Hi guys,
I am trying to get a Adafruit IS31FL3731 - 16x9 LED matrix to work. It is displaying numbers fine, however there is a flicker. I am assuming it is due to the ledmatrix.clear() which is required to clear the screen before a new update. However I have tried so many things to get this to work now I am out of ideas.
The project is a display that takes data from UART and displays the values on the LED Matrix. Code included below, many thanks for any help!
Jack
#include <VescUart.h> // Thanks SolidGeek!
#include <SimpleKalmanFilter.h>
#include <Wire.h>
#include <Adafruit_GFX.h> // Thanks Adafruit!
#include <Adafruit_IS31FL3731.h>
#include <Fonts/Dotty5px7b.h> // edit font here - https://tchapi.github.io/Adafruit-GFX-Font-Customiser/
#include <Fonts/goodbyeDespair7pt7b.h> // this font has been edited, only numbers are refined, other glyphs are not tested
// If you're using the full breakout...
Adafruit_IS31FL3731 ledmatrix = Adafruit_IS31FL3731(); // Adafruit_IS31FL3731(11,7);
/** Initiate VescUart class */
VescUart UART;
unsigned long previousMillis = 0; // timer for updating the display instead of using blocking delay
// VESC LED Matrix Display - for 16x9 LED Matrix
// Connect VESC TX to Arduino RX
// Connect VESC RX to Arduino TX
// Connect VESC 5v to Arduino VIN
// Connect VESC GND to Arduino GND
///////// User Set Values //////////
// These are specific values that need to be set based on your device.
const long updateInterval = 100; // interval at which to refresh the display (milliseconds)
const int displayBrightness = 20; // 0-255 - Sets Brightness of LEDs - could set levels with a LDR based on daylight level
const int motorPolePairs = 7; // The '7' is the number of pole pairs in the motor. Most motors have 14 poles, therefore 7 pole pairs
const float wheelDia = 0.6; // Wheel Diameter in m - measure the outer most tyre for accurate measurements
const int motorPulley = 1; // Num Teeth - Set to 1 for direct drive e.g. Hub Motor
const int wheelPulley = 1; // Num Teeth - Set to 1 for direct drive e.g. Hub Motor
const int BattNumCells = 12; // Number of series cells in battery e.g. 4.2*12=50.4v pack
const float cellDischargelevel = 3.2; // Lowest discharge level for battery - used for batt percentage
const int metersinMeterKm = 1000; // set to 1000 for Kph or 1609 for Mph
// Which display style to use? Future plan is to have buttons for user to cycle the screens
const int displayStyle = 1;
* 1 - Large Numbers (Speed Only)
* 2 - Smaller Numbers Speed & Distance + batt percent bar at bottom
///////// END User Set Values //////////
// define variables
int rpm;
float voltage;
float current;
float power; //int power
float amphour;
float tach;
float distance;
float velocity;
float watthour;
float batpercentage;
//SimpleKalmanFilter Filter1(2, 2, 0.01);
if (! ledmatrix.begin()) {
Serial.println("IS31 not found");
while (1);
Serial.println("IS31 Found!");
while (!Serial) {;}
/** Define which ports to use as UART */
UART.setSerialPort(&Serial);
// STARTUP SCREEN
ledmatrix.setTextColor(displayBrightness); // quarter brightness
ledmatrix.setFont(&goodbyeDespair7pt7b);
ledmatrix.setCursor(0,8);
ledmatrix.setTextSize(1);
ledmatrix.print("UE");
ledmatrix.clear(); // clear display ready for next update
} // end setup
void LargeNumbers() // Screen 1 - see above for desc
ledmatrix.setFont(&Dotty5px7b); // Dotty5px7b goodbyeDespair7pt7b
if (voltage > 9){
ledmatrix.setCursor(0,7); // double digits XY
else {
ledmatrix.setCursor(5,7); // single digits XY
ledmatrix.print(voltage);
void SmallNumbers2() // Screen 2 - see above for desc
// Voltage
if (voltage > 9){
ledmatrix.setCursor(0,4); // double digits XY
else {
ledmatrix.setCursor(2,4); // single digits XY
// distance
if (distance > 9){
ledmatrix.setCursor(9,4); // double digits XY centre is 5,5
else {
ledmatrix.setCursor(11,4); // single digits centre is 7,5
ledmatrix.print(distance);
// Bottom Batt Percentage Bar
int ledLevel = map(batpercentage, 0, 100, 0, 16); // maps percentage to num of LEDS on bottom // map(value, fromLow, fromHigh, toLow, toHigh) //16 is the number of LEDs on the bottom
ledmatrix.drawRect(0, 7, ledLevel, 2, displayBrightness); // x, y, width, height, brightness
if (currentMillis - previousMillis >= updateInterval) {
// save the last time you blinked the LED
//ledmatrix.clear(); // clear display ready for next update
////////// Read values //////////
if ( UART.getVescValues() ) {
rpm = (UART.data.rpm)/motorPolePairs; // The '7' is the number of pole pairs in the motor. Most motors have 14 poles, therefore 7 pole pairs
voltage = (UART.data.inpVoltage);
current = (UART.data.avgInputCurrent);
power = voltage*current;
amphour = (UART.data.ampHours);
watthour = amphour*voltage;
tach = (UART.data.tachometerAbs)/((motorPolePairs*2)*3); // The '42' is the number of motor poles multiplied by 3 tach = (UART.data.tachometerAbs)/42;
distance = tach*3.142*(1/metersinMeterKm)*wheelDia*(motorPulley/wheelPulley); // Motor RPM x Pi x (1 / meters in a mile or km) x Wheel diameter x (motor pulley / wheelpulley)
velocity = rpm*3.142*(60/metersinMeterKm)*wheelDia*(motorPulley/wheelPulley); // Motor RPM x Pi x (seconds in a minute / meters in a mile) x Wheel diameter x (motor pulley / wheelpulley)
batpercentage = ((voltage-(cellDischargelevel*BattNumCells))/BattNumCells)*100; // ((Battery voltage - minimum voltage) / number of cells) x 100
////////// Screen Selection //////////
//ledmatrix.setTextColor(displayBrightness); // set LED brightness
if (displayStyle == 1){
LargeNumbers(); // Screen 1 - see above for desc
if (displayStyle == 2){
SmallNumbers2(); // Screen 2 - see above for desc
else // could not get values from the VESC ;(
// Error X Symbol
ledmatrix.setCursor(5,8);
ledmatrix.print("X");
// END Error X Symbol
} ////////// END OF LOOP //////////
