Led was not declared in this scope (fastled)
hello,
I don't know which topic is it sorry for confusing
I used fastled for a project but it says an error
#include <WiFi.h>
#include <WebServer.h>
#include <FastLED.h>
#include <DNSServer.h>
#include <Preferences.h>  // Pour la persistence des paramètres
#include "site final.html"
// ==== CONFIG =====
#define LED_PIN     12
#define NUM_LEDS    30
#define LED_TYPE    WS2812B
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
const char* ap_ssid = "ESP32-LED";
const char* ap_password = "12345678";
WebServer server(80);
DNSServer dnsServer;
Preferences preferences;  // Objet pour le stockage persistant
// ==== VARIABLES ====
CRGB selectedColor = CRGB::Red;
int brightness = 128;
String currentEffect = "off";
unsigned long speed = 150;
// Variables d'animation
unsigned long previousMillis = 0;
uint16_t rainbowPosition = 0;
uint8_t serpentPosition = 0;
// ==== HTML PAGE ====
const char MAIN_page[] PROGMEM = "site final.html";
// ==== FONCTIONS DE STOCKAGE ====
void saveSettings() {
  preferences.begin("ledctrl", true);
  // Convertir CRGB en uint32_t (0xRRGGBB)
  uint32_t rgbColor = (selectedColor.r << 16) | (selectedColor.g << 8) | selectedColor.b;
  preferences.putUInt("color", rgbColor);
  preferences.putUInt("brightness", brightness);
  preferences.putString("effect", currentEffect.c_str());
  preferences.putULong("speed", speed);
  preferences.end();
void loadSettings() {
  uint32_t rgbColor = preferences.getUInt("color", 0xFF0000); // Rouge par défaut
  selectedColor = CRGB((rgbColor >> 16) & 0xFF, (rgbColor >> 8) & 0xFF, rgbColor & 0xFF);
  brightness = preferences.getUInt("brightness", 128);
  currentEffect = preferences.getString("effect", "off");
  speed = preferences.getULong("speed", 150);
  if (currentEffect == "rainbowAll" && preferences.getString("effect", "") == "rainbow") {
    currentEffect = "rainbow";
  preferences.end();
// ==== HANDLERS ====
void handleRoot() {
  server.send(200, "text/html", MAIN_page);
void handleSetColor() {
  if (server.hasArg("color")) {
    String hex = server.arg("color");
    hex.remove(0, 1); // Retire le #
    long rgb = strtol(hex.c_str(), NULL, 16);
    selectedColor = CRGB((rgb >> 16) & 0xFF, (rgb >> 8) & 0xFF, rgb & 0xFF);
    if (currentEffect == "all") allOn();
    saveSettings();
    server.send(200, "text/plain", "OK");
void handleSetBrightness() {
  if (server.hasArg("brightness")) {
    brightness = server.arg("brightness").toInt();
    FastLED.setBrightness(brightness);
    FastLED.show();
    saveSettings();  // Sauvegarde après modification
void handleSetSpeed() {
  if (server.hasArg("speed")) {
    speed = map(server.arg("speed").toInt(), 5, 1000, 1000, 5);
void handleSetEffect() {
  if (server.hasArg("effect")) {
    String newEffect = server.arg("effect");
    // Gestion spéciale pour le mode Rainbow
    if (currentEffect == "rainbow" && newEffect == "rainbowAll") {
      currentEffect = "rainbowAll";
    else if (currentEffect == "rainbowAll" && newEffect == "rainbow") {
    else {
      currentEffect = newEffect;
    // Applique l'effet
    if (currentEffect == "off") allOff();
    else if (currentEffect == "all") allOn();
    saveSettings();
void handleGetSettings() {
  String json = "{";
  json += "\"color\":\"" + String(selectedColor.r) + "," + String(selectedColor.g) + "," + String(selectedColor.b) + "\",";
  json += "\"brightness\":" + String(brightness) + ",";
  json += "\"effect\":\"" + currentEffect + "\",";
  json += "\"speed\":" + String(speed);
  json += "}";
  server.send(200, "application/json", json);
void handleNotFound() {
  server.sendHeader("Location", String("http://") + server.client().localIP().toString(), true);
  server.send(302, "text/plain", "");
// ==== LED EFFECTS ====
// (Vos fonctions d'effets restent inchangées)
void allOn() {
  fill_solid(leds, NUM_LEDS, selectedColor);
  FastLED.show();
void allOff() {
  fill_solid(leds, NUM_LEDS, CRGB::Black);
  FastLED.show();
void serpentAnimation() {
  if (currentMillis - previousMillis >= speed) {
    for (uint8_t i = 0; i < NUM_LEDS; i++) {
      if ((i + serpentPosition) % 6 < 3) {
        leds[i] = selectedColor;
    FastLED.show();
    serpentPosition = (serpentPosition + 1) % 6;
void rainbowAnimation() {
  // Multiply speed by 10 only for rainbow effect
  if (currentMillis - previousMillis >= (speed / 20)) {
      leds[i] = Wheel(((i * 256 / NUM_LEDS) + rainbowPosition) & 255);
    FastLED.show();
    rainbowPosition = (rainbowPosition + 1) % 256;
CRGB Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return CRGB(255 - WheelPos * 3, 0, WheelPos * 3);
  } else if(WheelPos < 170) {
    WheelPos -= 85;
    return CRGB(0, WheelPos * 3, 255 - WheelPos * 3);
    WheelPos -= 170;
    return CRGB(WheelPos * 3, 255 - WheelPos * 3, 0);
void rainbowAll() {
  static unsigned long lastUpdate = 0;
  static uint16_t hue = 0;  // Using 16-bit for smoother transitions
  // Calculate time since last update (non-blocking)
  if (currentMillis - lastUpdate >= 30) {  // Fixed refresh rate for smoothness
    lastUpdate = currentMillis;
    // Increment hue with speed adjustment (16-bit for precision)
    uint8_t hueIncrement = map(speed, 5, 1000, 1, 120);
    hue += hueIncrement;
    // Apply to all LEDs
    fill_solid(leds, NUM_LEDS, CHSV(hue >> 8, 255, 255));  // Use upper 8 bits
    FastLED.show();
    EVERY_N_MILLISECONDS(5) {}
// ==== SETUP / LOOP ====
  // Initialize FastLED FIRST
  FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  // Then load settings
  loadSettings();
  // Appliquer l'effet au démarrage
  WiFi.softAP(ap_ssid, ap_password);
  dnsServer.start(53, "*", WiFi.softAPIP());
  server.on("/", handleRoot);
  server.on("/setColor", handleSetColor);
  server.on("/setBrightness", handleSetBrightness);
  server.on("/setSpeed", handleSetSpeed);
  server.on("/setEffect", handleSetEffect);
  server.on("/getSettings", handleGetSettings);
  server.onNotFound(handleNotFound);
  server.begin();
  dnsServer.processNextRequest();
  server.handleClient();
  if (currentEffect == "serpent") serpentAnimation();
  else if (currentEffect == "rainbow") rainbowAnimation();
  else if (currentEffect == "rainbowAll") rainbowAll();
here the html
R"rawliteral(
<!DOCTYPE html>
<html lang="fr">
<head>
  <meta charset="UTF-8">
  <meta name="viewport" content="width=device-width, initial-scale=1.0">
  <title>LED Controller</title>
  <style>
    :root {
  --active-color: #1e88e5;
body {
  font-family: 'Calibri';
  background: #121212;
  color: white;
  display: flex;
  flex-direction: column;
  align-items: center;
  min-height: 100vh;
  margin: 0;
  padding: 20px;
.slider-container {
  width: 80%;
  max-width: 400px;
  margin: 20px 0;
.slider-label {
  display: flex;
  justify-content: space-between;
  margin-bottom: 10px;
  font-weight: bold;
input[type="range"].styled-slider {
  -webkit-appearance: none;
  width: 100%;
  height: 10px;
  background: #ddd;
  border-radius: 5px;
  outline: none;
input[type="range"].styled-slider::-webkit-slider-thumb {
  appearance: none;
  width: 20px;
  height: 20px;
  background: #333;
  border-radius: 50%;
  cursor: pointer;
  transition: background 0.2s ease;
input[type="range"].styled-slider:hover::-webkit-slider-thumb {
  background: #555;
.effects-panel {
  display: flex;
  gap: 15px;
  margin-top: 40px;
  flex-wrap: wrap;
  justify-content: center;
.effect-btn {
  background: #333;
  color: white;
  border: none;
  padding: 12px 25px;
  border-radius: 30px;
  font-size: 16px;
  cursor: pointer;
  text-transform: uppercase;
  letter-spacing: 1px;
  font-weight: bold;
  transition: all 0.3s;
  box-shadow: 0 4px 8px rgba(0,0,0,0.3);
  min-width: 120px;
  text-align: center;
.effect-btn.active {
  background: var(--active-color);
  box-shadow: 0 0 15px rgba(30, 136, 229, 0.5);
.color-preview {
  width: 80px;
  height: 80px;
  border-radius: 50%;
  border: 3px solid #444;
  background-color: #ff0000;
  box-shadow: 0 0 15px rgba(0,0,0,0.5);
  margin: 20px auto;
.rainbow-slider {
  width: 80%;
  max-width: 300px;
  margin: 0 auto;
.rainbow-slider input[type="range"] {
  width: 100%;
  height: 15px;
  border-radius: 10px;
  background: linear-gradient(to right,
    #ff0000, #ff8000, #ffff00, #80ff00,
    #00ff00, #00ff80, #00ffff, #0080ff,
    #0000ff, #8000ff, #ff00ff, #ff0080, #ff0000);
  outline: none;
  margin: 15px 0;
.rainbow-slider input[type="range"]::-webkit-slider-thumb {
  width: 25px;
  height: 25px;
  border-radius: 50%;
  background: white;
  border: 3px solid #121212;
  cursor: pointer;
  box-shadow: 0 0 5px rgba(0,0,0,0.5);
    #rainbowBtn.active[data-mode="rainbowAll"] {
  background: linear-gradient(90deg,
    #0000ff, #8000ff, #ff00ff, #ff0080);
#rainbowBtn.active[data-mode="rainbow"] {
    #ff0000, #ffff00, #00ff00, #00ffff,
    #0000ff, #ff00ff);
  </style>
</head>
<body>
  <h1>CONTROL PANEL</h1>
  <div id="connectionStatus" style="position: fixed; top: 10px; right: 10px; background: #4CAF50; color: white; padding: 5px 10px; border-radius: 20px; display: none;">
    Connecté
  <div class="rainbow-slider">
  <div class="color-preview" id="colorPreview"></div>
  <input type="range" id="hueSlider" min="0" max="360" value="0">
  <div class="slider-label">
    <span>COULEUR</span>
  </div>
</div>
<div class="slider-container">
    <span>LUMINOSITÉ</span>
    <span id="brightnessValue">50%</span>
  </div>
  <input type="range" class="styled-slider" id="brightnessSlider" min="0" max="255" value="128">
</div>
    <span>VITESSE</span>
  </div>
  <input type="range" class="styled-slider" id="speedSlider" min="5" max="1000" value="150">
</div>
<div class="effects-panel">
  <button class="effect-btn" id="serpentBtn">SERPENT</button>
  <button class="effect-btn" id="rainbowBtn" data-mode="rainbowAll">RAINBOW</button>
  <button class="effect-btn" id="allBtn">ON</button>
  <button class="effect-btn" id="offBtn">OFF</button>
</div>
  <script>
    // Éléments DOM
    const hueSlider = document.getElementById('hueSlider');
    const brightnessSlider = document.getElementById('brightnessSlider');
    const speedSlider = document.getElementById('speedSlider');
    const colorPreview = document.getElementById('colorPreview');
    const brightnessValue = document.getElementById('brightnessValue');
    const connectionStatus = document.getElementById('connectionStatus');
    // Conversion RGB vers Teinte (HSV)
    function rgbToHue(r, g, b) {
      r /= 255, g /= 255, b /= 255;
      const max = Math.max(r, g, b), min = Math.min(r, g, b);
      let h = 0;
      if (max === min) h = 0;
      else if (max === r) h = (60 * ((g - b) / (max - min)) + 360) % 360;
      else if (max === g) h = (60 * ((b - r) / (max - min)) + 120) % 360;
      else h = (60 * ((r - g) / (max - min)) + 240) % 360;
      return Math.round(h);
    // Remplacez la gestion du bouton Rainbow par ceci :
document.getElementById('rainbowBtn').addEventListener('click', function() {
  const isActive = this.classList.contains('active');
  const currentEffect = isActive ? 'off' :
                      (this.dataset.mode === 'rainbow' ? 'rainbowAll' : 'rainbow');
  // Bascule le mode pour le prochain clic
  this.dataset.mode = (this.dataset.mode === 'rainbow' ? 'rainbowAll' : 'rainbow');
  setEffect(currentEffect);
// Modifiez setEffect() pour gérer le mode
function setEffect(effect) {
  fetch('/setEffect?effect=' + effect)
    .then(() => {
      const rainbowBtn = document.getElementById('rainbowBtn');
      // Réinitialise tous les boutons
      document.querySelectorAll('.effect-btn').forEach(btn => {
        btn.classList.remove('active');
      // Met à jour l'état actif
      if (effect === 'rainbow' || effect === 'rainbowAll') {
        rainbowBtn.classList.add('active');
        rainbowBtn.dataset.mode = (effect === 'rainbow' ? 'rainbowAll' : 'rainbow');
        document.getElementById(effect + 'Btn').classList.add('active');
    // Charger les paramètres depuis l'ESP32
    function loadSettings() {
      fetch('/getSettings')
        .then(response => response.json())
        .then(settings => {
          const [r, g, b] = settings.color.split(',').map(Number);
          const hue = rgbToHue(r, g, b);
          hueSlider.value = hue;
          brightnessSlider.value = settings.brightness;
          speedSlider.value = settings.speed;
          updateColor();
          updateSliderValues();
            if (btn.id === settings.effect + 'Btn') btn.classList.add('active');
          showConnectionStatus();
    function showConnectionStatus() {
      connectionStatus.style.display = 'block';
      setTimeout(() => connectionStatus.style.display = 'none', 2000);
    // Éléments DOM
// Conversion en pourcentage
function toPercent(value, min, max) {
  return Math.round(((value - min) / (max - min)) * 100);
// Mise à jour des valeurs en %
function updateSliderValues() {
  brightnessValue.textContent = toPercent(brightnessSlider.value, 0, 255) + '%';
// Conversion teinte vers RGB
function hueToRgb(h) {
  h /= 60;
  const c = 255;
  const x = (1 - Math.abs(h % 2 - 1)) * 255;
  let r, g, b;
  if (h >= 0 && h < 1) { [r,g,b] = [c,x,0]; }
  else if (h < 2) { [r,g,b] = [x,c,0]; }
  else if (h < 3) { [r,g,b] = [0,c,x]; }
  else if (h < 4) { [r,g,b] = [0,x,c]; }
  else if (h < 5) { [r,g,b] = [x,0,c]; }
  else { [r,g,b] = [c,0,x]; }
  return {r: Math.round(r), g: Math.round(g), b: Math.round(b)};
// Mise à jour couleur
function updateColor() {
  const hue = hueSlider.value;
  const color = hueToRgb(hue);
  const hex = `#${color.r.toString(16).padStart(2,'0')}${color.g.toString(16).padStart(2,'0')}${color.b.toString(16).padStart(2,'0')}`;
  colorPreview.style.backgroundColor = `rgb(${color.r}, ${color.g}, ${color.b})`;
  colorPreview.style.boxShadow = `0 0 20px rgba(${color.r}, ${color.g}, ${color.b}, 0.7)`;
  fetch('/setColor?color=' + encodeURIComponent(hex));
// Écouteurs d'événements
hueSlider.addEventListener('input', updateColor);
brightnessSlider.addEventListener('input', () => {
  fetch('/setBrightness?brightness=' + brightnessSlider.value);
speedSlider.addEventListener('input', () => {
  fetch('/setSpeed?speed=' + speedSlider.value);
// Gestion des effets
    .then(() => {
        if (btn.id === effect + 'Btn') btn.classList.add('active');
// Assignation des événements aux boutons
document.getElementById('serpentBtn').addEventListener('click', () => setEffect('serpent'));
document.getElementById('rainbowBtn').addEventListener('click', () => setEffect('rainbow'));
document.getElementById('rainbowAllBtn').addEventListener('click', () => setEffect('rainbowAll'));
document.getElementById('allBtn').addEventListener('click', () => setEffect('all'));
document.getElementById('offBtn').addEventListener('click', () => setEffect('off'));
// Initialisation
updateColor();
setEffect('off');
    document.addEventListener('DOMContentLoaded', loadSettings);
  </script>
</body>
</html>
)rawliteral"
thank you for your help
Please copy and paste the exact error message.
Copy the verbose error log and paste into code tags like the source.
Where did you declare this variable? "leds"
" fill_solid(leds, NUM_LEDS, selectedColor); "
You declared this variable:
What board is this for
alright thank you for your responses
this code is for an ESP32 devkit v4
here the error :
C:\Users\ordi2405239\Desktop\beandeauLed/site final.html:1:1: error: expected unqualified-id before string constant
    1 | R"rawliteral(
    2 | <!DOCTYPE html>
    3 | <html lang="fr">
    4 | <head>
    5 |   <meta charset="UTF-8">
    6 |   <meta name="viewport" content="width=device-width, initial-scale=1.0">
    7 |   <title>LED Controller</title>
    8 |   <style>
    9 |     :root {
   10 |   --active-color: #1e88e5;
   11 | }
   12 |
   13 | body {
   14 |   font-family: 'Calibri';
   15 |   background: #121212;
   16 |   color: white;
   17 |   display: flex;
   18 |   flex-direction: column;
   19 |   align-items: center;
   20 |   min-height: 100vh;
   21 |   margin: 0;
   22 |   padding: 20px;
   23 | }
   24 |
   25 | .slider-container {
   26 |   width: 80%;
   27 |   max-width: 400px;
   28 |   margin: 20px 0;
   29 | }
   30 |
   31 | .slider-label {
   32 |   display: flex;
   33 |   justify-content: space-between;
   34 |   margin-bottom: 10px;
   35 |   font-weight: bold;
   36 | }
   37 |
   38 | input[type="range"].styled-slider {
   39 |   -webkit-appearance: none;
   40 |   width: 100%;
   41 |   height: 10px;
   42 |   background: #ddd;
   43 |   border-radius: 5px;
   44 |   outline: none;
   45 | }
   46 |
   47 | input[type="range"].styled-slider::-webkit-slider-thumb {
   48 |   -webkit-appearance: none;
   49 |   appearance: none;
   50 |   width: 20px;
   51 |   height: 20px;
   52 |   background: #333;
   53 |   border-radius: 50%;
   54 |   cursor: pointer;
   55 |   transition: background 0.2s ease;
   56 | }
   57 |
   58 | input[type="range"].styled-slider:hover::-webkit-slider-thumb {
   59 |   background: #555;
   60 | }
   61 |
   62 | .effects-panel {
   63 |   display: flex;
   64 |   gap: 15px;
   65 |   margin-top: 40px;
   66 |   flex-wrap: wrap;
   67 |   justify-content: center;
   68 | }
   69 |
   70 | .effect-btn {
   71 |   background: #333;
   72 |   color: white;
   73 |   border: none;
   74 |   padding: 12px 25px;
   75 |   border-radius: 30px;
   76 |   font-size: 16px;
   77 |   cursor: pointer;
   78 |   text-transform: uppercase;
   79 |   letter-spacing: 1px;
   80 |   font-weight: bold;
   81 |   transition: all 0.3s;
   82 |   box-shadow: 0 4px 8px rgba(0,0,0,0.3);
   83 |   min-width: 120px;
   84 |   text-align: center;
   85 | }
   86 |
   87 | .effect-btn.active {
   88 |   background: var(--active-color);
   89 |   box-shadow: 0 0 15px rgba(30, 136, 229, 0.5);
   90 | }
   91 |
   92 | .color-preview {
   93 |   width: 80px;
   94 |   height: 80px;
   95 |   border-radius: 50%;
   96 |   border: 3px solid #444;
   97 |   background-color: #ff0000;
   98 |   box-shadow: 0 0 15px rgba(0,0,0,0.5);
   99 |   margin: 20px auto;
  100 | }
  101 |
  102 | .rainbow-slider {
  103 |   width: 80%;
  104 |   max-width: 300px;
  105 |   margin: 0 auto;
  106 | }
  107 |
  108 | .rainbow-slider input[type="range"] {
  109 |   -webkit-appearance: none;
  110 |   width: 100%;
  111 |   height: 15px;
  112 |   border-radius: 10px;
  113 |   background: linear-gradient(to right,
  114 |     #ff0000, #ff8000, #ffff00, #80ff00,
  115 |     #00ff00, #00ff80, #00ffff, #0080ff,
  116 |     #0000ff, #8000ff, #ff00ff, #ff0080, #ff0000);
  117 |   outline: none;
  118 |   margin: 15px 0;
  119 | }
  120 |
  121 | .rainbow-slider input[type="range"]::-webkit-slider-thumb {
  122 |   -webkit-appearance: none;
  123 |   width: 25px;
  124 |   height: 25px;
  125 |   border-radius: 50%;
  126 |   background: white;
  127 |   border: 3px solid #121212;
  128 |   cursor: pointer;
  129 |   box-shadow: 0 0 5px rgba(0,0,0,0.5);
  130 | }
  131 |     #rainbowBtn.active[data-mode="rainbowAll"] {
  132 |   background: linear-gradient(90deg,
  133 |     #ff0000, #ff8000, #ffff00, #80ff00,
  134 |     #00ff00, #00ff80, #00ffff, #0080ff,
  135 |     #0000ff, #8000ff, #ff00ff, #ff0080);
  136 | }
  137 |
  138 | #rainbowBtn.active[data-mode="rainbow"] {
  139 |   background: linear-gradient(90deg,
  140 |     #ff0000, #ffff00, #00ff00, #00ffff,
  141 |     #0000ff, #ff00ff);
  142 | }
  143 |   </style>
  144 | </head>
  145 | <body>
  146 |   <h1>CONTROL PANEL</h1>
  147 |   <div id="connectionStatus" style="position: fixed; top: 10px; right: 10px; background: #4CAF50; color: white; padding: 5px 10px; border-radius: 20px; display: none;">
  148 |     Connecté
  149 |   <div class="rainbow-slider">
  150 |   <div class="color-preview" id="colorPreview"></div>
  151 |   <input type="range" id="hueSlider" min="0" max="360" value="0">
  152 |   <div class="slider-label">
  153 |     <span>COULEUR</span>
  154 |   </div>
  155 | </div>
  156 |
  157 | <div class="slider-container">
  158 |   <div class="slider-label">
  159 |     <span>LUMINOSITÉ</span>
  160 |     <span id="brightnessValue">50%</span>
  161 |   </div>
  162 |   <input type="range" class="styled-slider" id="brightnessSlider" min="0" max="255" value="128">
  163 | </div>
  164 |
  165 | <div class="slider-container">
  166 |   <div class="slider-label">
  167 |     <span>VITESSE</span>
  168 |   </div>
  169 |   <input type="range" class="styled-slider" id="speedSlider" min="5" max="1000" value="150">
  170 | </div>
  171 |
  172 | <div class="effects-panel">
  173 |   <button class="effect-btn" id="serpentBtn">SERPENT</button>
  174 |   <button class="effect-btn" id="rainbowBtn" data-mode="rainbowAll">RAINBOW</button>
  175 |   <button class="effect-btn" id="allBtn">ON</button>
  176 |   <button class="effect-btn" id="offBtn">OFF</button>
  177 | </div>
  178 |   <script>
  179 |     // Éléments DOM
  180 |     const hueSlider = document.getElementById('hueSlider');
  181 |     const brightnessSlider = document.getElementById('brightnessSlider');
  182 |     const speedSlider = document.getElementById('speedSlider');
  183 |     const colorPreview = document.getElementById('colorPreview');
  184 |     const brightnessValue = document.getElementById('brightnessValue');
  185 |     const connectionStatus = document.getElementById('connectionStatus');
  186 |
  187 |     // Conversion RGB vers Teinte (HSV)
  188 |     function rgbToHue(r, g, b) {
  189 |       r /= 255, g /= 255, b /= 255;
  190 |       const max = Math.max(r, g, b), min = Math.min(r, g, b);
  191 |       let h = 0;
  192 |       if (max === min) h = 0;
  193 |       else if (max === r) h = (60 * ((g - b) / (max - min)) + 360) % 360;
  194 |       else if (max === g) h = (60 * ((b - r) / (max - min)) + 120) % 360;
  195 |       else h = (60 * ((r - g) / (max - min)) + 240) % 360;
  196 |       return Math.round(h);
  197 |     }
  198 |     // Remplacez la gestion du bouton Rainbow par ceci :
  199 | document.getElementById('rainbowBtn').addEventListener('click', function() {
  200 |   const isActive = this.classList.contains('active');
  201 |   const currentEffect = isActive ? 'off' :
  202 |                       (this.dataset.mode === 'rainbow' ? 'rainbowAll' : 'rainbow');
  203 |
  204 |   // Bascule le mode pour le prochain clic
  205 |   this.dataset.mode = (this.dataset.mode === 'rainbow' ? 'rainbowAll' : 'rainbow');
  206 |
  207 |   setEffect(currentEffect);
  208 | });
  209 |
  210 | // Modifiez setEffect() pour gérer le mode
  211 | function setEffect(effect) {
  212 |   fetch('/setEffect?effect=' + effect)
  213 |     .then(() => {
  214 |       const rainbowBtn = document.getElementById('rainbowBtn');
  215 |
  216 |       // Réinitialise tous les boutons
  217 |       document.querySelectorAll('.effect-btn').forEach(btn => {
  218 |         btn.classList.remove('active');
  219 |       });
  220 |
  221 |       // Met à jour l'état actif
  222 |       if (effect === 'rainbow' || effect === 'rainbowAll') {
  223 |         rainbowBtn.classList.add('active');
  224 |         rainbowBtn.dataset.mode = (effect === 'rainbow' ? 'rainbowAll' : 'rainbow');
  225 |       } else {
  226 |         document.getElementById(effect + 'Btn').classList.add('active');
  227 |       }
  228 |     });
  229 | }
  230 |
  231 |     // Charger les paramètres depuis l'ESP32
  232 |     function loadSettings() {
  233 |       fetch('/getSettings')
  234 |         .then(response => response.json())
  235 |         .then(settings => {
  236 |           const [r, g, b] = settings.color.split(',').map(Number);
  237 |           const hue = rgbToHue(r, g, b);
  238 |           hueSlider.value = hue;
  239 |           brightnessSlider.value = settings.brightness;
  240 |           speedSlider.value = settings.speed;
  241 |           updateColor();
  242 |           updateSliderValues();
  243 |           document.querySelectorAll('.effect-btn').forEach(btn => {
  244 |             btn.classList.remove('active');
  245 |             if (btn.id === settings.effect + 'Btn') btn.classList.add('active');
  246 |           });
  247 |           showConnectionStatus();
  248 |         });
  249 |     }
  250 |
  251 |     function showConnectionStatus() {
  252 |       connectionStatus.style.display = 'block';
  253 |       setTimeout(() => connectionStatus.style.display = 'none', 2000);
  254 |     }
  255 |
  256 |     // Éléments DOM
  257 | const hueSlider = document.getElementById('hueSlider');
  258 | const brightnessSlider = document.getElementById('brightnessSlider');
  259 | const speedSlider = document.getElementById('speedSlider');
  260 | const colorPreview = document.getElementById('colorPreview');
  261 | const brightnessValue = document.getElementById('brightnessValue');
  262 |
  263 | // Conversion en pourcentage
  264 | function toPercent(value, min, max) {
  265 |   return Math.round(((value - min) / (max - min)) * 100);
  266 | }
  267 |
  268 | // Mise à jour des valeurs en %
  269 | function updateSliderValues() {
  270 |   brightnessValue.textContent = toPercent(brightnessSlider.value, 0, 255) + '%';
  271 | }
  272 |
  273 | // Conversion teinte vers RGB
  274 | function hueToRgb(h) {
  275 |   h /= 60;
  276 |   const c = 255;
  277 |   const x = (1 - Math.abs(h % 2 - 1)) * 255;
  278 |   let r, g, b;
  279 |
  280 |   if (h >= 0 && h < 1) { [r,g,b] = [c,x,0]; }
  281 |   else if (h < 2) { [r,g,b] = [x,c,0]; }
  282 |   else if (h < 3) { [r,g,b] = [0,c,x]; }
  283 |   else if (h < 4) { [r,g,b] = [0,x,c]; }
  284 |   else if (h < 5) { [r,g,b] = [x,0,c]; }
  285 |   else { [r,g,b] = [c,0,x]; }
  286 |
  287 |   return {r: Math.round(r), g: Math.round(g), b: Math.round(b)};
  288 | }
  289 |
  290 | // Mise à jour couleur
  291 | function updateColor() {
  292 |   const hue = hueSlider.value;
  293 |   const color = hueToRgb(hue);
  294 |   const hex = `#${color.r.toString(16).padStart(2,'0')}${color.g.toString(16).padStart(2,'0')}${color.b.toString(16).padStart(2,'0')}`;
  295 |
  296 |   colorPreview.style.backgroundColor = `rgb(${color.r}, ${color.g}, ${color.b})`;
  297 |   colorPreview.style.boxShadow = `0 0 20px rgba(${color.r}, ${color.g}, ${color.b}, 0.7)`;
  298 |   fetch('/setColor?color=' + encodeURIComponent(hex));
  299 |   updateSliderValues();
  300 | }
  301 |
  302 | // Écouteurs d'événements
  303 | hueSlider.addEventListener('input', updateColor);
  304 | brightnessSlider.addEventListener('input', () => {
  305 |   updateSliderValues();
  306 |   fetch('/setBrightness?brightness=' + brightnessSlider.value);
  307 | });
  308 | speedSlider.addEventListener('input', () => {
  309 |   updateSliderValues();
  310 |   fetch('/setSpeed?speed=' + speedSlider.value);
  311 | });
  312 |
  313 | // Gestion des effets
  314 | function setEffect(effect) {
  315 |   fetch('/setEffect?effect=' + effect)
  316 |     .then(() => {
  317 |       document.querySelectorAll('.effect-btn').forEach(btn => {
  318 |         btn.classList.remove('active');
  319 |         if (btn.id === effect + 'Btn') btn.classList.add('active');
  320 |       });
  321 |     });
  322 | }
  323 |
  324 | // Assignation des événements aux boutons
  325 | document.getElementById('serpentBtn').addEventListener('click', () => setEffect('serpent'));
  326 | document.getElementById('rainbowBtn').addEventListener('click', () => setEffect('rainbow'));
  327 | document.getElementById('rainbowAllBtn').addEventListener('click', () => setEffect('rainbowAll'));
  328 | document.getElementById('allBtn').addEventListener('click', () => setEffect('all'));
  329 | document.getElementById('offBtn').addEventListener('click', () => setEffect('off'));
  330 |
  331 | // Initialisation
  332 | updateColor();
  333 | updateSliderValues();
  334 | setEffect('off');
  335 |     document.addEventListener('DOMContentLoaded', loadSettings);
  336 |   </script>
  337 | </body>
  338 | </html>
  339 | )rawliteral"
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino: In function 'void allOn()':
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino:139:14: error: 'leds' was not declared in this scope
  139 |   fill_solid(leds, NUM_LEDS, selectedColor);
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino: In function 'void allOff()':
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino:144:14: error: 'leds' was not declared in this scope
  144 |   fill_solid(leds, NUM_LEDS, CRGB::Black);
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino: In function 'void serpentAnimation()':
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino:153:16: error: 'leds' was not declared in this scope
  153 |     fill_solid(leds, NUM_LEDS, CRGB::Black);
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino: In function 'void rainbowAnimation()':
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino:171:7: error: 'leds' was not declared in this scope
  171 |       leds[i] = Wheel(((i * 256 / NUM_LEDS) + rainbowPosition) & 255);
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino: In function 'void rainbowAll()':
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino:204:16: error: 'leds' was not declared in this scope
  204 |     fill_solid(leds, NUM_LEDS, CHSV(hue >> 8, 255, 255));  // Use upper 8 bits
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino: In function 'void setup()':
C:\Users\ordi2405239\Desktop\beandeauLed\beandeauLed.ino:215:51: error: 'leds' was not declared in this scope
  215 |   FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
Using library WiFi at version 3.2.0 in folder: C:\Users\ordi2405239\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi
Using library Networking at version 3.2.0 in folder: C:\Users\ordi2405239\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network
Using library WebServer at version 3.2.0 in folder: C:\Users\ordi2405239\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WebServer
Using library FS at version 3.2.0 in folder: C:\Users\ordi2405239\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\FS
Using library FastLED at version 3.9.16 in folder: C:\Users\ordi2405239\Documents\Arduino\libraries\FastLED
Using library DNSServer at version 3.2.0 in folder: C:\Users\ordi2405239\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\DNSServer
Using library ESP32 Async UDP at version 3.2.0 in folder: C:\Users\ordi2405239\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\AsyncUDP
Using library Preferences at version 3.2.0 in folder: C:\Users\ordi2405239\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Preferences
exit status 1
Compilation error: 'leds' was not declared in this scope````
This is the variable that you want to hold the contents of your html page.
But your html
is just a string literal so you you need to assign it to a variable. Also, you can not #include arbitrary files. I had to rename your file site_final_html.h
Move your variable declaration into the file in front of your raw string literal.
const char MAIN_page[] PROGMEM = R"rawliteral(
<!DOCTYPE html>
<html lang="fr">
<head>
ok thank you ill try but do you know how to insert a string from a document ?
Many, many people have asked the same question. Google is your friend.
ok thank you i will search it
have a nice day
