LED partial array for glitter
I have a strip of 146 LEDs. WS2815. I want to light 75 of them in sequence and then get the remaining 72 to light using "glitter" from fastLED for 3 seconds and then write to those 72 to become solid colors. I can get the whole strip to glitter but I can't get just the LEDs from #74 to #145 to glitter. It seems that I'm having a problem defining my starting point in the array. I don't want to start at 0 but rather at 75 any help would be more than welcome. Just a note to please be gentle with me as I am 76 years old and this is for a project for Burning Man. Not that that really makes any difference. Thanks.
#include "FastLED.h"
#define LEDPIN     7
#define LED_TYPE     WS2815
#define NUM_LEDS    146
#define BRIGHTNESS 60
#define FRAMES_PER_SECOND 120
CRGB leds[NUM_LEDS];
//sanity delay
// set up LED strip info
FastLED.addLeds<LED_TYPE,LEDPIN>(leds,NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.setBrightness(BRIGHTNESS);
fadeToBlackBy( leds, NUM_LEDS, 20);
/*  It takes 3 parameters:
1  the array you are dimming,
2  the number of LEDs in that array you are dimming starting from index [0] (the first LED in the array),
3  and the amount you would like to fade them. Changing the third variable changes how quickly the lights fadeSo an example would be:
This would reduce the colour values for all the LEDs to 20/256ths of their current value
in a previous line we set the whole array of LEDs to CRGB:: white, which means that the r, g, and b values are all 255.
Then we would write the line:
fadeToBlackBy(arrayName, lengthOfStrip, 10);
//changing this variable will increase the chance of a "star" popping up
addGlitter(200);
FastLED.show();
//glitter effect
void addGlitter( fract8 chanceOfGlitter) {
  if( random8() < chanceOfGlitter) {
    leds[ random16(NUM_LEDS) ] += CRGB::White;}
random16(NUM_LEDS) will give you a random number in the [0, NUM_LEDS[ interval
you want only the last 72 to glitter, so generate a random number for that range and add 75 to that number to impact only the tail
try
leds[75 +  random16(71) ] += CRGB::White;
Thank you, thank you, thank you. That was exactly what I was looking for. I had a gut feeling that I needed to do something like what you suggested but I just didn't know where of how to do it. You are a lifesaver.
cool - have fun ! (share pictures of the finished project !)
You could take advantage of the CPixelView class provided by FastLED. This provides a "view" into a subsection of an existing LED array and automatically adjusts to provide zero-based indexing for the subsection. So, you'd add below the definition of the LED array:
const size_t glitterStart = 75;
const size_t numGlitterLeds = NUM_LEDS - glitterStart;
CPixelView<CRGB> glitterLeds(leds, glitterStart, glitterStart + numGlitterLeds - 1);
and your addGlitter function would be come:
//glitter effect
void addGlitter(fract8 chanceOfGlitter) {
	if (random8() < chanceOfGlitter) {
		glitterLeds[random16(numGlitterLeds)] += CRGB::White;
