LEDs with multiple sequences
New to Arduino and found this forum while researching for a project.
I would like to run a set of 10 or so LEDs in a sequence which seems fairly easy to do with the Uno. The catch is I'm looking to have 6 of these sets tied together that would run one after the other but with minute or so in between. After all sequences are finished, a button push would restart it.
I’ve seen sequencers designs and controllers but nothing that quite fits this. Any suggestions would be most appreciated and welcomed. Thanks!
Welcome !
  • So you want 10 LEDs * 6 = 60 LEDs total ?
  • If Neo-Pexels will do, use 6 strips of 10 LEDs per.
Have you seen this one?
Thanks for the quick replies. I'll do a little dwg that may be more helpful. I think I found the place for the answer or at least some great guidance!
You can also get Neo-pixel LEDs in individual LEDs, not just strips.
These can vary from an individual LED on its own miniature PCB, to a strings of LEDs connected by flexible wire, looking a bit like Christmas Tree lights but individually addressable.
Have a good look on your Web Browser of choice and see what you can find.
Thanks again for the suggestions, I was looking to use individual LED's rather than strips. I created a pdf which shows the detail but unfortunately I can not attach since a newbie.
I was asked if I can add some animation to a historical revolution topo map display, that is mounted on foam board, to show six areas (each a separate sequence segment) of the progressive movement of troops. After finding the Arduino, doing one segment looks easy enough, its tying them all together to run one after the other which is the challenge but also the cost if one Arduino is needed for each of the six segments.
If there is a cost effective solution there are at least five separate maps, which is a lotta LED's and soldering to have by Memorial Day. If not then maybe I'll just wire each segment of 10 LED's, each with it's own button, and the user will need to be the automated operator.
Thanks
Hi, @cs1426
Welcome to the forum.
Export your diagram from your CAD as a jpg or png and post the image.
Tom.... :smiley: :+1: :coffee: :australia:
The sequencer linked in post #3 does exactly that. You put a "dash" for "LED OFF" and a "star" for "LED ON"... The sequence is made of ROWS for LEDs and COLUMNS for TIMING. The complete sequence will repeat, and the sequence can be as long as you want. Each column is a timed sequence. You select the duration of each event/column. One LED can be switched ON and left ON for as long as you want. If you want a muzzle flash every minute, ensure the product of "columns" times "duration" equals one minute or more... ask me anything.
An option for the software that could save you some time is MultiBlink5 (MultiBlink/Multi_Blink5_Neo/Multi_Blink5_Neo.ino at main · MajicDesigns/MultiBlink) which animates neopixel LEDs in different colors in set sequences depending on the data tables you provide in the code. I know one user who is using this to animate the display colors of lighthouses on a coastal map, which seems similar to your use case.
Blog post describing this software at MultiBlink – Simplifying concurrent LED patterns – Arduino++
Was able to attach this time, hope it makes sense, thanks for the suggestions.
RHS LED Map.pdf (103.0 KB)
Looks like a project with a WS2812 solution.
Yes I know, I said:-
Like these:-
You can also get smaller LEDs than the set shown above.
Did you ever bothered to do any searches like I advised?
You could always use 3mm white LEDs and address them individual. The wiring may be more complex but it might offer the sort of size you are looking for. However an addressable latch would help simplify things.
@Grumpy_Mike
I found those addressable LEDS under: APA106, 5MM... with 50 LEDs per string and factory-made connectors installed.
Welcome :slightly_smiling_face:
What you want is completely doable with an Arduino Uno — no special sequencer needed.
Basic idea:
  • Create 6 separate LED sequences in code
  • Run one sequence
  • Wait ~1 minute
  • Move to the next
  • After all 6 finish, wait for a button press to restart
Use a simple state machine and millis() instead of long delay() calls so timing stays clean.
If you’re controlling ~60 LEDs total, you may need shift registers (like 74HC595) to save pins.
If you share how many LEDs are on at once, people can suggest a more specific setup.
Sorry, been busy with my regular work. I did find the Neo-pixel LED on the Adafruit website but haven’t had a chance to research further. Straight runs using LED strips would likely work but the end user wanted to have a few curves so I was looking for individual LED’s (3 or 5mm) that could be poked through the foam core.
Wiring everything is secondary, I’m new to the automation aspect (and getting into any advanced coding), so any suggestions and even specific parts numbers are more than welcomed!
Thank you.
APA106 from Post #12... if you get the loose, individual LEDs, you can adjust the length of the connecting wires.
The diagram you posted had curves, but you will not see those curves in space. Think about it you are just using a flat sequence of light there is no way you can see anything else.
What we need to see is your sequence with a number attached to each LED in your system, and then each sequence showing the number or numbers of the LED that is lit at that stage in the sequence.
I think your are not understanding how things are going to look physically.
As to the hardware then I would go for the 74LS259 addressable latch to drive the hardware. As one latch only drives 8 LEDs then you need two of them.
If you want to see those specific shapes in the diagram posted in Reply #13 then you do not want just 10 LEDs to be controlled you need to control 60 LEDs. That is 10 LEDs per sequence.
However, as there will only be one LED on at any one time you will only need to supply the current for one LED. But each LED will need its own current limiting resistor. Also you will need two addressable latches per sequence.
I am not sure you are aware of this.
Thanks for your suggestions and support, updated a dwg which may help with the detail.
RHS LED wMap.pdf (2.6 MB)
