Hi there! I'm a secondary teacher who's recently been handed the job of trying to teach some 13 y.o.s to code. To keep them engaged I try and come up with a more complex project (they're at the "blink LED level") that they help me code before they have to sit through me hand holding them. (The above is also me apologizing for my awful code, I'm only two steps ahead of my students!)
This week's project is a "speed trap", a simple "If (going to fast) {Alarm = on;}"
I'm using a Mega2560 R3.
I've got a TF mini that I'm using to measure distance at two points which I then convert to cm/s for an output. ITI've got this working reasonably well however occasionally I get ridiculous values (students walk faster than mach1). This is probably the laser missing and the differential between the two measurements becoming massive.
As such I decided to try and filter/smooth the output by averaging three readings and/or using SimpleFilter.h to drop the value that's out of range.
What's odd is when I try to use delay to split the three measurements the whole system stops outputting to Serial after about six reading (I get six lines of reasonably accurate distance measurements) then nothing, no TX light on the arduino, nothing.
NB: I know none of this calculates speed or averages. I need consistent readings before I can tackle that.
int distance = 0;
int strength = 0;
getTFminiData(&distance, &strength);
while (!distance) {
Aa = distance;
delay(10);
Ab = distance;
delay(10)
Ac = distance;
//speed = (((distance2 - Result) * 20)); We're not calcuating speed till I can get consistent distance.
//Serial.println(Result);
Serial.print(Aa);
Serial.print(",");
Serial.print(Ab);
Serial.print(",");
Serial.println(Ac);
So I tried using Currentmillis/Previousmillis to set up a set of if statements. But this is where my coding knowledge falls apart. What I expect to happen is to see the first couple of readings have a couple of 0s as the CM/PM ticks up but the serial just outputs a series of Aa = 0, Ab = 0 and Ac = Avalue. If I track the CM/PM I don't see any variance between the two.
NB: PM is defined in setup and is 0 at start.
int distance = 0;
int strength = 0;
CM = millis();
while (!distance) {
if ((CM - PM) < 10) {
Aa = distance; //Aa is first value to be averaged Ab is 2 etc.
if ((CM - PM) > 10 && (CM - PM) < 15) {
Ab = distance;
if ((CM - PM) > 15) {
Ac = distance;
PM = CM;
//Serial.println(Result); //Ignore please, this is for later.
Serial.print(Aa);
Serial.print(",");
Serial.print(Ab);
Serial.print(",");
Serial.print(Ac);
Serial.print(",");
Serial.print(CM);
Serial.print(",");
Serial.println(PM);
Thank you SO much for your guidance and I apologize in advance for the truly awful code, I'm no doubt making a thousand mistakes I don't even recognize.
Here's all the stuff prior to void loop(). All of it seems to work fine.
#include "TFMini.h"
#include "MD_MAX72xx.h"
#include "MD_Parola.h"
#include "SimpleFilter.h"
TFMini tfmini;
#define HARDWARE_TYPE MD_MAX72XX::GENERIC_HW
#define MAX_DEVICES 1
#define CLK_PIN 52 // or SCK
#define DATA_PIN 51 // or MOSI
#define CS_PIN 3 // or SS
MD_Parola myDisplay = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
unsigned long CM;
unsigned long PM;
int CM2;
int PM2;
float distance2;
long speed;
int Aa;
int Ab;
int Ac;
int Avg[3];
int Result;
void getTFminiData(int* distance, int* strength) {
Serial2.begin(115200, SERIAL_8N1);
static char i = 0;
char j = 0;
int checksum = 0;
static int rx[9];
if (Serial2.available()) {
rx[i] = Serial2.read();
if (rx[0] != 0x59) {
i = 0;
} else if (i == 1 && rx[1] != 0x59) {
i = 0;
} else if (i == 8) {
for (j = 0; j < 8; j++) {
checksum += rx[j];
if (rx[8] == (checksum % 256)) {
*distance = rx[2] + rx[3] * 256;
*strength = rx[4] + rx[5] * 256;
i = 0;
i++;
Serial.begin(115200); //Initialize hardware serial port (serial debug port)
while (!Serial)
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Initializing...");
Serial2.begin(TFMINI_BAUDRATE); //Initialize the data rate for the SoftwareSerial port
tfmini.begin(&Serial2); //Initialize the TF Mini sensor
// Intialize the object:
myDisplay.begin();
// Set the intensity (brightness) of the display (0-15):
myDisplay.setIntensity(0);
// Clear the display:
myDisplay.displayClear();
myDisplay.setTextAlignment(PA_LEFT);
myDisplay.setZoneEffect(0, 1, PA_FLIP_UD);
myDisplay.setZoneEffect(0, 1, PA_FLIP_LR);
PM = 0;
Thanks again!
