LIDAR ROBOT - nrf24l01 rf transceiver + LCD + TF-Mini S
Hello,
Working on a project for university a LIDAR Robot which is capable of mapping a room.
I have started by creating a receiver using an Arduino uno with an LCD mounted to a breadboard.
The LIDAR Robot also uses an Arduino Uno with a TF-Mini S as the LIDAR Sensor and both components use nrf24l01 rf to transmit and receive.
I have coded the LIDAR Robot and reciever.
Each component works separately but not combined.
Code Shown Below:
// LIDAR ROBOT
#include <SoftwareSerial.h>
#include "TFMini.h"
#include <SPI.h>
#include <RF24.h>
#include <nRF24L01.h>
#include <Servo.h>  // Library used for servo motors with predefined functions and methods
TFMini tfmini;
int E1 = 0;        //Enable1 set to digital pin 0 - Front Left Wheel
int M1 = 1;        //Motor1 set to digital pin 1 - Front Left Wheel
int E2 = 2;        //Enable2 set to digital pin 2 - Front Right Wheel
int M2 = 3;        //Motor2 set to digital pin 3 - Front Right Wheel
int E3 = 4;        //Enable3 set to digital pin 4 - Back Left Wheel
int M3 = 5;        //Motor3 set to digital pin 5 - Back Left Wheel
int E4 = 6;        //Enable4 set to digital pin 6 - Back Right Wheel
int M4 = 7;        //Motor4 set to digital pin 7 - Back right Wheel
int Distance = 0;  //set distance value to 0
int Strength = 0;  //set strength value to 0
int pos = 0;       // variable to store the servo position
boolean object;
SoftwareSerial Serial0(12, 13);
float time = 0;
long duration, cm;
int i;
int Check;
int data = 0;
int uart[10];              //save data measured by LiDAR
const int HEADER = 0x59;  //frame header of data package
RF24 radio(9, 8);         // CE, CSN
const byte address[6] = "00001";
Servo myservo;
  Serial.begin(9600);         //set bit rate of serial port connecting Arduino with computer
  Serial0.begin(115200);      //set bit rate of serial port connecting LiDAR with Arduino
  radio.begin();
  radio.openWritingPipe(address);
  radio.setPALevel(RF24_PA_MAX);
  myservo.attach(10);  // attach the servo to our servo object
  myservo.write(98);
  pinMode(M1, OUTPUT);  //sets Left Motor to OUTPUT
  pinMode(M2, OUTPUT);  //sets Right Motor to OUTPUT
  pinMode(E1, OUTPUT);  //sets Left Enable to OUTPUT
  pinMode(E2, OUTPUT);  //sets Right Enable to OUTPUT
  pinMode(M3, OUTPUT);  //sets Left Motor to OUTPUT
  pinMode(M4, OUTPUT);  //sets Right Motor to OUTPUT
  pinMode(E3, OUTPUT);  //sets Left Enable to OUTPUT
  pinMode(E4, OUTPUT);  //sets Right Enable to OUTPUT
  radio.stopListening ();
  for (pos = 0; pos <= 180; pos += 1) {
    myservo.write(pos);
  for (pos = 180; pos >= 0; pos -= 1) {
    myservo.write(pos);
  if (Serial0.available())                //check if serial port has data input
    if (Serial0.read() == HEADER)        //assess data package frame header 0x59
      uart[0] = HEADER;
        uart[1] = HEADER;
        for (i = 2; i < 9; i++)         //save data in array
          uart[i] = Serial0.read();
        Check = uart[0] + uart[1] + uart[2] + uart[3] + uart[4] + uart[5] + uart[6] + uart[7];
        if (uart[8] == (Check & 0xff))        //verify the received data as per protocol
          Distance = uart[2] + uart[3] * 256;     //calculate distance value
          Strength = uart[4] + uart[5] * 256; //calculate signal strength value;
          Serial.print("Distance = ");
          Serial.print(Distance);
          Serial.print('\t');
          Serial.print("Strength = ");
          Serial.print(Strength);
          Serial.print('\n');
          radio.write(&data, sizeof(data));
          Serial.println(Distance);
          delay(400);
#Receiver
#include <SPI.h>
#include <RF24.h>
#include <LiquidCrystal.h>
RF24 radio(8, 9); // CE, CSN
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int txt = 0;
  while (!Serial);
  radio.begin();
  radio.openReadingPipe(1, address);
  lcd.begin(16, 2);
radio.startListening();
  if (radio.available())
  while (radio.available())
  if (Serial.available()) {
  radio.read(&txt, sizeof(txt));
  lcd.clear();
  lcd.write("Distance = ");
  while (Serial.available() > 0) {
  lcd.write(Serial.read());
Thank you for reading.
Any Help is Appreciated :+1:
What if serial becomes available, but no radio?
Why the if, followed by while?
Don't you want this for debugging?
Hello
Thank you for your response.
I should i have clarified the e1 m1 etc are for my wheels which will be mounted to a chasis.
I am using a dual h bridge motor
The if followed by while was due to me being able to show the readings on the serial monitor but not on the lcd screen. I was hoping by creating an if serial available it would work.
Thanks
Pins 0 and 1 on the Uno are used by Serial
