How Can I Make Line Fowller with help of Arduino decimilla and pid controller....
Plz ans me i have tournament on 18 of feb...
Best put the coffee pot on.
I'd say you've left it a bit late to start. What have you got so far? Have you built the robot? What sensor are you using? Motors? Shields?
Heyyy!!!!!
I m using 100rpm motor and i hv done connections but i hv got problem in programming and i m using PID controller and 7 sensor array.
Not to mention spelling and capitalization.
So, what problem have you got with the coding? What code are you having the problem in?
can u plz send me connections.
and tournament is posponedto 24th of feb 2012.
What connections?
What type of motor?
Which PID controller?
and 7 sensor array
Which 7 sensor array?
Still doesn't leave you much time.
dc motor 100 rpm.
7 line sensor array.
i can manage if u can help.
surbhitpulkit:
dc motor 100 rpm.
Not very helpful.
Which DC motor? 100rpm is seriously slow for a DC motor. What voltage does it require? Are you using a motor shield? Or an H-bridge? Or simply transistors?
Which 7 line sensor array? How does it connect to the Arduino? Post a link to it.
Not very helpful.
At the current rate of information exchange, I think OP might be a little late for next year's event.
i m using h-bridge and i m giving 12volts.
pulkit.docx (29.2 KB)
Can we try waterboarding?
It's extreme, but it may get answers.
can u plz tell me these codes are correct for line follower.
sketch_feb20a.ino (3.13 KB)
line_following_white (1).pde (3.12 KB)
this line sensor array i m using.
Focus broken?
If u can then jst tell me connections for line sensor array with arduino AtMega168.
I repeat: Which 7 line sensor array? Post a link to it. A fuzzy photo is no good.
Can you stop txting and start posting details?
Links?
Meaningful sentences?
