Hey guys why is my color on my leds not scync?
if you use FastLED you got options to get CHSV to RGB or oposit
and ofcause you can Calibrate your Ambilight to fit your need on CHSV
the Full 360 Colorcycle
try it out
bmbbsr:
if you use FastLED you got options to get CHSV to RGB or opositand ofcause you can Calibrate your Ambilight to fit your need on CHSV
the Full 360 Colorcycletry it out
How on Earth does that solve any problem of synchronising lights with the colour?
It looks to me like the signal from the TV is 90 degrees rotated to the lights, so fix your TV signal or simpler move your LEDs 90 degrees anti-clockwise.
thathas been my idee to offset the circle by 90deg or whatever he needs to see
his view he wants
match easyer on HSV then on rgb
and the conversion is as easy as a rgb2hsv
or hsv2rgb
No the match is already there, so no need for any of that.
