led strip WS2812B not fully switch on
Hello
I noob in arduino and I tried to use it with a WS2812B 5v led strip.
To do that I have :
  • arduino Uno
  • 120 WS2812B leds on a strip 5v
  • power 5v/20A
  • a capacitor on the led power
  • a R470 between the arduino output and the led data
I use the sandtest of neo pixel library like that :
#define PIN 5
Adafruit_NeoPixel strip = Adafruit_NeoPixel(120, PIN, NEO_GRB + NEO_KHZ800);
But just approximately 60 leds are used. I really don't know why.
I tested the volt between the ground (on alim) and the last led (who is switch off) and I have 5v. Same thing with the data cable.
And when I switch on the power of the leds (arduino is on USB) some leds after num 60 stay on in a random color (so they are not dead). The strip.show(); is done juste on the 60 first leds.
I want to understand what is the issue. Why all my led are not on ?
Somebody have an idea ?
Thank you
These may power up in undefined conditions.
Either physically remove them from the string or define the actual LED count total in your code.
Always show us you complete sketch.
Use the </> icon in the posting menu to bring up code tags.
The full code is
#ifdef __AVR__
  #include <avr/power.h>
#endif
#define PIN 5
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel.  Avoid connecting
// on a live circuit...if you must, connect GND first.
  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
  #if defined (__AVR_ATtiny85__)
    if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
  #endif
  // End of trinket special code
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // Some example procedures showing how to display to the pixels:
  colorWipe(strip.Color(255, 0, 0), 50); // Red
  colorWipe(strip.Color(0, 255, 0), 50); // Green
  colorWipe(strip.Color(0, 0, 255), 50); // Blue
//colorWipe(strip.Color(0, 0, 0, 255), 50); // White RGBW
  // Send a theater pixel chase in...
  theaterChase(strip.Color(127, 127, 127), 50); // White
  theaterChase(strip.Color(127, 0, 0), 50); // Red
  theaterChase(strip.Color(0, 0, 127), 50); // Blue
  rainbow(20);
  rainbowCycle(20);
  theaterChaseRainbow(50);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (uint16_t i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      strip.show();
      delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
I defined the good count of led in the code (see 120 above). But it like the arduino can't handle all the leds. I checked the ram and I have more 1200 free.
I tried with another led strip, I have the same statement.
I tried with another arduino Uno -> same statement.
I tried with a compter power supply -> same statement.
Do I have error in my setup or code ?
I always worry when you have an incorrect comment by a piece of code.
That statement does not do that function, it simply shows what you have in the array, which at this time you have not defined.
Also some other stuff is a little odd.
Try this code and see if it works for the full 120 LEDs
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN            5
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS      120
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 500; // delay for half a second
  pixels.begin(); // This initializes the NeoPixel library.
  // For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one.
  for(int i=0; i<NUMPIXELS; i++){
    // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
    pixels.setPixelColor(i, pixels.Color(150,0,0)); // Moderately bright green color.
    pixels.show(); // This sends the updated pixel color to the hardware.
    delay(delayval); // Delay for a period of time (in milliseconds).
    for(int i=0;i<NUMPIXELS;i++){
    pixels.setPixelColor(i, pixels.Color(0,0,0)); // Black
How many exactly? Was it the exact same number with the replacement strip?
