Leds (in sequence) to lcd (show delay t) to potentiometer to change delay t
I am trying to create a circuit with a potentiometer which changes the delay of the sequenced 6 leds, and then that delay time put into a formula and appears on the LCD.
im almost there but abit confused as i believe i need a code enhancement and am relatively new to using ardiunos
so every 6 leds blink i want 1 to be on the potentiometer per minute. so if the delay is 200ms between them flashing then every 1200ms:1
so 60,000/1200= 50 (the value i want to show on the display when the potentiometer is at 200ms between each led)
i need to string this value (which will be a variable and changed by pot) i believe instead.
So i need a led delay time to lcd.
The LCD display needs to display the what will be RPM which will be after every led has gone off in sequence, and the first led light up again.
For now i have managed to get the Ms of one led so the potentiometer has a display of 1023ms and works when i change the potentiometer resitance.
My problem is controlling the rate at which the delay between each led lighting up to the potentiometer.
I need to code the potentiate to the delay of all of them.
Please if you could assist as im a beginner in all of this.
I tried to connect the negative ports of leds all to the potentiometer by listing but im really stuck, im pretty sure im almost there, but need a nudge in the correct direction.
// include the library code:
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int L1 = 7;   //This assigns names to pins
int L2 = 8;
int L3 = 9;
int L4 = 10;
int L5 = 13;
int L6 = 1;
int pwmPin = 7; // assigns pin 12 to variable pwm
int pwmPin2 = 8;
int pwmPin3 = 9;
int pwmPin4 = 10;
int pwmPin5 = 13;
int pwmPin6 = 1;
int pot = A0; // assigns analog input A0 to variable pot
int t1 = 0;   // declares variable t1
int t2 = 0;   // declares variable t2
char sole[5]; //initializing a character of size 5 for showing the ADC result
int isOn = 1;
int potRead = 0;
long now = 1;
  lcd.begin(16, 2); //Registering the amount character/rows the lcd is specified at.
  lcd.setCursor(0, 0);
  lcd.setCursor(0, 1);
  lcd.print("delay:  ");
  pinMode(L1, OUTPUT); //Set the pins to coils as outputs ( LED)
  pinMode(L2, OUTPUT);
  pinMode(L3, OUTPUT);
  pinMode(L4, OUTPUT); //Set the pins to coils as outputs
  pinMode(L5, OUTPUT);
  pinMode(L6, OUTPUT);
    pinMode(pwmPin, OUTPUT);
    pinMode(pwmPin2, OUTPUT);
    pinMode(pwmPin3, OUTPUT);
    pinMode(pwmPin4, OUTPUT);
    pinMode(pwmPin5, OUTPUT);
    pinMode(pwmPin6, OUTPUT);
    pinMode(pot, INPUT);
  if (millis() > now + potRead) {
    digitalWrite(pwmPin, isOn);
    isOn = 1 - isOn;
    now = millis();
//ADD FOR RELAYS
//100ms
    // set the cursor to column 0, line 1
    lcd.print("  "); //print name
    lcd.setCursor(0, 1); // set the cursor to column 0, line
    lcd.print("delay:"); //print name
    String delay = String(analogRead(A0)); //intailizing a string and storing ADC value in it
    delay.toCharArray(sole, 5); // convert the reading to a char array
    lcd.print(sole); //
    lcd.print("   ");
    lcd.setCursor(0, 0); // set the cursor to column 0, line1
  digitalWrite(L1, HIGH);
  delay(300);
  digitalWrite(L1, LOW);
  digitalWrite(L2, HIGH);
  delay(300);
  digitalWrite(L2, LOW);
  digitalWrite(L3, HIGH);
  delay(300);
  digitalWrite(L3, LOW);
  digitalWrite(L4, HIGH);
  delay(300);
  digitalWrite(L4, LOW);
  digitalWrite(L5, HIGH);
  delay(300);
  digitalWrite(L5, LOW);
  digitalWrite(L6, HIGH);
  delay(300);
  digitalWrite(L6, LOW);
    t2 = analogRead(pot);
    t1 = 1024 - t2;      // -
Please format your code (CTRL-T in the IDE) before posting. You have lots of extra '{' and '}'
As for printing out a value on the LCD, you are making it way harder than needed.
int val = analogRead(A0);
lcd.print(val);
No need to use String (never use it) and then convert it to a char array. The print() function does all that for you.
okay, i will clean up the '{', and i will also use
lcd.print(val);
i will test but can i then delete the calculation t1 and t2?
And im still confused to how i can do what i want to do.
I'm not sure exactly what you are trying to accomplish either. Have a look at the map() function. It might do what you want if I understand you correctly.
basically, you read A0 (0-1023) and then apply map() to that value to scale it to whatever delay value you want (t2) and then use that value in your delay() function calls rather than a hard coded 300.
Since you are new, I'd get that part working and only after it all works, have a look at the example BlinkWithoutDelay which shows you a better method for doing delays without stalling your program.
In your case, it doesn't matter, but future projects may need it. It would also allow you to read A0 more often
What i'm trying to accomplish is the Potentiometer to be able to change the speed of the flashing leds, at the moment its whatever the delay time between the six of them is.
once completed i should be able to connect a power source to the ardiuno and change the rate at which the leds blink with a display of this blinking.
Okay thank you i looked at the map function and i'm unsure if this will be useful.
Yes it will be useful if your maths is not up to this simple task.
