Arduino based RCX 2.0 Programmer to be used with lejosfirmdl.exe as a substitute for the Lego IR Tower. Incredible simple hardware design with zero soldering. I made it to upload HaikuVM and LeJOS firmware and programs to the RCX 2.0 (also known as Lego Brick).
Download the sketch from here.
Hardware part list
- Arduino (I have a Yun)
- IR LED (I used SFH-409)
- IR Receiver (I used a TSOP 31236)
See the assembled design:
See the Programmer in action:
Hardware layout for the RCX Programmer
Pin usage IR LED and TSOP for 950nm and 38kHz carrier:
IR-LED:SFH-409 TSOP 31236
cathode anode
- + Data VCC GND
9 10 11 12 13 GND
ARDUINO
I guess similar TSOPs with 950nm and 38kHz carrier will do as well.
Any source code enhancements/solutions are welcome to make it full duplex or create a 38khz carrier signal based on interrupts or PWM.
