Ledc migration error code
Hey,
I m trying to code an ESP32-CAM to send photos to a MyPhP data base.
I found an old code that did exactly that but it seems to not work because of the "ledc" migration
I don t understand how to "rewrite" those lines to make it work again
Thanks
ESP32-CAM Save a captured photo(Base64) to MySQL.
Author : ChungYi Fu (Kaohsiung, Taiwan)  2019-9-28 19:00
https://www.facebook.com/francefu
Library
https://github.com/ChuckBell/MySQL_Connector_Arduino
const char* ssid = "my-wifi";
const char* password = "my-pw";
IPAddress server_addr(my-ip-with",");
int port = 3306;
char dbUser[] = "root";
char dbPassword[] = "";
String databaseName = "botanicam_db";
String tableName = "images";
String columnName = "data";   //Data Type: TEXT, MEDIUMTEXT...
#include <WiFi.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
WiFiClient client;
MySQL_Connection conn((Client *)&client);
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "Base64.h"
#include "esp_camera.h"
// WARNING!!! Make sure that you have either selected ESP32 Wrover Module,
//            or another board which has PSRAM enabled
//CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  Serial.setDebugOutput(true);
  Serial.println("");
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  long int StartTime=millis();
      if ((StartTime+10000) < millis()) break;
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println("");
    Serial.print("Camera Ready! Use 'http://");
    Serial.print(WiFi.localIP());
    Serial.println("' to connect");
    Serial.println("");
  else {
    Serial.println("Connection failed");
    ESP.restart();
    return;
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  //init with high specs to pre-allocate larger buffers
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;  //0-63 lower number means higher quality
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;  //0-63 lower number means higher quality
    config.fb_count = 1;
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    ESP.restart();
  //drop down frame size for higher initial frame rate
  sensor_t * s = esp_camera_sensor_get();
  s->set_framesize(s, FRAMESIZE_VGA);  // VGA|CIF|QVGA|HQVGA|QQVGA
  SaveCapaturedPhoto2mySQL();
  delay(10000);
void SaveCapaturedPhoto2mySQL() {
  Serial.println("Connect to mySQL");
  if (conn.connect(server_addr, port, dbUser, dbPassword)) {
    Serial.println("Connection successful");
    camera_fb_t * fb = NULL;
    fb = esp_camera_fb_get();
    if(!fb) {
      Serial.println("Camera capture failed");
      ESP.restart();
      return;
    char *input = (char *)fb->buf;
    char output[base64_enc_len(3)];
    String imageFile = "data:image/jpeg;base64,";
    for (int i=0;i<fb->len;i++) {
      base64_encode(output, (input++), 3);
      if (i%3==0) imageFile += urlencode(String(output));
    esp_camera_fb_return(fb);
    Serial.println("Image size = " + String(imageFile.length()));
    MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
    String INSERT_SQL = "INSERT INTO "+databaseName+"."+tableName+" ("+columnName+") VALUES ('"+imageFile+"')";
    cur_mem->execute(INSERT_SQL.c_str());  // How to modify the code to upload a big image? (UXGA|SXGA|XGA|SVG)
    delete cur_mem;
    Serial.println("Data stored!");
    Serial.println("");
  else {
    ledcAttach(4, 3, 5000, 8);
    ledcWrite(3,10);
    delay(200);
    ledcWrite(3,0);
    delay(200);
    ledcDetach(3);
    Serial.println("Connected to " + String(server_addr) + " failed.");
  client.stop();
//https://www.arduino.cc/reference/en/libraries/urlencode/
String urlencode(String str) {
  const char *msg = str.c_str();
  const char *hex = "0123456789ABCDEF";
  String encodedMsg = "";
  while (*msg != '\0') {
    if (('a' <= *msg && *msg <= 'z') || ('A' <= *msg && *msg <= 'Z') || ('0' <= *msg && *msg <= '9') || *msg == '-' || *msg == '_' || *msg == '.' || *msg == '~') {
      encodedMsg += *msg;
      encodedMsg += '%';
      encodedMsg += hex[(unsigned char)*msg >> 4];
      encodedMsg += hex[*msg & 0xf];
    msg++;
  return encodedMsg;
ERROR MESSAGES :
C:\Users\grego\Documents\Arduino\esp32cam\ESP32-CAM_MySQL\ESP32-CAM_MySQL.ino: In function 'void SaveCapaturedPhoto2mySQL()':
C:\Users\grego\Documents\Arduino\esp32cam\ESP32-CAM_MySQL\ESP32-CAM_MySQL.ino:174:15: error: too many arguments to function 'bool ledcAttach(uint8_t, uint32_t, uint8_t)'
174 | ledcAttach(4, 3, 5000, 8);
In file included from C:\Users\grego\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\cores\esp32/esp32-hal.h:95,
from C:\Users\grego\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\cores\esp32/Arduino.h:36,
from C:\Users\grego\AppData\Local\Temp\arduino\sketches\D65BA56BA023BD046D0810624901CBAA\sketch\ESP32-CAM_MySQL.ino.cpp:1:
C:\Users\grego\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\cores\esp32/esp32-hal-ledc.h:87:6: note: declared here
87 | bool ledcAttach(uint8_t pin, uint32_t freq, uint8_t resolution);
exit status 1
Compilation error: too many arguments to function 'bool ledcAttach(uint8_t, uint32_t, uint8_t)'
MIGRATION INFO :
https://docs.espressif.com/projects/arduino-esp32/en/latest/migration_guides/2.x_to_3.0.html#ledc
If you don't understand the instructions in the migration documentation and don't have the time to figure them out, then the quickest route would be to roll back your ESP32 core to a 2.x version. Then no code changes should be required.
how could i do that ? by dowloading an old version of the esp32 board ?
The same way you'd choose any version when installing or re-installing a core. With your IDE's board manager.
okay thanks !
