Okay quick question.
Is it possible to use a light pipe with a Time of flight laser sensor?
Sensor I want to use is a VL53LOX.
I am mounting it in an enclosure and shooting thru a hole. Given the angle of the beam I am wondering if I can use a light pipe of .375" to get the beam out and back in the box.
So what are your thoughts?
rpmmillwright:
My thought is why haven't you tried it already? It will most likely work if you are using a visible light laser.
Be sure to polish the ends of the acrylic rod.
Paul
Have not ordered materials yet for the pipe.
I can see that there will be an offset in the measurement but that is no big deal to work around.
rpmmillwright:
Looking at the device, I see you need two light pipes and two holes.
Do you have the capability to solder the device to a circuit board?
Paul
