Hi there,
I am currently making a line following and obstacle avoiding robot which is supposed to follow a line and in case if there is an obstacle on the line, the robot will be able to direct away from it and then follow the line again, this is my code:
#include <NewPing.h> //Ultrasonic sensor function library. You must install this library
int vSpeed = 110;
int turn_speed = 230; // 0 - 255 max
int t_p_speed = 125;
int stop_distance = 12;
int turn_delay = 10;
//HC-SR04 Sensor connection
const int trigPin = 11;
const int echoPin = 12;
//L293 Connection
const int motorA1 = 3;
const int motorA2 = 4;
const int motorAspeed = 5;
const int motorB1 = 7;
const int motorB2 = 8;
const int motorBspeed = 6;
//Sensor Connection
const int left_sensor_pin =9;
const int right_sensor_pin =10;
int turnspeed;
int left_sensor_state;
int right_sensor_state;
long duration;
int distance;
pinMode(motorA1, OUTPUT);
pinMode(motorA2, OUTPUT);
pinMode(motorB1, OUTPUT);
pinMode(motorB2, OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
delay(3000);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance= duration*0.034/2;
Serial.print("Distance: ");
Serial.println(distance);
left_sensor_state = digitalRead(left_sensor_pin);
right_sensor_state = digitalRead(right_sensor_pin);
if(right_sensor_state == HIGH && left_sensor_state == LOW)
Serial.println("turning right");
digitalWrite (motorA1,LOW);
digitalWrite(motorA2,HIGH);
digitalWrite (motorB1,LOW);
digitalWrite(motorB2,HIGH);
analogWrite (motorAspeed, vSpeed);
analogWrite (motorBspeed, turn_speed);
if(right_sensor_state == LOW && left_sensor_state == HIGH)
Serial.println("turning left");
digitalWrite (motorA1,HIGH);
digitalWrite(motorA2,LOW);
digitalWrite (motorB1,HIGH);
digitalWrite(motorB2,LOW);
analogWrite (motorAspeed, turn_speed);
analogWrite (motorBspeed, vSpeed);
delay(turn_delay);
if(right_sensor_state == LOW && left_sensor_state == LOW)
Serial.println("going forward");
delay(turn_delay);
if(right_sensor_state == HIGH && left_sensor_state == HIGH)
Serial.println("stop");
analogWrite (motorAspeed, 0);
analogWrite (motorBspeed, 0);
while(true){
if(distance < stop_distance)
delay(250);
analogWrite (motorAspeed, t_p_speed);
analogWrite (motorBspeed, t_p_speed);
delay(900);
delay(800);
delay(900);
delay(700);
delay(650);
left_sensor_state == HIGH;
while(left_sensor_state == LOW){
Serial.println("in the first while");
delay(100);
delay (500);
The void loop has nothing in it because whenever I put the code in it, the whole entire robot doesn't even move, now the problem that I am facing is that the motors either move backwards, or one moves forwards and the other one doesn't, the robot doesn't stop if there is an obstacle in front of it or when there is no line at all, neither does it stop if the IR sensors are on top of a black strip even though the infrared sensors are sensing the black indicated by the leds of the ir sensors.
Here is a link to a video of what is going on:
Please help, thank you and have a nice day!
