Im sorry if I put this in the wrong category I didnt know where to ask for help. Ive bought an arduino like 1 month ago and Ive been using it as a mouse for tasks on my computer. Theres never been any problem with it but now all of a sudden I cant use it anymore.
When I connect to the pc like Ive always done hear that windows (10) sound when u connect a new device, then after 3-5 seconds the sound for the device disconnecting happens. The on light is green on the board. When I have open devices in windows settings when I first connect it it recognizes the board and assigns it a COM port, it calls it "Arduino Leonardo Bootloader COM" with a COM port of course, then when I hear the disconnect sound it just calls it "Arduino Leonardo". In device manager it recognizes it as a Arduino Leonardo with a COM port even when its disconnected, also in the IDE it sees it and assigns it a COM port.
I cant upload sketches to it, I tried 1.x and 2.x IDE and I cant write to it with pyserial anymore like Ive done before. Ive tried multiple cable, different ports and assigning it a different COM port number in device manager but nothing works.
Sketch uses 3462 bytes (12%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes (5%) of dynamic memory, leaving 2411 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port COM6
PORTS {COM6, } / {} => {}
PORTS {} / {COM5, } => {COM5, }
Found upload port: COM5
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM5 -b57600 -D -Uflash:w:C:\Users\Fred\AppData\Local\Temp\arduino_build_980236/sketch_jul30a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "C:\Users\john\AppData\Local\Temp\arduino_build_980236/sketch_jul30a.ino.hex"
avrdude: writing flash (3462 bytes):
Writing | ################################################## | 100% 0.26s
avrdude: 3462 bytes of flash written
avrdude: verifying flash memory against C:\Users\john\AppData\Local\Temp\arduino_build_980236/sketch_jul30a.ino.hex:
avrdude: load data flash data from input file C:\Users\john\AppData\Local\Temp\arduino_build_980236/sketch_jul30a.ino.hex:
avrdude: input file C:\Users\john\AppData\Local\Temp\arduino_build_980236/sketch_jul30a.ino.hex contains 3462 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.02s
avrdude: verifying ...
avrdude: 3462 bytes of flash verified
avrdude done. Thank you.
When I upload a blank sketch ^
