Beginners problem with coding
Hi All, I am very much a newbie, teaching myself how to use and Arduino as best as I can. I have seen all the tutorials and youtube vids that I can. I am trying to flash 7 Leds in sequence when a button switch is pressed, then hold them on. I can do this with a sketch I did without the switch, but cannot get the switch part to work. I have tried everything I can think of to no avail. This is the sketch that compiles and uploads but just holds the leds on dimly. I am using the 5v and ground of the arduino Uno board and pin 11 to try and detect the switch operation.
int  switchpin = 11;  // pin 11 connected to switch
int timer = 500;           // The higher the number, the slower the timing.
int timer2 = 3000;
int thisPin;
  // set up digital pin read for switch
   pinMode (thisPin, OUTPUT);
  // use a for loop to initialize each pin as an output:
   pinMode (switchpin, INPUT);
  int switchPin = 11;
  if (digitalRead (switchpin) == HIGH);
  for (int thisPin = 2; thisPin < 9; thisPin++) {
  // loop from the lowest pin to the highest:
    // turn the pin on:
    digitalWrite(thisPin, HIGH);
    delay(timer);
    // turn the pin off:
    digitalWrite(thisPin, LOW);
  // loop from the highest pin to the lowest:
  for(int thisPin = 9; thisPin >= 2; thisPin--)
    // turn the pin on:
    delay(timer2);
Any help would be greatly appreciated
For a start:
Without enclosing the lines that are a part of the for loop code block, only the firs line after the for will execute as part of the for loop.
Enclose all the lines that you want to repeat in curly brackets. See the for structure reference.
    // turn the pin on:
    digitalWrite(thisPin, HIGH);  this is the only line that is in the for loop
    delay(timer);
Does your switch have a pulldown resistor so that the unpressed switch input is not floating?
Can you show the working code without the switch? Your loops look weird, and I'm surprised they worked without the switch.
That sets, only, pin 0 to output. Is that what you intend?
Thanks groundFungus. The switch has a pull up resistor, but even when I disconnect lead pin 11 from the switch circuit the sketch should wait until the voltage is high but it doesn't
This works without the switch
int timer2 = 3000;
    pinMode(thisPin, OUTPUT);
    delay(timer);
  for (int thisPin = 9
; thisPin >= 2; thisPin--) {
    // turn the pin on:
    delay(timer2);
type or paste code here
But then the loop assigns pin 2 to pin 8 as OUTPUT
The ";" at the end means that nothing is executed if this is true.
@skindog386
I modify your code.
int timer2 = 3000;
int thisPin;
// for loop need this ---> { }
   // this will set pin 2 to pin 8 as output
  // I prefer you hook up like +5 V --- Resistor -- pin 11 --- push button --- GND
// when the switch is press ... it will produce a LOW - 0 - 0 V signal
  if (digitalRead (switchpin) == LOW)
    // you forgot the  {   }
   delay(100); // debounce time
      // turn the pin on
     delay(timer);
 // end of loop one
  for(int thisPin = 8; thisPin > 1; thisPin--)
     // turn the pin on:
     delay(timer2);
// end of loop 2
// closing the if () stament
The code should compile. But as for working as intended... that you have to check it out.
Start with this working code and try to add the code for the switch into it. You missed and changed some things when building the new code from it.
Thank you so much, lots of info in there I can use. Much appreciated
Thats correct, that is what I wanted as waiting for button push
It doesn't wait... it just moves to the next line of code.
if (condition)
  ; // do nothing
  // do next thing
If you want to wait then you could use while instead of if.
It doesn't technically wait, but since it loops, doesn't it effectively wait? Assuming power draw isn't an issue. I'm learning too and trying to help other new people while I am between projects.
No because in the original sketch the subsequent for loops are executed regardless of the value of the button. If they were enclosed within {} (as @sergetechone has done in post #9) then yes it would effectively wait.
Hi guys, thanks so much for your help so far, but I have one more small issue to solve. I have got the 7 leds to come on individually one at a time then scroll backwards through the sequence. However I am trying to make all 7 leds come on at the same time for a couple of seconds then go out. I have written this code the long way coz if I use the same loop and a timer delay the leds come on sequentially. However, I cant seem to get past this error.
int timer = 250;           // The higher the number, the slower the timing.
int timer2 = 250;
int timer3 = 1000;
int thisPin;
int allpin2 = 2;
int allpin3 = 3;
int allpin4 = 4;
int allpin5 = 5;
int allpin6 = 6;
int allpin7 = 7;
int allpin8 = 8;
pinMode (allpin2, OUTPUT);
PinMode (allpin3,OUTPUT);
PinMode (allpin4,OUTPUT);
PinMode (allpin5,OUTPUT);
PinMode (allpin6,OUTPUT);
PinMode (allpin7,OUTPUT);
PinMode (allpin8,OUTPUT);
      // turn the pin on
     delay(timer);
 // end of loop one
     // turn the pin on:
     digitalWrite(allpin2, HIGH);
     digitalWrite(allpin3, HIGH);
     digitalWrite(allpin4, HIGH);
     digitalWrite(allpin5, HIGH);
     digitalWrite(allpin6, HIGH);
     digitalWrite(allpin7, HIGH);
     digitalWrite(allpin8, HIGH);
     delay(timer);
digitalWrite(allpin2, LOW);
digitalWrite(allpin3, LOW);
digitalWrite(allpin4, LOW);
digitalWrite(allpin5, LOW);
digitalWrite(allpin6, LOW);
digitalWrite(allpin7, LOW);
digitalWrite(allpin8, LOW);
// end of loop 2
the errors are the following.
C:\Users\Skindog home\7 led switch 2\7 led switch 3\7 led switch 3.ino:38:9: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\Skindog home\7 led switch 2\7 led switch 3\7 led switch 3.ino:39:9: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\Skindog home\7 led switch 2\7 led switch 3\7 led switch 3.ino:40:9: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\Skindog home\7 led switch 2\7 led switch 3\7 led switch 3.ino:41:9: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\Skindog home\7 led switch 2\7 led switch 3\7 led switch 3.ino:42:9: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\Skindog home\7 led switch 2\7 led switch 3\7 led switch 3.ino:43:9: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\Skindog home\7 led switch 2\7 led switch 3\7 led switch 3.ino:44:9: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\Skindog home\7 led switch 2\7 led switch 3\7 led switch 3.ino:45:1: error: expected declaration before '}' token
exit status 1
Compilation error: expected constructor, destructor, or type conversion before '(' token
Once again many thanks for taking the time to help
pinMode vs. PinMode
I am sorry, I dont know what you mean. The word pinMode is written the same in all instances.............. I think
Are you sure?????
PinMode is not the same as pinMode. The capital p is the difference. C++ is really anal about case.
