LED not pulsating (fading) as expected
Hello Arduino experts,
I am trying to make an LED pulsate (fade-in and fade-out) when a servo motor is in movement when a button is pressed. What I am trying to do is that when I press the button : 2 servo motor start turning and an LED starts fading in and out. I want the fading to stop when the motors stop or when the button is unpressed.
I got both servos to work as expected when pressing the button but the LED is not fading in the expected behavour, it seems more like it's flickering or fading inconsistently.
But I tested the code for fading (line 39-54) without the servo motors and the fading worked properly. but when I add them both together the LED doesn't pulsate as expected, any advice ? Here is the code and schematics :
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
#define servoPin1 3 //~
#define pushButtonPin 2
int led = 9;         // the PWM pin the LED is attached to
int brightness = 0;  // how bright the LED is
int fadeAmount = 1;  // how many points to fade the LED by
int angle = 179;    // initial angle  for servo (beteen 1 and 179)
int angleStep = 1;
const int minAngle = 0;
const int maxAngle = 180;
int pos = 0;
const int type =2;
  // declare pin 9 to be an output:
  pinMode(led, OUTPUT);
  // Servo button demo by Robojax.com
  Serial.begin(9600);          //  setup serial
  myservo.attach(servoPin1);  // attaches the servo on pin 3 to the servo object
  pinMode(pushButtonPin,INPUT_PULLUP);
   //myservo.write(angle);//initial position
  if(digitalRead(pushButtonPin) == LOW){
       //begin LED dimming code
analogWrite(led, brightness);
//   change the brightness for next time through the loop:
  brightness = brightness + fadeAmount;
  // reverse the direction of the fading at the ends of the fade:
  if (brightness <= 0 || brightness >= 255) {
    fadeAmount = -fadeAmount;
//   wait for 30 milliseconds to see the dimming effect
  delay(30);
  //end LED dimming
    if (angle > 0 && angle <= 180) {
      angle = angle - angleStep;
       if(angle < 0){
        angle = 0;
       else{
      myservo.write(angle); // move the servo to desired angle
  delay(20); // waits for the servo to get there
  if(digitalRead(pushButtonPin) == HIGH){
  analogWrite(led, 0);
    if (angle >= 0 && angle <= 180) {
      angle = angle + angleStep;
      if(angle >180){
        angle =180;
      else{
Never ever use the Arduino 5v pin to power motors.
So what should I use instead ? and is this the cause of the problem ?
I want to add. Never ever use USB to power motors..... It very seldomly turns out well.
A separate motor power supply, or skip the motors.
int led = 9; // the PWM pin the LED is attached to <———<<<<
Servo library disables analogWrite() (PWM) functionality on pins 9 and 10
I connected the LED to pin 11 and now the LED stays on but does not pulsate.
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the </> icon from the ‘reply menu’ to attach the copied sketch.
#include <Servo.h>
int led = 11;         // the PWM pin the LED is attached to
int angleStep = 1;
int pos = 0;
const int type =2;//watch video for details. Link is at the top of this code (robojax)
   Serial.println("Robojax Servo Button ");
  delay(10);
  //end LED dimming
       if(angle < 0){
        angle = 0;
       else{
      if(angle >180){
        angle =180;
      else{
What exactly is happening with the sketch and hardware ?
The LED will stay ON instead of pulsating. The servos rotate fine.
Changed a few things.
Probably messed up your sketch, however, try this to see is the servo moves and the LED fades.
#include <Servo.h>
Servo myservo;
#define servoPin1        3
int led               = 11;
int brightness        = 0;
int fadeAmount        = 1;
int angle             = 179;
int angleStep         = 1;
int pos               = 0;
const int type        = 2;
  pinMode(pushButtonPin, INPUT_PULLUP);
} //END of   setup()
  // P U S H E D
  if (digitalRead(pushButtonPin) == LOW)
    if (brightness < 0 )
      brightness = 0;
    else if (brightness > 255)
      brightness = 255;
    delay(10);
      if (angle < 0)
        angle = 0;
  // R E L E A S E D
  if (digitalRead(pushButtonPin) == HIGH)
    brightness = 0;
    if (angle <= 180)
      if (angle > 180)
        angle = 180;
    delay(20); //waits for the servo to get there
} //END of   loop()
Servo work but LED stays ON. I am also trying this on a simulator. I will try it using the hardware. How can I connect the servos on a different power source ? Also I will powering the Arduino using 12 V power (not USB)
The LED fades here just fine.
You must have something wired wrong or your pin 11 is bad.
Always show us a good image of your ‘actual’ wiring.
Example:
I only tried it on the TinkerCad simulator I will be trying with the real hardware.
But is it ok how I am connecting multiple servos to the same pin ? if not how should I be connecting them ? NOTE: I power my Arduino Uno using 12 Vpower source NOT USB.
Two servo motors on one output pin should be okay.
If you run into problems, put a 220R resistor in series with each servo connection.
This looks perfect I will definitely try this set up...
