#Line driving me crazy
Hi Guys, im sorry for the bad Title but I have no idea whats happening..
I programmed a Website with html and js. The code ist stored using :
const char index_html[] PROGMEM = R"rawliteral(My website)rawliteral";
While testing and Programming in VS code and Live Server everything worked fine but now that I compiled my code and uploaded it to the esp8266 im getting the following error:
The corresponding code in my ArduinoIDE looks the following:
So i suspect the IDE is adding "#line 80 "C:\Users\se\Documents\Arduino\WebserverTest\WebserverTest.ino" " while compiling?
Any help is appreciated
My whole Code:
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <NTPClient.h>
#include "Adafruit_HTU21DF.h"
<!DOCTYPE HTML>
<html lang="de">
  <head>
    <meta name="viewport" content="width=device-width, initial-scale=1">
    <link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
    <title>Temperaturen und Luftfeuchtigkeit</title>
    <style>
      html {
      font-family: Arial;
      display: inline-block;
      margin: 0px auto;
      text-align: center;
      h2 { font-size: 3.0rem; }
      p { font-size: 3.0rem; }
      .units { font-size: 1.2rem; }
      .dht-labels{
        font-size: 1.5rem;
        vertical-align:middle;
        padding-bottom: 15px;
    </style>
  </head>
  <body>
    <h2>Temperaturen und Luftfeuchtigkeit</h2>
    <p>
      <span id="Time">%Time%</span>
    </p>
    <p>
      <i class="fas fa-thermometer-half" style="color:#059e8a;"></i>
      <span class="dht-labels">Temperature</span>
      <span id="temperature">%TEMPERATURE%</span>
      <sup class="units">&deg;C</sup>
    </p>
    <p>
      <i class="fas fa-tint" style="color:#00add6;"></i>
      <span class="dht-labels">Humidity</span>
      <span id="humidity">%HUMIDITY%</span>
      <sup class="units">%</sup>
    </p>
    <div style="width: 100%;">
      <div style="width: 45%; float: left; display: table-cell; padding: 10px; ">
        <canvas id="myChart"></canvas>
      </div>
      <div style="width: 45%; float: right; display: table-cell; padding: 10px; ">
        <canvas id="myChart2"></canvas>
      </div>
    </div>
    <script src="https://cdn.jsdelivr.net/npm/chart.js"></script>
  </body>
  <script>
    let TempArray;
    let HumArray;
    let AndererName;
    const ctx = document.getElementById('myChart');
    const ctx2 = document.getElementById('myChart2');
    GetTempData();
    GetHumData();
    GetTimeData();
    setInterval(GetTempData, 5000);
    setInterval(UpdateCHart, 5000);
    setInterval(GetHumData, 5000);
    setInterval(GetTimeData, 5000);
    async function GetTempData(){
      const TempResponse = await fetch("/Hum");
      const Temperature = await TempResponse.text();
      TempArray = Temperature.split("\r\n").map(Number);
      document.getElementById("temperature").innerHTML = TempArray[0];
      console.log(TempArray);
    async function GetHumData(){
      const HumResponse = await fetch("/Temp");
      const Humidity = await HumResponse.text();
      HumArray = Humidity.split("\r\n").map(Number);
      console.log(HumArray);
      document.getElementById("humidity").innerHTML = HumArray[0];
    async function GetTimeData(){
      const TimeResponse = await fetch("/Time");
      const Time = await TimeResponse.text();
      AndererName = Time.split("\r\n").map(Number);
      document.getElementById("Time").innerHTML = AndererName[0];
    function UpdateCHart(){
      MyChart.data.datasets[0].data = TempArray;
      MyChart.update();
      console.log("update");
    const MyChart = new Chart(ctx, {
      type: 'line',
      data: {
        labels: TimeArray,
        datasets: [{
          label: 'Temperatur in C',
          data: TempArray,
          borderWidth: 1
      options: {
        scales: {
          y: {
            beginAtZero: true
    const MyChart2 = new Chart(ctx2, {
      type: 'line',
      data: {
        labels: TimeArray,
        datasets: [{
          label: 'Luftfeuchtigkeit in %',
          data: TempArray,
          borderWidth: 1
      options: {
        scales: {
          y: {
            beginAtZero: true
  </script>
</html>)rawliteral";
// Webserver
ESP8266WebServer server(80);
Adafruit_HTU21DF htu = Adafruit_HTU21DF();
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "pool.ntp.org");
float temp[24];
float rel_hum[24];
float arrayTimeH[24];
void WiFiSetup(){
  const char* ssid = "XX";
  const char* password = "XX";
  WiFi.begin(ssid, password);
  Serial.print("Verbindung wird hergestellt ...");
  while (WiFi.status() != WL_CONNECTED)
      Serial.print(".");
  Serial.print("Verbunden! IP-Adresse: ");
void DNSSetup(){
  //http://Temp.local/
  const char* dns_name = "Temp";
  if (MDNS.begin(dns_name)) {
    Serial.println("DNS gestartet, erreichbar unter: ");
    Serial.println("http://" + String(dns_name) + ".local/");
  server.on("/", []() {
    server.send(200, "text/html", index_html);
  server.on("/Hum", []() {
    server.setContentLength(CONTENT_LENGTH_UNKNOWN);
    server.send(200, "text/plain", "");
    int i;
    for ( i = 0; i < 24; i++) {
    server.sendContent(String(rel_hum[i]) + "\r\n");
  server.on("/Temp", []() {
    int i;
    server.sendContent(String(temp[i]) + "\r\n");
  server.on("/Time", []() {
    int i;
    server.sendContent(String(arrayTimeH[i]) + "\r\n");
  server.begin();
void setup(){
  Wire.begin();
  Wire.setClockStretchLimit(4000);
  timeClient.begin();
  timeClient.setTimeOffset(3600);
  Serial.println("HTU21D-F test");
  if (!htu.begin()) {
    Serial.println("Couldn't find sensor!");
    while (1);
  WiFiSetup();
  DNSSetup();
  const int TriggerTime = 3600000;
  unsigned long NextTrigger;
  int i;
void loop(){
  if( millis() > NextTrigger){
    NextTrigger = millis() + TriggerTime;
    Serial.println(NextTrigger);
    Serial.println(millis());
    timeClient.update();
    arrayTimeH[i] = timeClient.getHours();
    Serial.println(arrayTimeH[i]);
    temp[i] = htu.readTemperature();
    rel_hum[i] = htu.readHumidity();
    Serial.print("Datensatz: ");
    Serial.println(i);
    Serial.print("Uhrzeit: ");
    Serial.print("Temp:");
    Serial.println(temp[i]);
    Serial.print("Humidity: ");
    Serial.println(rel_hum[i]);
    Serial.println("_________");
    i++;
    if(i>24){
      i=0;
  server.handleClient();
  MDNS.update();
Which version of the IDE are you using?
Looks like a possible bug with handling the raw text literal, all the lines that are being flagged are within the text and should not be processed as function declarations.
Im using 2.2.1
try to compile with 1.8.x just to see if you get the same issue
There is a bug (or there was one). From memory, solution is to put your const char index_html[] PROGMEM = R"rawliteral( ........</html>)rawliteral"; in an include file.
Seeing that this is posted in the IDE 2.x section, .... :smiley:
this is usually a nice thing to do as the rawliteral messes up the code indentation (done by pressing ctrlT on a PC or command ⌘T on a Mac)
Tank you so mutch!!
Hi @sporelamm. The Arduino developers are tracking this bug here:
