER);
// blink start led
// startLed.blinkOn();
// button watcher
startButton.tick();
betButton.tick();
coinInserter.tick();
// cylinder watcher
cylinder1.update();
cylinder2.update();
cylinder3.update();
// slot game winning/losing watcher
slotWatch();
// LED watcher
startLed.update();
betLed.update();
// sound watcher
EasyBuzzer.update();
I've tried including multiple arrays with PROGMEM, as well as removing the Serial.println() statements, and I really think this is the problem.
After I've done this, the led array starts up fine and displays what it should (albeit very slowly, stuttering).
Is there any other way to reduce the space in SRAM? (Although the compiler tells me that there are 1203 bytes left for dynamic memory)
(Thank you very much!)
_
This is my code now:
#include <rtttl.h>
//Pantalla I2C
#include <Wire.h>
//#include <hd44780.h> // main hd44780 header
//#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header
//hd44780_I2Cexp lcd; // declare lcd object: auto locate & auto config expander chip
// PINs definitions
#define CYLINDER_1_DIN 6
#define CYLINDER_1_CLK 4
#define CYLINDER_3_DIN 10
#define CYLINDER_3_CS 11
#define CYLINDER_3_CLK 12
#define SPEAKER 3
#define BUTTON_START 2
#define LED_BET A2
#define ADC_SEED_PIN A7 // this pin is on Pro Micro not listed on pins, but it is on the chip itself
OneButton btn = OneButton(BUTTON_START, true, true);
const static unsigned char CH[] PROGMEM = {
const int symbolValue[10] PROGMEM = {3, 3, 5, 5, 10, 20, 30, 40, 75, 75};
const int cylinderSymbols1[24] PROGMEM = {8, 5, 5, 9, 1, 0, 1, 7, 3, 3, 3, 2, 2, 2, 0, 0, 0, 4, 4, 4, 6, 1, 1, 1};
const int cylinderSymbols2[24] PROGMEM = {8, 4, 4, 0, 0, 0, 9, 1, 6, 6, 1, 1, 1, 7, 1, 1, 2, 2, 2, 3, 5, 3, 3, 3};
const int cylinderSymbols3[24] PROGMEM = {8, 2, 2, 2, 4, 4, 0, 0, 1, 9, 1, 1, 1, 6, 7, 3, 3, 3, 5, 5, 0, 0, 0, 2};
#define totalSymbols 24
#define reelSpeed 12
const byte startingPicture[] PROGMEM = {8, 8, B10000001, B01000010, B00100100, B00011000, B00011000, B00100100, B01000010, B10000001};
byte buffer[10];
int updDelay;
//constructor
public:
arrSize = _arrSize;
return isRolling;
int *myArray;
delete [] myArray;
void update() {
isRolling = false;
realIndex++;
void roll() {
isRolling = true;
int getPosition() {
class Flasher {
public:
ledPin = pin;
OnTime = on;
OffTime = off;
ledState = LOW;
previousMillis = 0;
void update() {
OnTime = on;
OffTime = off;
void blinkOn() {
updateFlshr = true;
isOn = true;
void off() {
isOn = false;
ledState = LOW;
bool isBlinking() {
return updateFlshr;
return isOn;
//Declarado arriba del todo
// songs definitons
int credit = 1000;
char buffer[50];
//lcd.setCursor(0, line);
//lcd.print(buffer);
//lcd.setCursor(11, 0);
//lcd.print(" ");
uint16_t aread;
union {
} seed;
uint8_t i, t;
aread <<= 3;
* the seed.
if (rndGenFirst) {
//Serial.print("Using seed: ");
//Serial.println(get_seed(ADC_SEED_PIN));
//Serial.println("HOLA, RUEDA PLS");
betLed.off();
updateBetInfo();
secondNumber++;
thirdNumber++;
//Serial.println("RND: ");
//Serial.println(firstNumber);
//Serial.println(secondNumber);
//Serial.println(thirdNumber);
cylinder1.generateShiftArray(15);
cylinder2.generateShiftArray(20);
cylinder3.generateShiftArray(22);
cylinder1.roll();
cylinder2.roll();
cylinder3.roll();
slotRunning = true;
betPos = i;
bet = betsArr[i];
updateBetInfo();
betPos++;
betPos = 0;
betPos = 0;
updateBetInfo();
updateBetInfo();
startLed.blinkOn();
betLed.blinkOn();
void slotWatch() {
/* TODO
// WIN
playWinSong();
winner = true;
x | J | x
x | x | J
x | J | J
// WIN
playWinSong();
winner = true;
// J | x | J
// WIN
playWinSong();
winner = true;
J | J | x
J | x | x
// WIN
playWinSong();
winner = true;
// JOKERS end
// LOSE
if (credit <= 0) {
playGameOverSong();
credit = 0;
//lcd.setCursor(0, 1);
//lcd.print(" iNSERT C0iN ");
startLed.off();
betLed.off();
setCorrectBet();
if (credit > 0) {
startLed.blinkOn();
betLed.blinkOn();
winner = false;
static void holi(){
//Serial.println("Adios");
//Serial.begin(9600);
//Serial.println("Inicializando maquina...");
btn.attachClick(startButtonFn);
//INICIALIZACION DE LA PANTALLA I2C
/*int status = lcd.begin(16, 2);
if(status) hd44780::fatalError(status);
lcd.setCursor(1, 0);
lcd.print("Pulsa para jugar");*/
updateBetInfo();
//startButton.attachClick(startButtonFn);
// button watcher
//startButton.tick();
betButton.tick();
// cylinder watcher
cylinder1.update();
cylinder2.update();
cylinder3.update();
slotWatch();
// LED watcher
startLed.update();
betLed.update();
// sound watcher
btn.tick();
Could you try the freeMemory() function to check runtime how much SRAM is still free: Measuring Memory Usage | Memories of an Arduino | Adafruit Learning System
Note you do not access program memory like this.
But like this:-
for (byte k = 0; k < 5; k++) {
displayInt = pgm_read_word_near(charSet + k);
Serial.println(displayInt);
a)
double check each used int variable if it has to be a two byte signed value.
If you can confirm, that you really need an int, use int16_t instead.
Otherwise, replace it with a more appropriate value type.
one suspicious variable:
b)
use the F-Makro for fix text
lcd.print(F("Pulsa para jugar"));
c) after you have improved your sketch, post it again including links to the used libraries, otherwise I don't know where I can find
#include <rtttl.h>
