Level shift SPI
Hi all,
I want to connect a DollaTek TFT display with an Arduino. This display works with 3.3 V and is connected via SPI. Of course the Vcc input goes to Arduino's 3.3V output. The CLK, CS, and MOSI pins will be connected via a level shift IC (I have the CD4050BE lying around), but what is with its RST pin? I assume, the signal direction is from TFT to the Arduino? So can I connect it directly (as the Arduino rates 3.3 V as HIGH)? Is that true?
Thanks for helping,
-richard
What kind of "Arduino" are You using? It seams to be a 5 volt unit.
I would not be too sure that the 3.3 volt output delivers enough current. Did You check the specs?
Yes, a 3.3 volt output is fine to connect to 5 volt unit input.
Arduino nano. And yes, the nano provides a maximum of 50 mA on its power pins. That may be too less for the display. So a discrete power source would be adequate.
Check the datasheet for the display.
Insufficient power supplied is way too often the reason for none functioning projects. Avoid falling into that hole.
Prove it. I wouldn’t assume… anything when messing around with this stuff.
Determine. Then use a level shifter, or whatever to adjust to the needs of the two parties.
a7
Ah, that explains perhaps something: I have used an Uno with a TFT shield (this should work...), and very often the display turned suddenly white (only backlight). This happened with several display shields of the same kind. Perhaps these China displays are poorly dimensioned?
Not really. The backlight often consumes more current than the LCD and its logic. Just check the specs.
Between two fingers, calculate for max 50 mA from the 3.3 or 5 volt output of boards like an UNO.
I did power a NEO-6M GPS from the 3.3 volt of an UNO powered by a 5 volt phone charger battery, and that worked. Now use the 5 volt pin...
Not to be misunderstood: I wrote a questionmark. This was not a statement... Of course there are chinese quality products.
No problem. The idea for this forum replies is that more members than You are reading them. It's not a personal service for You but for the whole community.
Misunderstandings or wrong ideas are common so clarifying things like this will likely reach more members than You.
An Uno has a dedicated 3.3volt regulator that can provide 150mA (wrongly stated as 50mA in the spec sheets).
A (classic/clone) Nano however struggles to deliver more than 30mA, because it's 3.3volt power is stolen from the CH340 USB chip.
Leo..
Thanks! Didn't feel like diving down in specs, just made a shot from the hip to make OP check things up.
Thanks for all your replies. I lay the display aside until I get a TXS0108 for level shifting, this will be in the next days. In the meantime I tried a different display, but it also fails to work with the CD4050. I'll report.
