Hi People,
I recently switch to linux and I have in mind to do some stuff using arduino.
I installed the ide for linux (pop os) and successfully upload the blink example on my arduino board.
But when I want to use a library i got an error : library not found
here's a example if i want to try the midiusb example :
Arduino : 1.8.19 (Linux), Carte : "Arduino Nano, ATmega328P (Old Bootloader)"
arduino-builder -dump-prefs -logger=machine -hardware /usr/share/arduino/hardware -tools /usr/share/arduino/hardware/tools/avr -libraries /home/blood01/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=0403_6001 -ide-version=10819 -build-path /tmp/arduino_build_209088 -warnings=none -build-cache /tmp/arduino_cache_651994 -prefs=build.warn_data_percentage=75 -verbose /home/blood01/Arduino/sketchbook/miditest/miditest.ino
arduino-builder -compile -logger=machine -hardware /usr/share/arduino/hardware -tools /usr/share/arduino/hardware/tools/avr -libraries /home/blood01/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=0403_6001 -ide-version=10819 -build-path /tmp/arduino_build_209088 -warnings=none -build-cache /tmp/arduino_cache_651994 -prefs=build.warn_data_percentage=75 -verbose /home/blood01/Arduino/sketchbook/miditest/miditest.ino
Using board 'nano' from platform in folder: /usr/share/arduino/hardware/arduino/avr
Using core 'arduino' from platform in folder: /usr/share/arduino/hardware/arduino/avr
Detecting libraries used...
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/eightanaloginputs" "/tmp/arduino_build_209088/sketch/miditest.ino.cpp" -o "/dev/null"
Generating function prototypes...
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/eightanaloginputs" "/tmp/arduino_build_209088/sketch/miditest.ino.cpp" -o "/tmp/arduino_build_209088/preproc/ctags_target_for_gcc_minus_e.cpp"
/home/blood01/Arduino/sketchbook/miditest/miditest.ino:11:21: erreur fatale: MIDIUSB.h : Aucun fichier ou dossier de ce nom
compilation terminée.
exit status 1
Erreur de compilation pour la carte Arduino Nano
Same stuff if I start a new empty sketch and i want to include a stock library like eeprom.h for example.
I check my preferences and the folder is ok (home/blood01/Arduino/) and the library i need is well installed in home/blood01/Arduino/libraries/MIDIUSB/
I saw some other topic on this forum talking about that but none gave me a solution so if someone have an idea on how i can fix that, it will be great
thanks a lot
