Hello everybody. I recently bought a led matrix 64x16:
The arduino sketch provided works fine. Now I want to adjust the code to display another text.
This is the code:
//Author: cantone-electonics
//More information welcome to : http://www.canton-electronics.com
//Arduino 1.0.4
//Arduino uno R3
//64x16 Matrix LED
#define COL_PIXEL 64
#define ROW_PIXEL 16
int latchPin=8; //LT
int clockPin=12;//SK
int dataPin=11; //R1
int en_74138 = 2;
int la_74138 = 3;
int lb_74138 = 4;
int lc_74138 = 5;
int ld_74138 = 6;
unsigned int ROW_xPixel;
unsigned int ROW_num;
unsigned char Col_num_1;
unsigned char Col_num_2;
unsigned char Col_num_3;
unsigned char Col_num_4;
unsigned char Col_num_5;
unsigned char Col_num_6;
unsigned char Col_num_7;
unsigned char Col_num_8;
//Data code: Horizontal modulus ,Bytes reverse order
unsigned char Bmp1[]=
; Width X height (pixels): 64X16
;I Love You
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xc0, 0xff, 0x0, 0x3, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xc, 0xc0, 0x0, 0x0, 0x0,
0x0, 0x0, 0xc, 0x0, 0x3, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xc, 0xc0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xc, 0x0, 0x3, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x30, 0x30, 0x0, 0x0, 0x0, 0x0, 0x0, 0xc, 0x0, 0x3, 0xc0, 0x3, 0x3, 0x30, 0xf0, 0x0, 0xc0, 0xc,
0xf0, 0xc0, 0x0, 0x3, 0x0, 0xc, 0x0, 0x3, 0x30, 0xc, 0x3, 0x30, 0xc, 0x3, 0x0, 0x3, 0xc, 0xc3, 0x0, 0x3, 0x0, 0xc,
0x0, 0x3, 0xc, 0x30, 0x3, 0x30, 0x3, 0xc, 0x0, 0x3, 0x3, 0xcc, 0x0, 0x3, 0x0, 0xc, 0x0, 0x3, 0xc, 0x30, 0x3, 0x30,
0x3, 0xc, 0x0, 0x3, 0x3, 0xcc, 0x0, 0x3, 0x0, 0xc, 0x0, 0x3, 0xc, 0x30, 0x3, 0x30, 0xf, 0xc, 0x0, 0x3, 0x3, 0xcc,
0x0, 0x3, 0x0, 0xc, 0x0, 0x3, 0xc, 0x30, 0x3, 0x30, 0xf3, 0x3, 0x0, 0x3, 0x3, 0xcc, 0x0, 0x3, 0x0, 0xc, 0x0, 0x3,
0xc, 0x30, 0xc, 0xc, 0x3, 0x0, 0x0, 0x3, 0x3, 0xcc, 0x0, 0x3, 0x0, 0xc, 0x0, 0xc3, 0x30, 0xc, 0x30, 0x3, 0x3, 0xc,
0x0, 0x3, 0xc, 0xc3, 0x0, 0x3, 0xc0, 0xff, 0x0, 0xff, 0xc0, 0x3, 0xc0, 0x0, 0xfc, 0x3, 0x0, 0x3, 0xf0, 0x0, 0xff,
unsigned char Bmp2[]=
; Width X height (pixels): 16X16
;WELCOME 64 16
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x3c, 0x30, 0xf0, 0xfc, 0xff, 0x3c, 0x0,
0xf0, 0x3f, 0xf0, 0xf, 0x3c, 0x0, 0xcf, 0xff, 0x3f, 0x3c, 0xf0, 0xf0, 0xfc, 0xff, 0x3c, 0x0, 0xfc, 0x3f, 0xfc, 0x3f, 0x3c,
0x0, 0xcf, 0xff, 0x3f, 0x3c, 0xf0, 0xf0, 0x3c, 0x0, 0x3c, 0x0, 0xf, 0x0, 0xf, 0xf0, 0x3c, 0x0, 0xcf, 0x3, 0x0, 0x3c, 0xfc,
0xf0, 0x3c, 0x0, 0x3c, 0x0, 0xf, 0x0, 0xf, 0xf0, 0xfc, 0xc0, 0xcf, 0x3, 0x0, 0x3c, 0xfc, 0xf0, 0x3c, 0x0, 0x3c, 0x0, 0xf,
0x0, 0xf, 0xf0, 0xfc, 0xf0, 0xcf, 0x3, 0x0, 0xfc, 0xfc, 0xfc, 0xfc, 0xff, 0x3c, 0x0, 0xf, 0x0, 0xf, 0xf0, 0xfc, 0xf3, 0xcf,
0xff, 0x3f, 0xf0, 0xfc, 0x3c, 0xfc, 0xff, 0x3c, 0x0, 0xf, 0x0, 0xf, 0xf0, 0x3c, 0x3f, 0xcf, 0xff, 0x3f, 0xf0, 0xfc, 0x3c,
0x3c, 0x0, 0x3c, 0x0, 0xf, 0x0, 0xf, 0xf0, 0x3c, 0x3f, 0xcf, 0x3, 0x0, 0xf0, 0xfc, 0x3c, 0x3c, 0x0, 0x3c, 0x0, 0xf, 0x0,
0xf, 0xf0, 0x3c, 0x3f, 0xcf, 0x3, 0x0, 0xf0, 0xff, 0x3f, 0x3c, 0x0, 0x3c, 0x0, 0xf, 0x0, 0xf, 0xf0, 0x3c, 0x3f, 0xcf, 0x3,
0x0, 0xf0, 0xff, 0x3f, 0x3c, 0x0, 0x3c, 0x0, 0xf, 0x0, 0xf, 0xf0, 0x3c, 0x3f, 0xcf, 0x3, 0x0, 0xc0, 0xcf, 0xf, 0x3c, 0x0,
0x3c, 0x0, 0xf, 0x0, 0xf, 0xf0, 0x3c, 0xf, 0xcf, 0x3, 0x0, 0xc0, 0xcf, 0xf, 0xfc, 0xff, 0xfc, 0xff, 0xfc, 0x3f, 0xfc, 0x3f,
0x3c, 0xc, 0xcf, 0xff, 0x3f, 0x0, 0x3, 0x3, 0xfc, 0xff, 0xfc, 0xff, 0xf0, 0x3f, 0xf0, 0xf, 0x3c, 0xc, 0xcf, 0xff, 0x3f, 0x0,
void shiftOut(unsigned char dataOut)
for(int i=0;i<=7;i++)
PORTB &=~(1<<(clockPin-8));//equate digitalWrite(clockPin,LOW);
if(dataOut & (0x01<<i)) PORTB |=1<<(dataPin-8); //equate digitalWrite(dataPin,HIGH);
else PORTB &=~(1<<(dataPin-8));//equate digitalWrite(dataPin,LOW);
PORTB |=1<<(clockPin-8);//equate digitalWrite(clockPin,HIGH);
//Combine 2 bits/pixel to 1 bits/pixel
unsigned char Combine_2BitsTo1Bit(unsigned char num,unsigned char *BMP)
unsigned char Col_num_tem_1;
unsigned char Col_num_tem_2;
unsigned int Col_num_tem = 0;
unsigned char i=0;
unsigned char Col_num_1bit = 0x00;
Col_num_tem_1 = *(BMP+num);
Col_num_tem_2 = *(BMP+num+1);
Col_num_tem = Col_num_tem_1;
Col_num_tem |= (Col_num_tem_2 << 8);
for(i=0;i<8;i++)
if(Col_num_tem&(0x0003<<i*2)) Col_num_1bit |= (0x01<<i);
return ~Col_num_1bit;
//display one picture
void display_martix(unsigned char *BMP)
//Display count
unsigned int dis_cnt=256;
unsigned int i;
for(i=0;i<dis_cnt*16;i++)
digitalWrite(en_74138, HIGH);//Turn off display
//Col scanning
shiftOut(Col_num_1);
shiftOut(Col_num_2);
shiftOut(Col_num_3);
shiftOut(Col_num_4);
shiftOut(Col_num_5);
shiftOut(Col_num_6);
shiftOut(Col_num_7);
shiftOut(Col_num_8);
digitalWrite(latchPin, LOW);
digitalWrite(latchPin, HIGH);
//Row scanning
// AVR Port Operation
PORTD = ((ROW_xPixel << 3 ) & 0X78) | (PORTD & 0X87);//Write PIN 3 4 5 6 la_74138 lb_74138 lc_74138 ld_74138
digitalWrite(en_74138, LOW);//Turn on display
if(ROW_xPixel==15) ROW_xPixel=0; else ROW_xPixel++;
// Single color,1 bits/pixel
Col_num_1=~BMP[(COL_PIXEL/8)*ROW_xPixel];
Col_num_2=~BMP[(COL_PIXEL/8)*ROW_xPixel+1];
Col_num_3=~BMP[(COL_PIXEL/8)*ROW_xPixel+2];
Col_num_4=~BMP[(COL_PIXEL/8)*ROW_xPixel+3];
Col_num_5=~BMP[(COL_PIXEL/8)*ROW_xPixel+4];
Col_num_6=~BMP[(COL_PIXEL/8)*ROW_xPixel+5];
Col_num_7=~BMP[(COL_PIXEL/8)*ROW_xPixel+6];
Col_num_8=~BMP[(COL_PIXEL/8)*ROW_xPixel+7];
//Single color,2 bits/pixel
Col_num_1 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2,BMP);
Col_num_2 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+2,BMP);
Col_num_3 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+4,BMP);
Col_num_4 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+6,BMP);
Col_num_5 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+8,BMP);
Col_num_6 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+10,BMP);
Col_num_7 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+12,BMP);
Col_num_8 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+14,BMP);
// delayMicroseconds(1000);
pinMode(latchPin,OUTPUT);
pinMode(clockPin,OUTPUT);
pinMode(dataPin,OUTPUT);
pinMode(en_74138,OUTPUT);
pinMode(la_74138,OUTPUT);
pinMode(lb_74138,OUTPUT);
pinMode(lc_74138,OUTPUT);
pinMode(ld_74138,OUTPUT);
// AVR Port Settings
DDRD |= 0x78; //Set PIN 3 4 5 6 output
display_martix(Bmp1);
display_martix(Bmp2);
I would like to alter the text, but I don't understand how to do that. The code for the text is in HEX, I can imagine the first line is blanc becourse HEX0X0 = 0000. Then I cant figure out how it works. Is the re someone who van point me in the right direction.
Greets Herman
