Leds to be turned off immediately when I turn off the switch
Hello, could anyone please help me with my code?
It's composed of 4 way switch and 8 Leds, each switch has a pattern of led lighting. What I really need is for leds to be also immediately turned off when the switch is off, even if its respective pattern is still not finished running. Thank you
Here's my code:
int LED1 = 13;
int LED2 = 12;
int LED3 = 11;
int LED4 = 10;
int LED5 = 9;
int LED6 = 8;
int LED7 = 7;
int LED8 = 6;
int S1 = 5;
int S2 = 4;
int S3 = 3;
int S4 = 2;
int val = HIGH;
int oneSec = 1000;
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);
pinMode(LED5, OUTPUT);
pinMode(LED6, OUTPUT);
pinMode(LED7, OUTPUT);
pinMode(LED8, OUTPUT);
pinMode(S1, INPUT);
pinMode(S2, INPUT);
pinMode(S3, INPUT);
pinMode(S4, INPUT);
if (val=digitalRead(S1)) {
digitalWrite(LED1, HIGH);//First row
delay(oneSec);
digitalWrite(LED2, HIGH);//Secondo row
delay(oneSec);
digitalWrite(LED1, LOW);
digitalWrite(LED3, HIGH);//Third row
delay(oneSec);
digitalWrite(LED2, LOW);
digitalWrite(LED4, HIGH);//Fourth row
delay(oneSec);
digitalWrite(LED3, LOW);//FIFTH
digitalWrite(LED5, HIGH);//FIFTH
delay(oneSec);
digitalWrite(LED4, LOW);//SIXTH
digitalWrite(LED6, HIGH);//SIXTH
delay(oneSec);
digitalWrite(LED5, LOW);//SEVENTH
digitalWrite(LED7, HIGH);//SEVENTH
delay(oneSec);
digitalWrite(LED6, LOW);//EIGHTH
digitalWrite(LED8, HIGH);//EIGHTH
delay(oneSec);
digitalWrite(LED7, LOW);//NINETH
delay(oneSec);
digitalWrite(LED8, LOW);
else{
if (val = digitalRead(S2)) {
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
} else{
if (val = digitalRead(S3)) {
delay(oneSec);
digitalWrite(LED1, LOW);//1st row
delay(oneSec);
digitalWrite(LED2, LOW);//2nd row
delay(oneSec);
digitalWrite(LED3, LOW);//3rd row
delay(oneSec);
digitalWrite(LED4, LOW);//4th row
delay(oneSec);
digitalWrite(LED5, LOW);//5th row
delay(oneSec);
digitalWrite(LED6, LOW);//6th row
delay(oneSec);
digitalWrite(LED7, LOW);//7th row
delay(oneSec);
digitalWrite(LED8, LOW);//8th row
delay(oneSec);
digitalWrite(LED7, LOW);//9th row
delay(oneSec);
digitalWrite(LED6, LOW);//10th row
delay(oneSec);
digitalWrite(LED5, LOW);//11th row
delay(oneSec);
digitalWrite(LED4, LOW);//12th row
delay(oneSec);
digitalWrite(LED3, LOW);//13th row
delay(oneSec);
digitalWrite(LED2, LOW);//14th row
digitalWrite(LED1, HIGH);//15th row
delay(oneSec);
} else{
if (val = digitalRead(S4)) {
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
} else{
Here's my code:
int LED1 = 13;
int LED2 = 12;
int LED3 = 11;
int LED4 = 10;
int LED5 = 9;
int LED6 = 8;
int LED7 = 7;
int LED8 = 6;
int S1 = 5;
int S2 = 4;
int S3 = 3;
int S4 = 2;
int val = HIGH;
int oneSec = 1000;
 pinMode(S1, INPUT);
 pinMode(S2, INPUT);
 pinMode(S3, INPUT);
 pinMode(S4, INPUT);
  delay(oneSec);
  delay(oneSec);
  delay(oneSec);
  delay(oneSec);
  delay(oneSec);
  delay(oneSec);
  delay(oneSec);
  delay(oneSec);
  delay(oneSec);
        else{
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
  } else{
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
} else{
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
delay(oneSec);
} else{
Hi @schwarz046 ,
Welcome to the forum..
The delay() function is what is jamming you up, it stops all execution until it finishes..
Need to rewrite sketch using non-blocking delays and a state machine for the leds..
Using arrays will make coding a bit easier and less..
let me know if you need more help..
god luck.. ~q
Hi @schwarz046 , Please don't crosspost.
https://forum.arduino.cc/t/leds-to-be-turned-off-immediately-when-i-turn-off-the-switch/1186794/1
I'm new to arduino and kind of lost in what you just said, could you please make a sample code for that for me to use as reference? Thank you
Your topic has been moved to the Programming category of the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
I have never used 4 way switches, but what i might try is wiring the switches into the lights. Is there a way that the switches can turn of the lights without the arduino even knowing? Could you also post your wiring?
those delays are killing you...
you need to change the structure of the code and get rid of the delays
For extra information and examples look at
You probably want to use a test for equality '==' rather than an assignment '=' in logical tests like that.
And you need to rewrite your sketch so it does not rely on delay() for timing. When those sequences using delay begin, there is nothing checking the switches or doing anything else.
Get comfy and google
  blink without delay Arduino
And
  Arduino two things at once
And
  Arduino finite state machine
And
  Arduino finite state machine traffic lights
HTH
a7
This requires to use non-blocking timing. And this means writing code without a single delay().
Each and every delay() must be replaced by non-blocking timing.
Are you ready for thinking totally different about how to do waiting ?
If not. The only way would be to open a switch in the GND-wire to interrupt the electric current.
Though switching on would still only be possible after finishing your existing code with all its delay()'s
Here you can learn about non-blocking timing
best regards Stefan
I took a different approach.
  • fixed your comparisons,
  • extracted duplicate codes,
  • extracted each action,
    in order to show you where your logic falls down. What the others have pointed to is correct, you need to get rid of delays() to address your immediate need, but your logic is also incorrect.
    Look at the if..else structures. If any button is not pressed, your logic will clear the LEDs, regardless of the actions of the other buttons. Of course, in the next pass of the loop, the LEDs are turned on again, so it might seem like 'it's doing what it should', but an oscilloscope on the LED outputs will show you things your eyes can't see.
    613732 3675 6702
  if (val == digitalRead(S1)) {
    pattern1();
  }    else {
    clearall();
  if (val == digitalRead(S2)) {
    pattern2();
    clearall();
  if (val == digitalRead(S3)) {
    pattern3();
    clearall();
  if (val == digitalRead(S4)) {
    pattern4();
    clearall();
Hi @schwarz046 ,
not sure which post to reply too.. :slight_smile:
give this a go..
#define LED1  13
#define LED2  12
#define LED3  11
#define LED4  10
#define LED5  9
#define LED6  8
#define LED7  7
#define LED8  6
const byte leds[] = {LED1, LED2, LED3, LED4, LED5, LED6, LED7, LED8};
const byte buttons[] = {5, 4, 3, 2};
byte lastButtons[] = {1, 1, 1, 1};
unsigned long lastReads[] = {0, 0, 0, 0};
byte currentState = 0;
byte currentStep = 0;
unsigned long lastStep = 0;
unsigned long stepDelay = 1000ul;
  for (int i = 0; i < sizeof(leds); i++) {
    pinMode(leds[i], OUTPUT);
  for (int i = 0; i < sizeof (buttons); i++) {
    pinMode(buttons[i], INPUT_PULLUP);
  //what time is it now..
  unsigned long now  = millis();
  for ( int i = 0; i < sizeof(buttons); i++) {
    if (now - lastReads[i] >= 50) {
      byte btn = digitalRead(buttons[i]);
      if (btn != lastButtons[i]) {
        lastReads[i] = now; //start debouncing..
        lastButtons[i] = btn;
        if (btn == LOW) {
          currentState = i + 1;
          currentStep = 0;
          AllOff();
  switch (currentState) {
    case 0: AllOff(); break;
    case 1: {
        switch (currentStep) {
          case 0: digitalWrite(LED1, HIGH); lastStep = now; currentStep++; break;
          case 1: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 2: digitalWrite(LED2, HIGH); lastStep = now; currentStep++; break;
          case 3: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 4: digitalWrite(LED1, LOW);
          case 5: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 6: digitalWrite(LED2, LOW);
          case 7: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 8: digitalWrite(LED3, LOW);
            digitalWrite(LED5, HIGH);//Fourth row
          case 9: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 10: digitalWrite(LED4, LOW);
            digitalWrite(LED6, HIGH);//Fourth row
          case 11: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 12: digitalWrite(LED5, LOW);
            digitalWrite(LED7, HIGH);//Fourth row
          case 13: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 14: digitalWrite(LED6, LOW);
            digitalWrite(LED8, HIGH);//Fourth row
          case 15: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 16: digitalWrite(LED7, LOW); lastStep = now; currentStep++; break;
          case 17: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 18: digitalWrite(LED7, LOW); currentStep++; break;
          case 19: AllOff(); currentStep++; break;
      } break;
    case 2: {
              currentStep++;
            } break;
          case 2: digitalWrite(LED1, LOW);
            digitalWrite(LED2, HIGH);//Third row
              currentStep++;
            } break;
          case 4: digitalWrite(LED2, LOW);
            digitalWrite(LED1, HIGH);//Third row
              currentStep++;
            } break;
          case 6: digitalWrite(LED1, LOW);
            digitalWrite(LED3, LOW);//Third row
            digitalWrite(LED4, HIGH);//Third row
              currentStep++;
            } break;
          case 8: digitalWrite(LED2, LOW);
            digitalWrite(LED4, LOW);//Third row
              currentStep++;
            } break;
          case 10: digitalWrite(LED3, LOW);
            digitalWrite(LED5, LOW);//Third row
            digitalWrite(LED6, HIGH);//Third row
              currentStep++;
            } break;
          case 12: digitalWrite(LED4, LOW);
            digitalWrite(LED6, LOW);//Third row
            digitalWrite(LED5, HIGH);//Third row
            digitalWrite(LED7, HIGH);//Third row
              currentStep++;
            } break;
          case 14: digitalWrite(LED5, LOW);
            digitalWrite(LED7, LOW);//Third row
            digitalWrite(LED8, HIGH);//Third row
              currentStep++;
            } break;
          case 16: digitalWrite(LED6, LOW);
            digitalWrite(LED8, LOW);//Third row
              currentStep++;
            } break;
          case 19: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 20: digitalWrite(LED8, LOW);
          case 21: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 22: digitalWrite(LED8, LOW);
          case 23: AllOff(); currentStep++; break;
      } break;
    case 3: {
              currentStep++;
            } break;
              currentStep++;
            } break;
              currentStep++;
            } break;
          case 6: digitalWrite(LED3, LOW);
              currentStep++;
            } break;
          case 8: digitalWrite(LED4, LOW);
              currentStep++;
            } break;
          case 10: digitalWrite(LED5, LOW);
              currentStep++;
            } break;
          case 12: digitalWrite(LED6, LOW);
              currentStep++;
            } break;
          case 14: digitalWrite(LED7, LOW);
              currentStep++;
            } break;
          case 16: digitalWrite(LED8, LOW);
              currentStep++;
            } break;
              currentStep++;
            } break;
          case 20: digitalWrite(LED6, LOW);
              currentStep++;
            } break;
          case 22: digitalWrite(LED5, LOW);
          case 23: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 24: digitalWrite(LED4, LOW);
          case 25: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 26: digitalWrite(LED3, LOW);
          case 27: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 28: digitalWrite(LED2, LOW);
          case 29: if (now - lastStep >= stepDelay) {
              currentStep++;
            } break;
          case 30: AllOff(); currentStep++; break;
      } break;
    case 4: {
              currentStep++;
            } break;
              currentStep++;
            } break;
          case 4: digitalWrite(LED3, HIGH);
              currentStep++;
            } break;
          case 6: digitalWrite(LED4, HIGH);
              currentStep++;
            } break;
          case 8: digitalWrite(LED5, HIGH);
              currentStep++;
            } break;
          case 10: digitalWrite(LED6, HIGH);
              currentStep++;
            } break;
          case 12: digitalWrite(LED7, HIGH);
              currentStep++;
            } break;
          case 14: digitalWrite(LED8, HIGH);
              currentStep++;
            } break;
              currentStep++;
            } break;
              currentStep++;
            } break;
              currentStep++;
            } break;
              currentStep++;
            } break;
              currentStep++;
            } break;
              currentStep++;
            } break;
              currentStep++;
            } break;
      } break;
void AllOff() {
    digitalWrite(leds[i], LOW);
have fun.. ~q
is there really no other way aside from using blink without delay? I've seen my peers use the "break;" command and it works for them
You can't insert a "break;" inside a delay()
You will have to use while-loops and additionally
  • check the state of all 4 switches inside the while-loop
  • so you can break; out of the while-loop()
best regards Stefan
when you need to wait, you could check the buttons
unsigned long t0 = millis();
bool needToExit = false;
while (millis() - t0 <= 1000) {
  if (digitalRead(buttonPin) == LOW) { // button is pressed, interrupt sequence
    needToExit = true;
if (needToExit) return; // or whatever is needed to exit from current pattern
not fantastic but could be away to check the button status along the pattern execution...
int SW[4] = {2,3,4,5};
int LEDs[8] = {6,7,8,9,10,11,12,13};
int CurrentState=0;
  for(int x=0; x<4; x++)
   pinMode(SW[x], INPUT);
  for (int x=0; x<8; x++)
    pinMode(LEDs[x], OUTPUT);
  TurnOffAll();
  if (digitalRead(2)==HIGH && digitalRead(3)==LOW && digitalRead(4)==LOW && digitalRead(5)==LOW){
     Pattern1();
  if (digitalRead(2)==LOW && digitalRead(3)==HIGH && digitalRead(4)==LOW && digitalRead(5)==LOW){
 Pattern2();
 if (digitalRead(2)==LOW && digitalRead(3)==LOW && digitalRead(4)==HIGH && digitalRead(5)==LOW){
  Pattern3();
if (digitalRead(2)==LOW && digitalRead(3)==LOW && digitalRead(4)==LOW && digitalRead(5)==HIGH){
    Pattern4();
  TurnOffAll();
Serial.println(digitalRead(2));
Serial.println(digitalRead(3));
Serial.println(digitalRead(4));
Serial.println(digitalRead(5));
Serial.println("================");
  //Serial.println(digitalRead(3));
 // Serial.println(digitalRead(4));
 // Serial.println(digitalRead(5));
 // Serial.println("=====================");
 void BlinkAll() {
   for (int x = 0; x <= 7; x++)
     digitalWrite(LEDs[x], HIGH);
     delayMicroseconds(1000);
void TurnOffAll(){
      digitalWrite(LEDs[x], LOW);
void Pattern1()
    for (int x = 0; x <= 8; x++)
      digitalWrite(LEDs[x-1], HIGH);
      if(digitalRead(2)==LOW)
      digitalWrite(LEDs[x-1], LOW);
void Pattern2()
    for (int x = 0; x <= 9; x++)
      digitalWrite(LEDs[x-2], HIGH);
       if(digitalRead(3)==LOW)
      digitalWrite(LEDs[x-2], LOW);
void Pattern3()
 for(int x=0; x<=7; x++)
    if(digitalRead(4)==LOW)
  for(int x=6; x>=0; x--)
void Pattern4()
{for(int x=0; x<=7; x++)
    if(digitalRead(5)==LOW)
  for(int x=7; x>=0; x--)
Above is the code of my peer. It gets the job done which is to immediately turn off all leds when no switch is turned on, and it happens to work when he integrated the "break" command in his code. It's too complex for me to understand but in what way can I also integrate "break" command in my code earlier?
You have a different idea if what immediate means. It looks like you are happy waiting as long as 1000 milliseconds for this "immediate" reaction.
So if that is immediate enough for your purposes, all done.
When that level of immediacy proves to be excruciatingly unacceptable, you'll need to turn to one of the several examples offered that demonstrate the ideas some of us are pushing towards you.
a7
Hi @schwarz046 ,
My example in a sim..
Uno Button Blink Leds..
good luck.. ~q
@qubits-us your example
it does not stop if the button is released
didn't realize that was a requirement..
sorry.. ~q
