LED "Startup sequence" before running the rest in a loop
Hello
I am not very good in understanding and programming to arduino and did my program got somehow to run as I wanted to, but i will have an "startup sequence" in the script before the LEDs run.
I want all LEDs to light up in Red (maybe a fast Fade in, where i can define the speed) then light up for about 2 seconds , then fade out and after that this code should be executed
#include <FastLED.h>
double Pixel = 0;
double i = 0;
double Dimmer = 0;
#define NUM_LEDS 122
#define DATA_PIN 3
#define BRIGHTNESS 255
CRGB leds[NUM_LEDS];
int potPin0 = A0;    // select the input pin for the potentiometer speed
int potPin1 = A1;    // select the input pin for the potentiometer tail
int potPin2 = A2;    // select the input pin for the potentiometer color
int potPin3 = A3;    // select the input pin for the potentiometer brightness
int val0;       // variable to store the value coming from the sensor
int val1;       // variable to store the value coming from the sensor
int val2;       // variable to store the value coming from the sensor
int val3;       // variable to store the value coming from the sensor
      FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
      FastLED.setBrightness(255);
  val0 = analogRead(potPin0) / 41;    // read the value from the sensor for speed
  val1 = analogRead(potPin1) / 102.3; // read the value from the sensor for tail
  val2 = analogRead(potPin2) / 4.01;     // read the value from the sensor for color
  val3 = analogRead(potPin3) / 4.01;     // read the value from the sensor for brightness
  if (val1 < 1) {
    val1 = 1;
  Serial.print("V0 = ");
  Serial.print(val0);
  Serial.print(" / ");
  Serial.println(analogRead(potPin0));
  Serial.print("V1 = ");
  Serial.print(val1);
  Serial.println(analogRead(potPin1));
    Serial.print("V2 = ");
  Serial.print(val2);
  Serial.println(analogRead(potPin2));
    Serial.print("V3 = ");
  Serial.print(val3);
  Serial.println(analogRead(potPin3));
  Serial.print("NUM_LEDS = ");
  Serial.println(NUM_LEDS);
   for (Pixel = 1; Pixel <= NUM_LEDS-5; Pixel++) {
         fill_solid( &(leds[int(constrain(Pixel, 1, NUM_LEDS) - 0.1)]),
         (constrain(int(5), 1, (NUM_LEDS - constrain(Pixel, 1, NUM_LEDS) + 1))),
         CHSV( val2, 255, val3) );
         FastLED.show();
      for (Dimmer = 1; Dimmer <= 122; Dimmer++) {
            leds[int(constrain(Dimmer, 1, NUM_LEDS) - 0.1)].fadeToBlackBy( val1*2.55 );
      delay(val0);
   for (Pixel = NUM_LEDS-4; Pixel >= 2; Pixel--) {
         FastLED.show();
      for (Dimmer = 1; Dimmer <= NUM_LEDS; Dimmer++) {
      delay(val0);
Hope someone can help me with that
Greetings
Björn
If you want it to run only once, put it in setup(). The FastLED library has many examples, including fade which you could use as a starting point. Try that. If you get stuck, post your best attempt, the errors and folks can help.
Okay i found a solution, just googled for fastled (which was the key btw) and found a fade out animation sample. Thanks for putting me in the right way :slight_smile:
      FastLED.clear ();
      fadeAnimation(0, 255, 0);
void fadeAnimation(int red, int green, int blue){
  float r, g, b;
  // FADE OUT
  for(int i = 255; i >= 0; i--) {
    r = (i/256.0)*red;
    g = (i/256.0)*green;
    b = (i/256.0)*blue;
    fill_solid(leds, NUM_LEDS, CRGB(r, g, b));
    FastLED.show();
    delay(3);
Functions can't be defined inside functions. You need at least a brace between setup() and fadeAnimation().
}    // brace to end setup function
And who knows if you have the brace that finishes fadeAnumation()?
    show();
    delay(3);
}    // closing brace for the function
HTH
a7
Can you explain what you tried to achieve in this complicated code? Why did you used a float math inside the array index? Why the Pixel iterator was declared as double?
Nevermind what i posted before, it was the very old sketch of the program. i also finally found out how to make the lights turn all on and fade out , after that the running light starts.... problem was my old arduino gave up the ghost and i think its impossible to read out the program , so i had to search on my hard drive and thought this was the right program :frowning: But finally i found a backup from the last upload on my NAS and modified it
here's that code (a combination of neopixel and fastled now)
#include <FastLED_NeoPixel.h>
#define MAX_P 122
CRGB leds[MAX_P];
Adafruit_NeoPixel strip = Adafruit_NeoPixel(MAX_P, 3, NEO_BRG + NEO_KHZ800);
int potPin0 = 0;    // select the input pin for the potentiometer
int potPin1 = 1;    // select the input pin for the potentiometer
int val0 = 0;       // variable to store the value coming from the sensor
int val1 = 0;       // variable to store the value coming from the sensor
int li=0;
int direction=+1;
uint32_t Red=strip.Color(255, 0, 0);
uint32_t Blank=strip.Color(0, 0, 0);
      FastLED.addLeds<NEOPIXEL, 3>(leds, MAX_P);
      FastLED.clear ();
      fadeAnimation(255, 0, 0);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  val0 = analogRead(potPin0) / 50;    // read the value from the sensor
  val1 = analogRead(potPin1) / 34.1;    // read the value from the sensor
  //decay
  for(uint16_t i=0; i<MAX_P; i++) {
    uint8_t r= (strip.getPixelColor(i)>>16) & 0xff;
    r=(r*(69+val1))/100;
      strip.setPixelColor(i, r, 0, 0);
  strip.setPixelColor(li, Red);
  if(li>(MAX_P-1)){
    li=MAX_P;
    direction=-1;
  }else if(li<0){
    li=-1;
    direction=1;
  li+=direction;
  strip.show();
  delay(val0);
  float r, g, b;
  // FADE OUT
    r = (i/256.0)*red;
    b = (i/256.0)*blue;
    fill_solid(leds, MAX_P, CRGB(r, g, b));
    FastLED.show();
    delay(8);
