LED mesh P10 with Arduino Uno
Hello, I am a student of the University, I have a project where I have to do as an accountant where I must represent two numbers with 4 LED meshes, that is to say a number for two led meshes vertically, researched and obtained data horizontally as letters but I don't know how to show half of one number above and the other below, attached image of what I explain
I don't know how the image shows directly, so I attached the image link
This is the code that I use for the text horizontally, I would be very grateful with your help.
#include <SPI.h>        //SPI.h debe incluirse ya que DMD está escrito por SPI (el IDE se queja de lo contrario)
#include <Fuente.h>        //Incluye libreria de fuente
#include <TimerOne.h>
#include "SystemFont5x7.h" //Incluye libreria de tiempo 1
#include "Arial_black_16.h"
//DMD display(2,1);    //Un panel horizontal
DMD display(2,1);  //Descomente si va utilizar dos paneles horizontales
//DMD display(3,1);  //Descomente si va utilizar tres paneles horizontales
void ScanDMD()
  display.scanDisplayBySPI();
   Timer1.initialize( 3000 );
   Timer1.attachInterrupt(ScanDMD);
 void loop(){
   display.selectFont(Arial_Black_16);                      // selecciona letra pequeña
   display.drawString(0,1,"UTMACH",6,  GRAPHICS_NORMAL); // escribe una cadena de 4 letras
   //display.drawString(7,9,"Demasiado",9, GRAPHICS_NORMAL); // escribe una cadena de 5 letras
   delay( 5000 );
OK, here is the image from your cross posting in the Spanish forum:
You need to explain what your "P10" matrix modules actually are, but I am going to presume they may be one of the MAX7219 8 by 8 array modules.
If this is the case, I would suggest you would want to use the "Parola" library available in the IDE which allows for such arrays.
I have never heard of this "Fuente" library before. If the "P10" matrix modules are a different device again, then I cannot help at all. :astonished:
Paul__B:
I'm sorry I don't realize that I don't put the type of P10 is the P10 (R1) 16x32, I don't know how to show the number like in the image you saw
https://drive.google.com/open?id=1FSDLBKwiRppclCe-uebPdrvt9kcU0J8t
those are the modules and it is the only thing that I have managed to join two meshes but in a horizontal way, but I need to visualize numbers and that these are subtracted from 1 in 1: 10,9,8,7,6,5,4 .. ... until 0
fuente.h is the dmd.h library I don't know why they had placed it like this, since the library is from a tutorial code that I had previously found.
OK, so this "P10" is some module you have obtained from somewhere-or-other but most of us here would not know anything about it.
Nor would we have any idea what a "dmd.h library" is or where it appears on the 'net. DuckDuckGo does however indicate that this is the support for the Freetronics modules sold (amongst others no doubt) by Jaycar.
So I suppose that is a start. I have so far resisted the Freetronics displays. :grinning: Perhaps someone here has used them.
